单片机 > 单片机程序设计 > 详情
nRF24L01 AVR 发送接收驱动程序
发布时间:2020-05-16 发布时间:
#include
#include
#include "12864.h"
  智芯锐电子技术社区:http://www.zhixinrui.com
//spi标志
#define DDR_SPI DDRB
#define DD_MOSI 5
#define DD_MISO 6
#define DD_SCK 7
#define DD_SS 4
#define CE PB3
#define IRQ PB2
//--------------------------------NRF24L01接口定义--------------------------------
//#define NRF24L01_MISO          PB6  //输入0
#define   Hign_24L01_MISO    PORTB|=(1 << PB6)
#define   Low_24L01_MISO     PORTB &= ~(1 << PB6)
#define   Read_24L01_MISO    PINB & (1 << PB6)
//#define NRF24L01_MOSI         PB5       //输出1
#define   Hign_24L01_MOSI    PORTB |= (1 << PB5)
#define   Low_24L01_MOSI     PORTB &= ~(1 << PB5)
#define   Read_24L01_MOSI    PINB & (1 << PB5)
//#define NRF24L01_SCK    PB7      //输出1
#define   Hign_24L01_SCK    PORTB |= (1 << PB7)
#define   Low_24L01_SCK     PORTB &= ~(1 << PB7)
#define   Read_24L01_SCK    PINB & (1 << PB7);
//#define NRF24L01_CSN       PB4       //输出1
#define   Low_24L01_CSN     PORTB &= ~(1 << PB4)
#define   Hign_24L01_CSN    PORTB |= (1 << PB4)
//#define NRF24L01_CE         PB3       //输出1
#define   Hign_24L01_CE    PORTB |= (1 << PB3)
#define   Low_24L01_CE     PORTB &= ~(1 << PB3)
#define   Read_24L01_CE    PINB & (1 << PB3)
//*********************************************NRF24L01*************************************
#define TX_ADR_WIDTH    5       // 发送地址长度,最大长度为5 5*8=40 bit
#define RX_ADR_WIDTH    5       // 接收地址长度
#define TX_PLOAD_WIDTH  32      // 发送字节长度,
#define RX_PLOAD_WIDTH  32      // 接收字节长度
 uchar TX_ADDRESS[TX_ADR_WIDTH]={0x34,0x43,0x10,0x10,0x01};  //发送地址
 uchar RX_ADDRESS[RX_ADR_WIDTH]={0x34,0x43,0x10,0x10,0x01}; //接收地址
//***************************************NRF24L01寄存器指令*******************************************************
#define READ_REG        0x00    // 读寄存器指令
#define WRITE_REG       0x20    // 写寄存器指令
#define RD_RX_PLOAD     0x61    // 读取接收数据指令
#define WR_TX_PLOAD     0xA0    // 写待发数据指令
#define FLUSH_TX        0xE1    // 冲洗发送 FIFO指令
#define FLUSH_RX        0xE2    // 冲洗接收 FIFO指令
#define REUSE_TX_PL     0xE3    // 定义重复装载数据指令
#define NOP             0xFF    // 保留
//*************************************SPI(nRF24L01)寄存器地址****************************************************
#define CONFIG          0x00  // 配置收发状态,CRC校验模式以及收发状态响应方式
#define EN_AA           0x01  // 自动应答功能设置
#define EN_RXADDR       0x02  // 可用信道设置
#define SETUP_AW        0x03  // 收发地址宽度设置
#define SETUP_RETR      0x04  // 自动重发功能设置
#define RF_CH           0x05  // 工作频率设置
#define RF_SETUP        0x06  // 发射速率、功耗功能设置
#define STATUS          0x07  // 状态寄存器
#define OBSERVE_TX      0x08  // 发送监测功能
#define CD              0x09  // 地址检测
#define RX_ADDR_P0      0x0A  // 频道0接收数据地址
#define RX_ADDR_P1      0x0B  // 频道1接收数据地址
#define RX_ADDR_P2      0x0C  // 频道2接收数据地址
#define RX_ADDR_P3      0x0D  // 频道3接收数据地址
#define RX_ADDR_P4      0x0E  // 频道4接收数据地址
#define RX_ADDR_P5      0x0F  // 频道5接收数据地址
#define TX_ADDR         0x10  // 发送地址寄存器
#define RX_PW_P0        0x11  // 接收频道0接收数据长度
#define RX_PW_P1        0x12  // 接收频道0接收数据长度
#define RX_PW_P2        0x13  // 接收频道0接收数据长度
#define RX_PW_P3        0x14  // 接收频道0接收数据长度
#define RX_PW_P4        0x15  // 接收频道0接收数据长度
#define RX_PW_P5        0x16  // 接收频道0接收数据长度
#define FIFO_STATUS     0x17  // FIFO栈入栈出状态寄存器设置
//*******  void spi_init()  初始化SPI
void spi_init()
 Hign_24L01_CSN;
 DDR_SPI = (1<
 DDR_SPI&=~((1<
 SPCR=(1<
 SPSR=0;
//*******  uchar SPI_RW(uchar date)  读写SPI
 SPDR=date;
    while(!(SPSR&(1<
    return SPDR;
//*******uchar SPI_Read(uchar reg)  读24L01寄存器
 uchar reg_val;
 Low_24L01_CSN;
 SPI_RW(reg);
 reg_val = SPI_RW(0);
 Hign_24L01_CSN;
 return(reg_val);
//*******  uchar SPI_RW_Reg(uchar reg, uchar value)
//          写24L01寄存器
 uchar status;
 Low_24L01_CSN;
 status = SPI_RW(reg);
 SPI_RW(value);
 Hign_24L01_CSN;
 return(status);
//*******  uchar SPI_Read_Buf(uchar reg, uchar *pBuf, uchar bites)
//          读24L01 寄存器BUFF
 uint status1,uchar_ctr;
 Low_24L01_CSN;
 status1 = SPI_RW(reg);
 for(uchar_ctr=0;uchar_ctr
  pBuf[uchar_ctr] = SPI_RW(0);
 Hign_24L01_CSN;
 return(status1);
//*******  uchar SPI_Write_Buf(uchar reg, uchar *pBuf, uchar bites)
//          写24L01 寄存器BUFF
 uchar status1,uchar_ctr;
 Low_24L01_CSN;             //SPI使能
 for(uchar_ctr=0; uchar_ctr
 SPI_RW(*pBuf++);
 Hign_24L01_CSN;           //关闭SPI
 return(status1);        //
//*******  void SetRX_Mode(void)
//          接收模式设置
 Low_24L01_CE;
 SPI_Write_Buf(WRITE_REG + RX_ADDR_P0, RX_ADDRESS, RX_ADR_WIDTH); //写接收地址
 SPI_RW_Reg(WRITE_REG + EN_AA, 0x01);      //0通道自动应答
 SPI_RW_Reg(WRITE_REG + EN_RXADDR, 0x01);  //数据通道0
 SPI_RW_Reg(WRITE_REG + RF_CH,0);        //射频通道
 SPI_RW_Reg(WRITE_REG + RX_PW_P0, RX_PLOAD_WIDTH);//写通道0 接受数据长度
 SPI_RW_Reg(WRITE_REG + RF_SETUP, 0x07); //0db 1M
 SPI_RW_Reg(WRITE_REG + CONFIG, 0x0f); //接收模式
 Hign_24L01_CE;        //开始接收
 delayus(200);//注意不能太小
//*******  uchar nRF24L01_RxPacket(uchar* rx_buf)
//          接收数据包
    uchar sta,flag=0;
    sta=SPI_Read(STATUS);      // 读取状态寄存其来判断数据接收状况
    if(sta&0x40)                 // 判断是否接收到数据RX_DR==1?
       Low_24L01_CE;   // StandBy I模式
       SPI_Read_Buf(RD_RX_PLOAD,rx_buf,TX_PLOAD_WIDTH);// read receive payload from RX_FIFO buffer
       flag =1;   //读取数据完成标志
    SPI_RW_Reg(WRITE_REG+STATUS,sta);   //接收到数据后RX_DR,TX_DS,MAX_PT都置高为1,通过写1来清楚中断标志
    return (flag);
//*******  void nRF24L01_TxPacket(uchar * tx_buf)
//          发送数据包
void nRF24L01_TxPacket(  uchar * tx_buf)
   uchar sta=0;
   uchar flag=0;
   Low_24L01_CE;   //StandBy I模式
   SPI_Write_Buf(WRITE_REG + TX_ADDR, TX_ADDRESS, TX_ADR_WIDTH);
   SPI_Write_Buf(WRITE_REG + RX_ADDR_P0, TX_ADDRESS, TX_ADR_WIDTH); // 装载接收端地址
   SPI_Write_Buf(WR_TX_PLOAD, tx_buf, TX_PLOAD_WIDTH);     // 装载数据
   SPI_RW_Reg(WRITE_REG + SETUP_RETR, 0x1f); //500+86us
   SPI_RW_Reg(WRITE_REG + RF_CH, 0);        //
   SPI_RW_Reg(WRITE_REG + CONFIG, 0x0e);      // IRQ收发完成中断响应,16位CRC,主发送
   delayms(2);
   Hign_24L01_CE;   //置高CE,激发数据发送
   delayus(10);
   Low_24L01_CE;
void init_NRF24L01(void)
  spi_init();
  Low_24L01_CE;    // 空闲模式
  Hign_24L01_CSN;   // SPI 关闭
  Low_24L01_SCK;   // 关闭时钟
51单片机中断源的扩展方法
