while (EECR&(1<
EEDR = data;
EECR |= (1<
unsigned char Read_byte_eeprom(unsigned short address)
while (EECR&(1<
EECR |= (1<
return EEDR;
void Refresh_eeprom(void)
unsigned char i = 0;
unsigned char check = 0;
unsigned char *p = (unsigned char *)&ram;
asm("cli");
ram.start = 0x55;
for (; i
Write_byte_eeprom(i,*(p+i));
check += *(p+i);
Write_byte_eeprom(i,check);
asm("sei");
void Read_eeprom(void)
for (; i
*(p+i) = Read_byte_eeprom(i);
check += *(p+i);
//取值合理性判断
if ((*(p+i) != check) || (*p != 0x55))
Parameter_reset();
