#include
//--重定义函数变量--//
#define uchar unsigned char
#define uint unsigned int
#define ulong unsigned long
/* 定义常量 */
#define FOSC 12000000L //主时钟
#define T50us (65536-FOSC/12/1000000*50) //12T 模式下,50us 时间的计算方法
#define T10ms (65536-FOSC/12/1000*10) //12T 模式下,10ms 时间的计算方法
//--定义全局变量--//
uchar uTime1 = 0; //脉冲宽度数值
uchar uMove = 0; //移动标志
uchar uCount = 0; //每 10ms 计数值
uchar LightLevel[8] = {64,32,16,8,4,2,1,0};//亮度级别表:PWM的脉冲宽度
//0、1、2、3、4、5、6、7、8、9、A、b、C、d、E、F的显示码
uchar code DIG_CODE[16]={0x3F, 0x06, 0x5B, 0x4F, 0x66, 0x6D, 0x7D, 0x07,
0x7F, 0x6F, 0x77, 0x7C, 0x39, 0x5E, 0x79, 0x71};
void TimeConfig();
void main(void)
TimeConfig();
while(1)
uchar Led = 0x00; //当前点亮的Led的值
uchar i = 0;
if (uCount >= 10)
uCount = 0;
uMove++;
uTime1 %= 64;
uMove %= 8;
for(i = 0; i < 8; i++)
if (uTime1 < LightLevel[(i+uMove)%8])
Led |= 0x01 << i;
else
Led &= ~(0x01 << i);
P0 = Led;
void TimeConfig()
TMOD = 0x11; //设置定时计数器0和定时计数器1工作模式1
//--定时器0赋初始值,12MHZ下定时10ms--//
TL0 = T10ms;
TH0 = T10ms >> 8;
//--定时器1赋初始值,12MHZ下定时50us--//
TL1 = T50us;
TH1 = T50us >> 8;
TF0 = 0; //清除TF0标志
ET0 = 1; //开启定时器0中断
TF1 = 0; //清除TF1标志
ET1 = 1; //开启定时器1中断
EA = 1;
TR0 = 1; //开启定时器 0
TR1 = 1; //开启定时器 1
void Time0(void) interrupt 1 //0:外部中断1; 1:定时器0中断; 2:外部中断2; 3:定时器1中断; 4:串口中断
TL0 = T10ms; //重新赋初值
TH0 = T10ms >> 8;
uCount++;
void Time1(void) interrupt 3 //0:外部中断1; 1:定时器0中断; 2:外部中断2; 3:定时器1中断; 4:串口中断
TL1 = T50us; //重新赋初值
TH1 = T50us >> 8;
uTime1++;
