MSC-51 3字节和4字节浮点数计算程序,主要用于数据采集及上传,经过IEEE转换,在上位机直接显示.
;这是本人使用的MSC-51 3字节和4字节浮点数计算程序,主要用于数据采集及上传,经过IEEE转换,在上位机直接显示。
;本人还有热电阻和热电偶温度查表计算程序,有需要可EMAIL:majingsong1@2911.net
; FLOATING PROGRAM
; IEEE754 FLOAT CONVERT TO 4 BYTES FLOAT
; INPUT: ((R0))((R0)+1)((R0)+2)((R0)+3) IEEE-754 FLOAT
; OUTPUT: R4 R5R6R7 4 BYTES FLOAT
IEE_F:MOV A,@R0
JNZ CON_0
INC R0
MOV A,@R0
JNZ CON_1
INC R0
MOV A,@R0
JNZ CON_2
INC R0
MOV A,@R0
JNZ CON_3
MOV R4,#0
MOV R5,#0
MOV R6,#0
MOV R7,#0
DEC R0
DEC R0
DEC R0
RET
CON_3:DEC R0
CON_2:DEC R0
CON_1:DEC R0
CON_0:CLR FLAG_0
INC R0
MOV A,@R0
RLC A
MOV R5,A
DEC R0
MOV A,@R0
RLC A
MOV R4,A
JNC SA_IE
SETB FLAG_0
SA_IE: CLR C
MOV A,R4
SUBB A,#7FH
CLR C
INC A
MOV C,ACC.7
MOV ACC.6,C
MOV C,FLAG_0
MOV ACC.7,C
MOV R4,A
MOV A,R5
SETB C
RRC A
MOV R5,A
INC R0
INC R0
MOV A,@R0
MOV R6,A
INC R0
MOV A,@R0
MOV R7,A
DEC R0
DEC R0
DEC R0
RET
; 4 BYTES FLOAT CONVERT TO IEEE754 FLOAT
; INPUT: ((R0)) R2R3R4 4 BYTES FLOAT
; OUTPUT: ((R1)) ((R1)+1) ((R1)+2) ((R1)+3)
; IEEE-754 FLOAT
F_IEE:
INC R0
MOV A, @R0
MOV R2, A
INC R0
MOV A, @R0
MOV R3, A
INC R0
MOV A, @R0
MOV R4, A
DEC R0
DEC R0
DEC R0
MOV A,R2
JZ ZERO_IEE
MOV A,@R0
MOV C,ACC.7
MOV FLAG_0,C
CLR ACC.7
MOV C,ACC.6
JC F_FF
DEC A
CLR C
ADD A,#7FH
LJMP F_TR
F_FF: CLR C
SUBB A,#02H
F_TR: MOV C,FLAG_0
RRC A
MOV @R1,A
INC R1
MOV A,R2
MOV ACC.7,C
MOV @R1,A
INC R1
MOV A,R3
MOV @R1,A
INC R1
MOV A,R4
MOV @R1,A
FIEE_OFF:DEC R1
DEC R1
DEC R1
RET
ZERO_IEE:MOV @R1,A
INC R1
MOV @R1,A
INC R1
MOV @R1,A
INC R1
MOV @R1,A
SJMP FIEE_OFF
; 2 BYTE MUL
; 0.R2R3 * 0.R4R5→0.R2R3R7
D2_MUL: MOV A, R3
MOV B, R5
MUL AB
MOV R7, B
MOV A, R3
MOV B, R4
MUL AB
ADD A, R7
MOV R7, A
CLR A
ADDC A, B
MOV R3, A
MOV A, R2
MOV B, R5
MUL AB
ADD A, R7
MOV A, R3
ADDC A, B
MOV R3, A
MOV PSW.5, c
MOV A, R2
MOV B, R4
MUL AB
ADD A, R3
MOV R3, A
CLR A
ADDC A, B
MOV C, PSW.5
ADDC A, #0
MOV R2, A
RET
; 2 BYTE DIV
; 0.R2R3R7R6 / 0.R4R5→0.R2R3
; INPUT 0.R2R3 < 0.R4R5
D2_DIV: MOV A, R1
PUSH ACC
MOV B, #10H
A2O: CLR C
MOV A, R6
RLC A
MOV R6, A
MOV A, R7
RLC A
MOV R7, A
MOV A, R3
RLC A
MOV R3, A
XCH A, R2
RLC A
XCH A, R2
MOV PSW.5, C
CLR C
SUBB A, R5
MOV R1, A
MOV A, R2
SUBB A, R4
JB PSW.5, A2S
JC A2R
A2S: MOV R2, A
MOV A, R1
MOV R3, A
INC R6
A2R: DJNZ B, A2O
POP ACC
MOV R1, A
MOV A, R7
MOV R2, A
MOV A, R6
MOV R3, A
RET
; 3 BYTE FLOAT LOAD
; ((R0))→R6,((R0)+1)→R2,((R0)+2)→R3
; ((R1))→R7,((R1)+1)→R4,((R0)+2)→R5
F3_MLD: MOV A, @R0
MOV R6, A
INC R0
MOV A, @R0
MOV R2, A
INC R0
MOV A, @R0
MOV R3, A
DEC R0
DEC R0
MOV A, @R1
MOV R7, A
INC R1
MOV A, @R1
MOV R4, A
INC R1
MOV A, @R1
MOV R5, A
DEC R1
DEC R1
RET
; 3 BYTE FLOAT STANDED
F3_SDT: JC M3A
MOV C, FLAG39
JB PSW.5, M3B
MOV A, R2
RRC A
MOV R2, A
MOV A, R3
RRC A
MOV R3, A
INC R6
RET
M3B: MOV A, R4
RRC A
MOV R4, A
MOV A, R5
RRC A
MOV R5, A
INC R7
RET
M3A: MOV A, R2
JNZ M3C
CJNE R3, #0, M3D
MOV R6, #41H
M3E: RET
M3C: JB ACC.7, M3E
M3D: MOV C, PSW.5
MOV A, R3
RLC A
MOV R3, A
MOV A, R2
RLC A
MOV R2, A
CLR PSW.5
DEC R6
SJMP M3A
RET
; 3 BYTE FLOAT ADD OR SUB
; R6R2R3 + R7R4R5→R4R2R3
; R6R2R3 - R7R4R5→R4R2R3
; FLAG3A = 0 ADD FLAG3A = 1 SUB
F3_ABP: MOV A, R6
MOV C, ACC.7
MOV FLAG38, C
XRL A, R7
JNB ACC.7, SQ
CPL FLAG3A
MOV A, R6
MOV C, ACC.6
MOV ACC.7, C
MOV R6, A
MOV A, R7
MOV C, ACC.6
MOV ACC.7, C
MOV R7, A
SQ: CLR C
MOV A, R6
SUBB A, R7
JZ ST
CLR PSW.5
CLR FLAG39
JB ACC.7, SW
CJNE R4, #00H, SE
CJNE R5, #00H, SE
ST: JB FLAG3A, SY
MOV A, R3
ADD A, R5
MOV R3, A
MOV A, R2
ADDC A, R4
MOV R2, A
JNC SD
SETB FLAG39
CLR C
SF: CLR PSW.5
LCALL F3_SDT
SD: MOV A, R6
MOV C, FLAG38
MOV ACC.7, C
XCH A, R4
MOV R6, A
RET
SW: CJNE R2, #00H, SF
CJNE R3, #00H, SF
MOV A, R7
MOV R6, A
SJMP ST
SE: CPL PSW.5
CLR C
LCALL F3_SDT
SJMP SQ
SY: MOV A, R3
CLR C
SUBB A, R5
MOV R3, A
MOV A, R2
SUBB A, R4
MOV R2, A
JNC SL
CLR A
CLR C
SUBB A, R3
MOV R3, A
CLR A
SUBB A, R2
MOV R2, A
CPL FLAG38
SL: SETB C
SJMP SF
;3 BYTE FLOAT ADD
; ((R0))((R0)+1)((R0)+2) + ((R1))((R1)+1)
; ((R1)+2)→R4R2R3
; FLAG3A = 0
F3_ADD: CLR FLAG3A
LCALL F3_MLD
LCALL F3_ABP
RET
; 3 BYTE SUB
; ((R0))((R0)+1)((R0)+2) -
; ((R1))((R1)+1)((R1)+2)→R4R2R3
; FLAG3A = 1
F3_SUB: SETB FLAG3A
LCALL F3_MLD
LCALL F3_ABP
RET
; 3 BYTE FLOAT MUL
; ((R0))((R0)+1)((R0)+2) *
F3_MUL: LCALL F3_MLD
MOV A, R6
XRL A, R7
MOV C, ACC.7
MOV FLAG38, C
LCALL D2_MUL
MOV A, R7
MOV C, ACC.7
MOV PSW.5, C
MOV A, @R0
ADD A, @R1
MOV R6, A
SETB C
LCALL F3_SDT
MOV A, R6
MOV C, FLAG38
MOV ACC.7, C
MOV R4, A
RET
; 3 BYTE FLOAT DIV
; ((R0))((R0)+1)((R0)+2) /
; ((R1))((R1)+1)((R1)+2)→R4(阶)R2R3
; C = 0 NORMAL ,C = 1 DIV BY 0
F3_DIV: LCALL F3_MLD
MOV A, R6
XRL A, R7
MOV C, ACC.7
MOV FLAG38, C
CLR A
MOV R6, A
MOV R7, A
CJNE R4, #00H, TY
CJNE R5, #00H, TY
SETB C
RET
TY: MOV A, R3
SUBB A, R5
MOV A, R2
SUBB A, R4
JC TU
CLR PSW.5
CLR FLAG39
LCALL F3_SDT
MOV A, R7
RRC A
MOV R7, A
CLR C
SJMP TY
TU: CLR A
XCH A, R6
PUSH ACC
LCALL D2_DIV
POP ACC
ADD A, @R0
CLR C
SUBB A, @R1
MOV C, FLAG38
MOV ACC.7, C
MOV R4, A
CLR C
RET
; 3BYTE FLOAT STORE
; R4R2R3 TO (R1)(R1+1)(R1+2)
F3_STR: MOV A, R4
MOV @R1, A
INC R1
MOV A, R2
MOV @R1, A
INC R1
MOV A, R3
MOV @R1, A
DEC R1
DEC R1
RET
; 3 BYTE FLOAT SQRT
; F0 = 0 NORMAL ,F0 = 1 ERROR
F3_SQRT:MOV A, @R0
JB ACC.7, BV
MOV @R1, A
INC R0
INC R1
MOV A, @R0
MOV @R1, A
INC R0
INC R1
MOV A, @R0
MOV @R1, A
DEC R0
DEC R0
DEC R1
DEC R1
BM: LCALL F3_DIV
MOV R6, A
MOV A, @R1
MOV R7, A
INC R1
MOV A, @R1
MOV R4, A
INC R1
MOV A, @R1
MOV R5, A
DEC R1
DEC R1
CLR FLAG3A
LCALL F3_ABP
DEC R4
CLR PSW.5
MOV A, R4
MOV B, R7
CJNE A, B, BN
MOV A, R5
SUBB A, R3
ANL A, #0FCH
MOV R7, A
MOV A, R6
SUBB A, R2
JNZ BN
CJNE R7, #00H, BN
SETB PSW.5
BN: LCALL F3_STR
JNB PSW.5, BM
RET
BV: CLR PSW.5
RET
; 3 BYTE BIN TO 4 BYTE FLOAT
; INPUT ADDRESS (R0),OUTPUT ADDRESS (R1)
F3_BTF:MOV A, #10H
MOV R2, A
MOV A, @R0
MOV R3, A
INC R0
MOV A, @R0
MOV R4, A
DEC R0
MOV A, R3
ORL A, R4
JNZ FRLN1
MOV R2, A
MOV R3, A
MOV R4, A
JMP FRLN2
FRLN1: MOV A, R3
JB ACC.7, FRLN2
LCALL FRL1
SJMP FRLN1
FRLN2: INC R1
INC R1
MOV A, R4
MOV @R1, A
DEC R1
MOV A, R3
MOV @R1, A
DEC R1
MOV A, R2
CLR ACC.7
CLR ACC.6
MOV @R1, A
RET
FRL1: CLR C
MOV A, R4
RLC A
MOV R4, A
MOV A, R3
RLC A
MOV R3, A
DEC R2
MOV A, R2
XRL A, #0C0H
JNZ FRL1E
MOV R2, A
MOV R3, A
MOV R4, A
FRL1E: RET
; 3 BYTE FLOAT BIN TO DEC
; INPUT DATA: FLAG3E = 0 1 <= DATA < 10
; FLAG3E = 1 FLAG3F = 0 0.2 <= DATA < 2
; FLAG3E = 1 FLAG3F = 1 0.4 <= DATA < 4
F3_BTD: MOV A, @R0
MOV C, ACC.7
MOV FLAG3C, C
MOV C, ACC.6
MOV ACC.7, C
MOV R6, A
INC R0
MOV A, @R0
MOV R2, A
INC R0
MOV A, @R0
MOV R3, A
DEC R0
DEC R0
CJNE R2, #00H, PA
CJNE R3, #00H, PA
CLR A
MOV @R1, A
INC R1
MOV @R1, A
INC R1
MOV @R1, A
INC R1
MOV @R1, A
INC R1
MOV @R1, A
INC R1
MOV @R1, A
PL: DEC R1
DEC R1
DEC R1
DEC R1
DEC R1
RET
PA: MOV @R1, #00H
JB FLAG3E, PB
DEC @R1
PB: INC R1
MOV @R1, #01H
JNB FLAG3E, PD
INC @R1
JNB FLAG3F, PD
INC @R1
PD: MOV A, R6
CLR C
SUBB A, @R1
JZ PX
JNB ACC.6, PE
PM: DEC @R1
DEC @R1
DEC @R1
DEC @R1
PZ: MOV A, R6
CLR C
SUBB A, @R1
JZ PY
JB ACC.6, PF
PQ: JNB FLAG3E, PG
DEC R6
JNB FLAG3F, PG
DEC R6
PG: CJNE R6, #00H, PH
MOV R6, #05H
JNB FLAG3E, PI
MOV R7, #01H
JNB FLAG3F, PJ
INC R7
PJ: CLR A
CLR C
PK: XCH A, R3
RLC A
XCH A, R3
XCH A, R2
RLC A
XCH A, R2
RLC A
DJNZ R7, PK
DEC R6
MOV @R1, A
INC R1
PI: MOV A, R3
MOV B, #0AH
MUL AB
MOV R3, A
MOV R7,B
MOV A, R2
MOV B, #0AH
MUL AB
ADD A, R7
MOV R2, A
CLR A
ADDC A, B
MOV @R1, A
INC R1
DJNZ R6, PI
SJMP PL
PX: MOV A, R2
SUBB A, #80H
JC PM
PE: MOV R5, #0CDH
MOV R4, #0CCH
LCALL D2_MUL
MOV A, R2
JB ACC.7, PN
MOV A, R7
MOV C, ACC.7
ORL C, ACC.6
MOV A, R3
RLC A
MOV R3, A
MOV A, R2
RLC A
MOV R2, A
DEC R6
PT: MOV A, R6
ADD A, #0FDH
MOV R6, A
DEC R1
INC @R1
INC R1
SJMP PD
TPS: SJMP PZ
PH: MOV A, R2
RRC A
MOV R2, A
MOV A, R3
RRC A
MOV R3, A
INC R6
SJMP PG
PY: MOV A, #0CBH
CLR C
SUBB A, R3
MOV A, #0CCH
SUBB A, R2
JC PQ
PF: MOV R4, #0A0H
MOV R5, #00H
LCALL D2_MUL
MOV A, R2
JB ACC.7, PR
MOV A, R7
MOV C, ACC.7
ORL C, ACC.6
MOV A, R3
RLC A
MOV R3, A
MOV A, R2
RLC A
MOV R2, A
DEC R6
PU: MOV A, R6
ADD A, #04H
MOV R6, A
DEC R1
DEC @R1
INC R1
SJMP TPS
PN: MOV A, R7
JNB ACC.7, PT
MOV A, R3
ORL A, #01H
MOV R3, A
SJMP PT
PR: MOV A, R7
JNB ACC.7, PU
MOV A, R3
ORL A, #01H
MOV R3, A
SJMP PU
; 4 BITE FLOAT MUL
;((R0))((R0)+1)((R0)+2)((R0)+3)*
; ((R1))((R1)+1)((R1)+2)((R1)+3)
; TO R4R5R6R7
F4_MUL: LCALL F4_LD
INC R1
MOV A, R0
PUSH ACC
LCALL D3_MUL
POP ACC
MOV R0, A
DEC R1
MOV A, R2
MOV C, ACC.7
MOV PSW.5, C
MOV A, @R0
XRL A, @R1
MOV C, ACC.7
MOV FLAG38, C
MOV A, @R0
ADD A, @R1
XCH A, R0
PUSH ACC
SETB C
LCALL F4_STD
POP ACC
XCH A, R0
MOV C, FLAG38
MOV ACC.7, C
MOV R4, A
RET
; 4 BITE FLOAT DIV
;((R0))((R0)+1)((R0)+2)((R0)+3)/
; TO R4R5R6R7,
; C=0 NORMAL, C=1 DIV BY 0
F4_DIV: LCALL F4_LD
MOV A, @R0
XRL A, @R1
MOV C, ACC.7
MOV FLAG38, C
CLR A
MOV R5, A
MOV R6, A
MOV R7, A
INC R1
CJNE @R1, #00H, L4A
INC R1
CJNE @R1, #00H, L4B
INC R1
CJNE @R1, #00H, L4C
DEC R1
DEC R1
DEC R1
SETB C
RET
L4C: DEC R1
L4B: DEC R1
L4A: DEC R1
MOV A, @R0
XCH A, R0
INC R1
PUSH ACC
L4E: MOV A, R4
INC R1
INC R1
SUBB A, @R1
MOV A, R3
DEC R1
SUBB A, @R1
MOV A, R2
DEC R1
SUBB A, @R1
JC L4D
CLR PSW.5
CLR FLAG39
LCALL F4_STD
MOV A, R5
RRC A
MOV R5, A
CLR C
SJMP L4E
L4D: MOV A, R0
PUSH ACC
LCALL D3_DIV
POP ACC
DEC R1
XCH A, R0
POP ACC
XCH A, R0
CLR C
SUBB A, @R1
MOV C, FLAG38
MOV ACC.7, C
MOV R4, A
CLR C
RET
; 4 BITE FLOAT LOAD
; ((R0)+1)((R0)+2)((R0)+3) TO R2R3R4
F4_LD: INC R0
MOV A, @R0
MOV R2, A
INC R0
MOV A, @R0
MOV R3, A
INC R0
MOV A, @R0
MOV R4, A
DEC R0
DEC R0
DEC R0
RET
; 4 BITE FLOAT ADD OR SUB
; ((R0))(R2)(R3)(R4) + ((R1))((R1)+1)((R1)+2)
; ((R1)+3) TO R4R5R6R7
; ((R0))(R2)(R3)(R4) - ((R1))((R1)+1)((R1)+2)
; FLAG3A=0 ADD, FLAG3A=1 SUB
F4_AB: INC R1
MOV A, @R1
MOV R5, A
INC R1
MOV A, @R1
MOV R6, A
INC R1
MOV A, @R1
MOV R7, A
DEC R1
DEC R1
DEC R1
MOV A, @R0
MOV C, ACC.7
MOV FLAG38, C
XRL A, @R1
JNB ACC.7, F4_ABT
CPL FLAG3A
F4_ABT:MOV A, R0
PUSH ACC
MOV A, @R0
MOV C, ACC.6
MOV ACC.7, C
MOV R0, A
MOV A, R1
PUSH ACC
MOV A, @R1
MOV C, ACC.6
MOV ACC.7, C
MOV R1, A
F4_SDT1:CLR C
MOV A, R0
SUBB A, R1
JZ F4_ABTI
CLR PSW.5
CLR FLAG39
JB ACC.7, F4_ABX
CJNE R5, #00H, F4_ABG
CJNE R6, #00H, F4_ABG
CJNE R7, #00H, F4_ABG
MOV A, R0
MOV R1, A
F4_ABTI:JB FLAG3A, F4_ABS
MOV A, R4
ADD A, R7
MOV R7, A
MOV A, R3
ADDC A, R6
MOV R6, A
MOV A, R2
ADDC A, R5
MOV R5, A
JNC F4_ABA
SETB FLAG39
CLR C
SETB PSW.5
F4_ABL: LCALL F4_STD
MOV A, R1
MOV R0, A
F4_ABA: POP ACC
MOV R1, A
POP ACC
XCH A, R0
MOV C, FLAG38
MOV ACC.7, C
XCH A, R4
RET
F4_ABX: CJNE R2, #00H, F4_ABG1
CJNE R3, #00H, F4_ABG1
CJNE R4, #00H, F4_ABG1
MOV A, R1
MOV R0, A
SJMP F4_ABTI
F4_ABG: CPL PSW.5
F4_ABG1:CLR C
LCALL F4_STD
SJMP F4_SDT1
F4_ABS: CLR C
MOV A, R4
SUBB A, R7
MOV R7, A
MOV A, R3
SUBB A, R6
MOV R6, A
MOV A, R2
SUBB A, R5
MOV R5, A
JNC F4_ABS1
CLR A
CLR C
SUBB A, R7
MOV R7, A
CLR A
SUBB A, R6
MOV R6, A
CLR A
SUBB A, R5
MOV R5, A
CPL FLAG38
F4_ABS1:SETB C
CLR PSW.5
LCALL F4_STD
SJMP F4_ABA
; 4 BITE FLOAT ADD
; FLAG3A=0 ADD
F4_ADD: CLR FLAG3A
LCALL F4_LD
LCALL F4_AB
RET
; 4 BITE FLOAT SUB
; FLAG3A=1 SUB
F4_SUB: SETB FLAG3A
LCALL F4_LD
LCALL F4_AB
RET
; 4 BITE FLOAT STANDED
; F0=0 R0R2R3R4
; F0=1 R1R5R6R7
F4_STD: JC F4A
MOV C, FLAG39
JB PSW.5, F4B
MOV A, R2
RRC A
MOV R2, A
MOV A, R3
RRC A
MOV R3, A
MOV A, R4
RRC A
MOV R4, A
INC R0
RET
F4B: MOV A, R5
RRC A
MOV R5, A
MOV A, R6
RRC A
MOV R6, A
MOV A, R7
RRC A
MOV R7, A
INC R1
RET
F4A: MOV A, R5
JNZ F4C
CJNE R6, #00H, F4D
CJNE R7, #00H, F4D
F4E: RET
F4C: JB ACC.7, F4E ; 0E7H
F4D: MOV C, PSW.5
MOV A, R7
RLC A
MOV R7, A
MOV A, R6
RLC A
MOV R6, A
MOV A, R5
RLC A
MOV R5, A
CLR PSW.5
DEC R0
SJMP F4A
; 4 BYTE FLOAT STORE
; R4R5R6R7 TO (R0)(R0+1)(R0+2)(R0+3)
F4_STR: MOV A, R4
MOV @R0, A
INC R0
MOV A, R5
MOV @R0, A
INC R0
MOV A, R6
MOV @R0, A
INC R0
MOV A, R7
MOV @R0, A
DEC R0
DEC R0
DEC R0
RET
; 3 BYTE DIV
; 0.R2R3R4R5R6R7 / ((R1))((R1)+1)((R1)+2)
; TO (R0)(R0+1)(R0+2)(R0+3)
D3_DIV: MOV R0, #18H
INC R1
INC R1
S3D: CLR C
MOV A, R7
RLC A
MOV R7, A
MOV A, R6
RLC A
MOV R6, A
MOV A, R5
RLC A
MOV R5, A
MOV A, R4
RLC A
MOV R4, A
XCH A, R3
RLC A
XCH A, R3
XCH A, R2
RLC A
XCH A, R2
MOV PSW.5, C
CLR C
SUBB A, @R1
DEC R1
MOV A, R3
SUBB A, @R1
DEC R1
MOV B, A
MOV A, R2
SUBB A, @R1
INC R1
INC R1
JB PSW.5, S3A
JC S3B
S3A: CLR C
MOV R2, A
MOV A, R4
SUBB A, @R1
MOV R4, A
MOV R3, B
INC R7
S3B: DJNZ R0, S3D
DEC R1
DEC R1
RET
; 3 BYTE MUL
; 0.R2R3R4 * 0.((R1))((R1)+1)((R1)+2)
; TO R5R6R2R3R4
D3_MUL: MOV R0, #19H
CLR C
CLR A
MOV R5, A
MOV R6, A
MOV R7, A
K3B: MOV A, R5
RRC A
MOV R5, A
MOV A, R6
RRC A
MOV R6, A
MOV A, R7
RRC A
MOV R7, A
XCH A, R2
RRC A
XCH A, R2
XCH A, R3
RRC A
XCH A, R3
XCH A, R4
RRC A
XCH A, R4
DJNZ R0, K3A
RET
K3A: JNC K3B
INC R1
INC R1
ADD A, @R1
MOV R7, A
MOV A, R6
DEC R1
ADDC A, @R1
MOV R6, A
MOV A, R5
DEC R1
ADDC A, @R1
MOV R5, A
SJMP K3B
; 功能:以e为底的浮点指数函数
;入口条件:操作数在TMP0中。使用TMP0,TMP1,TMP2
;出口信息:OV=0时,结果仍在TMP0中,OV=1时,溢出。
;影响资源:DPTR、PSW、A、B、R2~R7、位1EH、1FH 堆栈需求:6字节
F4_EXP:
MOV R1, #TMP1
MOV A, #01H ; e(x) = 2(1.442695 * x)
MOV @R1, A
INC R1
MOV A, #0B8H
MOV @R1, A
INC R1
MOV A, #0AAH
MOV @R1, A
INC R1
MOV A, #3BH
MOV @R1, A
MOV R0, #TMP0
MOV R1, #TMP1
LCALL F4_MUL ;进行加权运算
MOV R0, #TMP0
LCALL F4_STR
E20:
MOV R0, #TMP0
MOV A, @R0
MOV R4, A
INC R0
MOV A, @R0
MOV R5, A
INC R0
MOV A, @R0
MOV R6, A
INC R0
MOV A, @R0
MOV R7, A
MOV A, R5
ORL A, R6
ORL A, R7
JNZ EXP2
EXP1:
MOV R4, #01H ;尾数为零,幂为1.000000
MOV R5, #80H
MOV R6, #00H
MOV R7, #00H
CLR OV
RET
EXP2:
MOV R0, #TMP0
MOV A, @R0
MOV R4, A ;将指数复制到工作区
INC R0
MOV A, @R0
MOV R5, A
INC R0
MOV A, @R0
MOV R6, A
INC R0
MOV A, @R0
MOV R7, A
LCALL INT
EXP4:
MOV A, R4
JB ACC.6, EXP5
CLR ACC.7
MOV R0, A
CLR C
MOV R1, #00H
MOV A, R5
PUSH ACC
EXPJ1: MOV A, R5
RLC A
MOV R5, A
MOV A, R1
RLC A
MOV R1, A
DJNZ R0, EXPJ1
POP ACC
MOV R5, A
MOV A, R4
JB ACC.7, EXPJ2
MOV A, R1
SJMP EXP6
EXPJ2: MOV A, R1
CPL A
INC A
SJMP EXP6
EXP5: MOV A, #00H
EXP6: PUSH ACC ;暂时保存之
MOV R0, #TMP1
LCALL F4_STR
MOV R0, #TMP0
MOV R1, #TMP1
LCALL F4_SUB ;求指数的小数部分
MOV R0, #TMP0
LCALL F4_STR
PUSH DPH
PUSH DPL
MOV DPTR, #EXP_TABL
MOV TMP2, #41H
MOV TMP2+1, #00H
MOV TMP2+2, #00H
MOV TMP2+3, #00H
PLN1: CLR A ;计算指数的小数部分的幂
MOV R0, #TMP1
MOVC A, @A+DPTR
MOV @R0, A
INC DPTR
INC R0
CLR A
MOVC A, @A+DPTR
MOV @R0, A
INC DPTR
INC R0
CLR A
MOVC A, @A+DPTR
MOV @R0, A
INC DPTR
INC R0
CLR A
MOVC A, @A+DPTR
MOV @R0, A
INC DPTR ;指向下一个系数
MOV R0, #TMP2
MOV R1, #TMP1
LCALL F4_ADD ;进行代数加法运算
MOV R0, #TMP2
LCALL F4_STR
CLR A ;读取下一个系数的第一个字节
MOVC A, @A+DPTR
CJNE A, #40H, PLN2;是结束标志吗?
POP DPL
POP DPH
POP ACC ;取出指数的整数部分
ADD A, R4 ;按补码加到幂的阶码上
MOV R4, A
MOV A, R4
CLR ACC.7 ;幂的符号为正
MOV R4, A
RET
PLN2:
MOV R0, #TMP0
MOV R1, #TMP2
LCALL F4_MUL ;进行乘法运算
MOV R0, #TMP2
LCALL F4_STR
LJMP PLN1 ;继续下一项运算
EXP_TABL:
DB 77H, 0B1H, 0C9H, 00H ; 1.3564 * 10(-3)
DB 7AH, 0A1H, 68H, 00H ; 9.8514 * 10(-3)
DB 7CH, 0E3H, 4FH, 00H ; 0.055495
DB 7EH, 0F5H, 0E7H, 00H ; 0.24014
DB 00H, 0B1H, 72H, 00H ; 0.69315
DB 01H, 80H, 00H, 00H ; 1.000000
DB 40H, 40H, 40H, 40H ;结束
; (R4)R5R6R7
RLN: MOV A, R5 ;浮点数规格化
ORL A, R6 ;尾数为零否?
ORL A, R7
JNZ RLN1
MOV R4, #0C1H ;阶码取最小值
RET
RLN1: MOV A, R5
JB ACC.7, RLN2 ;尾数最高位为一否?
CLR C ;不为一,左规一次
LCALL RL1
SJMP RLN ;继续判断
RLN2: CLR OV ;规格化结束
RET
RL1: MOV A, R7 ;第一操作数左规一次
RLC A ;尾数扩大一倍
MOV R7, A
MOV A, R6
RLC A
MOV R6, A
MOV A, R5
RLC A
MOV R5, A
DEC R4 ;阶码减一
CJNE R4, #0C0H, RL1E ;阶码下溢否?
CLR A
MOV R5, A ;阶码下溢,操作数以零计
MOV R6, A
MOV R7, A
MOV R4, #0C1H
RL1E: CLR OV
RET
RR1: MOV A, R5 ;第一操作数右规一次
RRC A ;尾数缩小一半
MOV R5, A
MOV A, R6
RRC A
MOV R6, A
MOV A, R7
RRC A
MOV R7, A
INC R4 ;阶码加一
CLR OV ;清溢出标志
CJNE R4, #40H, RR1E ;阶码上溢否?
MOV R4, #3FH ;阶码溢出
SETB OV
RR1E: RET
; 功能:浮点取整函数
;入口条件:操作数在[R0]中。
;出口信息:R4R5R6R7
FINT:
MOV A, @R0
MOV R4, A ;阶存放在R4中
INC R0
MOV A, @R0 ;将尾数高字节存放在R5中
MOV R5, A
INC R0
MOV A, @R0 ;将尾数第二字节存放在R6中
MOV R4, A
INC R0
MOV A, @R0 ;将尾数第三字节存放在R7中
MOV R7, A
DEC R0 ;恢复数据指针
DEC R0
DEC R0
LCALL INT ;在工作寄存器中完成取整运算
RET
INT: MOV A, R5
ORL A, R6
ORL A, R7
JNZ INTA
MOV R4, #41H ;尾数为零,阶码也清零,结束取整
RET
INTA: MOV A, R4
CLR ACC.7
JZ INTB ;阶码为零否?
JB ACC.6, INTB;阶符为负否?
CLR ACC.6
CLR C
SUBB A, #18H ;阶码小于24否?
JC INTD
RET ;阶码大于24,已经是整数
INTB: CLR A ;绝对值小于一,取整后正数为零,负数为负一
MOV R7, A
MOV R6, A
MOV R5, A
MOV R4, #41H
INTC: RET
INTD: CLR F0 ;舍尾标志初始化
MOV A, R4
CLR ACC.7
MOV R0, A
CLR A
MOV R1, A
MOV R2, A
MOV R3, A
CLR C
INTE:
MOV A, R7
RLC A
MOV R7, A
MOV A, R6
RLC A
MOV R6, A
MOV A, R5
RLC A
MOV R5, A
MOV A, R3
RLC A
MOV R3, A
MOV A, R2
RLC A
MOV R2, A
MOV A, R1
RLC A
MOV R1, A
DJNZ R0, INTE ;阶码
MOV A, R4
CLR ACC.7
MOV R0, A
MOV A, #18H
CLR C
SUBB A, R0
MOV R0, A
INTF: CLR C
MOV A, R3
RLC A
MOV R3, A
MOV A, R2
RLC A
MOV R2, A
MOV A, R1
RLC A
MOV R1, A
DJNZ R0, INTF
MOV A, R3
MOV R7, A
MOV A, R2
MOV R6, A
MOV A, R1
MOV R5, A
RET
