1.s3c6410_init()被调用的流程:
cpu赋值流程:
1).定义cpu, __mach_desc_MACH_TYPE_SMDK6410
static struct cpu_table *cpu;
#define MACHINE_START(_type,_name)
static const struct machine_desc __mach_desc_##_type
__used
__attribute__((__section__(".arch.info.init"))) = {
.nr = MACH_TYPE_##_type,
.name = _name,
#define MACHINE_END
static const struct machine_desc __mach_desc_SMDK6410
.nr = MACH_TYPE_SMDK6410
.name = "SMDK6410"
2).
machine_arch_type==MACH_TYPE_SMDK6410==1626
MACHINE_START(SMDK6410, "SMDK6410")
.init_irq = s3c_init_irq,
.map_io = smdk6410_map_io,
.fixup = smdk6410_fixup,
.timer = &s3c_timer,
.init_machine = smdk6410_machine_init,
MACHINE_END
start_kernel()==>setup_arch()===>
1.mdesc=setup_machine(machine_arch_type)==>lookup_machine_types(MACH_TYPE_SMDK6410) == __mach_desc_SMDK6410
2.paging_init(mdesc) ==>devicemaps_init(mdesc) ==> mdesc->map_io()==>__mach_desc_SMDK6410->map_io()
==>smdk6410_map_io() ==> s3c24xx_init_io() ==> cpu = s3c_lookup_cpu(idcode);
调用流程:
arch_initcall(s3c_arch_init)==>s3c_arch_init()==>(cpu->init)()==>s3c6410_init()
