//此子程序用于PIC系列单片机和铁电存储器FM24C04交换数据
#define bitset(var,bitno) ((var)|=(1<
#define bitclr(var,bitno) ((var)&=((1<
//定义铁电的写地址和读地址
//用高256字节,则为A2 A3
//用低256字节,则为A0 A1
#define WriteDeviceAdd 0xa2 //用高256字节
#define ReadDeviceAdd 0xa3 //用高256字节
#define SDA RC3
#define SCL RC2
void I2C_Start()
SDA=1;
SCL=1;
SDA=0;
SCL=0;
void I2C_Stop()
SCL=0;
SDA=0;
SCL=1;
SDA=1;
bit I2C_WaitAck()
uchar ErrorTime=255;
SDA=1;
SCL=1;
bitset(TRISC,3);
while(SDA)
ErrorTime--;
if(ErrorTime==0)
bitclr(TRISC,3);
I2C_Stop();
return(0);
bitclr(TRISC,3);
SCL=0;
return(1);
void I2C_SendNotAck()
SDA=1;
SCL=1;
SCL=0;
void I2C_SendAck()
SDA=0;
SCL=1;
SCL=0;
void I2C_WriteByte(uchar input)
uchar i=8;
while(i--)
SCL=0;
if(input&0x80) SDA=1;
else SDA=0;
input=input<<1;
SCL=1;
SCL=0;
uchar I2C_ReceiveByte()
uchar i=8,rbyte=0;
SDA=1;
bitset(TRISC,3);
while(i--)
rbyte=rbyte<<1;
SCL=1;
if(SDA) rbyte++;
SCL=0;
bitclr(TRISC,3);
return(rbyte);
void I2C_Wr24c04(uchar *Wdata,uchar FmAdd,uchar bytes)
I2C_Start();
I2C_WriteByte(WriteDeviceAdd);
I2C_WaitAck();
I2C_WriteByte(FmAdd);
I2C_WaitAck();
for(;bytes!=0;bytes--)
I2C_WriteByte(*Wdata);
I2C_WaitAck();
Wdata++;
I2C_Stop();
void I2C_Rd24c04(uchar *RamAdd,uchar FmAdd,uchar bytes)
I2C_Start();
I2C_WaitAck();
I2C_WaitAck();
I2C_Start();
I2C_WriteByte(ReadDeviceAdd);
I2C_WaitAck();
while(bytes!=1)
*RamAdd=I2C_ReceiveByte();
I2C_SendAck();
RamAdd++;
bytes--;
I2C_SendNotAck();
I2C_Stop();
