官方代码
#include
int main(void)
WDTCTL = WDTPW +WDTHOLD; // Stop Watchdog Timer
DCOCTL = DCO0 + DCO1 + DCO2; // Max DCO
BCSCTL1 = RSEL0 + RSEL1 + RSEL2; // XT2on, max RSEL
BCSCTL2 |= SELS; // SMCLK = XT2
P5DIR |= 0x70; // P5.6,5,4 outputs
P5SEL |= 0x70; // P5.6,5,5 options
while(1)
自己写
#include "MSP430x14x.h"
int main( void )
// Stop watchdog timer to prevent time out reset
WDTCTL = WDTPW + WDTHOLD;
/*DCO frequency select. */
DCOCTL |=(BIT5+BIT6+BIT7);//=7;
BCSCTL1 |= (RSEL0+RSEL1+RSEL2);//DCO MAX;
/*ACLK*/
//BCSCTL1 &= ~XTS; //因为默认是0,所以可以不用设置;
//BCSCTL1 &= ~(DIVA0+DIVA1);
/*SMCLK*/
BCSCTL1 &= ~XT2OFF; //因为默认是1,所以置1;
BCSCTL2 &= ~SELS; //1:外部时钟;0:DCO
BCSCTL2 |= DIVS_1; //2分频
/*MCLK*/
BCSCTL2 |= SELM_0; //选择主系统的时钟源
BCSCTL2 |= DIVM_0; //1分频
/*Oscillator fault interrupt enable*/
__enable_interrupt(); //开启中断;
// IE1 |= OFIE; //中断使能;这个不能置一,不知道为啥,置一就有问题,官方提供的例子也没有使OFIE置一,感觉好奇怪
do
IFG1 &= ~OFIFG; //中断标志位清零
/*DELAY*/
__no_operation();
while(IFG1&OFIFG); //没有振荡器置位则跳出循环
for(;;);
