//***************ICCAVR 编译*****************//
#include
#define uchar unsigned char
#define uint unsigned int
//数码管字型表,对应0,1,2,3,4,5,6,7,8,9,A,B,C,D,E,F//
uchar Table[16]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,
0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71};
uchar Read_Da
void DelayMs(uint i) //Ms级延时,参数i为延时时间
{uint j;
for(;i!=0;i--)
{for(j=8000;j!=0;j--) {;}}
void Display(uchar *p) //动态显示函数,参数p为待显示的数组名
{uchar i,sel=0x01;
for(i=0;i<4;i++)
{PORTA=sel; //选通最右边的数码管
PORTC=0xff-Table[p[i]]; //送字型码
DelayMs(1); //显示延时
sel=sel<<1; //移位以显示前一位
void Init_IO(void) //初始化I/O口
{DDRA=0xff; //设置A口为推挽1输出
PORTA=0xff;
DDRC=0xff; //设置C口为推挽1输出
PORTC=0xff;
void Write_EEPROM(uchar Da
{if(EECR&0x20) DelayMs(4);
EEARH=Address>>8;
EEARL=Address&0x00ff;
EEDR=Da
EECR=EECR|0x04;
EECR=EECR|0x02;
DelayMs(4);
uchar Read_EEPROM(uint Address)
{uchar i;
if(EECR&0x01) DelayMs(4);
EEARH=Address>>8;
EECR=EECR|0x01;
DelayMs(5);
i=EEDR;
return(i);
void main(void)
{uchar i;
Init_IO(); //初始化I/O口
PORTA=0xff; //点亮以测试所有的数码管
PORTC=0x00;
DelayMs(300); //延时
PORTC=0xff; //熄灭所有的数码管
for(i=0;i<4;i++)
Write_EEPROM(4*i,i);
for(i=0;i<4;i++)
Read_Da
while(1)
Display(Read_Da
