调了好久,终于通了。。为什么用了一周时间这么久?主要原因是我不知道隔离模块有问题,导致一直是盲目的改代码,今天没办法,直接把隔离模块短路,一下子就读出了ID号。
7792挂在SPI2上,PB12,PB13,PB14,PB15,可我用SPI调的时候一直读出来是0XFF,以为是SPI2有问题,于是我直接抛弃SPI,用时序直接读。很好用!!!
下面是我的代码:
#define SCLOCK1 GPIO_SetBits(GPIOB,GPIO_Pin_13);
#define SCLOCK0 GPIO_ResetBits(GPIOB,GPIO_Pin_13);
#define CS1 GPIO_SetBits(GPIOB,GPIO_Pin_12);
#define CS0 GPIO_ResetBits(GPIOB,GPIO_Pin_12);
#define DIN1 GPIO_SetBits(GPIOB,GPIO_Pin_15);
#define DIN0 GPIO_ResetBits(GPIOB,GPIO_Pin_15);
#define DOUT1 GPIO_SetBits(GPIOB,GPIO_Pin_14);
#define DOUT0 GPIO_ResetBits(GPIOB,GPIO_Pin_14);
void Delay(unsigned int Time)
while(Time)
Time--;
unsigned char DataRead[3];
void WriteToReg(unsigned char ByteData) // write ByteData to the register
unsigned char temp;
int i;
CS0;
temp=0x80;
for(i=0;i<8;i++)
if((temp & ByteData)==0)
DIN0;
else
DIN1;
SCLOCK0;
Delay(10);
SCLOCK1;
Delay(10);
temp=temp>>1;
CS1;
void ReadFromReg(unsigned char nByte) // nByte is the number of bytes which need to be read
int i,j;
unsigned char temp;
DIN1;
CS0;
temp=0;
// DOUT1;
for(i=0; i
for(j=0; j<8; j++)
SCLOCK0;
if(GPIO_ReadInputDataBit(GPIOB,GPIO_Pin_14)==0)
temp=temp<<1;
}else
temp=temp<<1;
temp=temp+0x01;
Delay(10);
SCLOCK1;
Delay(10);
DataRead[i]=temp;
temp=0;
CS1;
extern void SSD1305_ShowASC16(u8 x,u8 y,u8 len,unsigned char *str);
void task_7792(void* parameter)
char str[20];
short iData[3];
int ResetTime;
/* PRECONFIGURE...*/
ResetTime=32;
SCLOCK1;
CS0; //to keep DIN=1 for 32 sclock to reset the part
DIN1;
while(ResetTime--)
Delay(10);
SCLOCK0;
Delay(10);
SCLOCK1;
CS1;
while(1)
WriteToReg(0x10); //write to Communication register.The next step is writing to Configuration register.
WriteToReg(0x00); //set the Configuration bipolar mode.Gain=1.
WriteToReg(0x80); //Configuration internal reference selected.
WriteToReg(0x08);//write to Communication register.The next step is writing to Mode register.
WriteToReg(0x20);//set the mode register as single conversion mode.
WriteToReg(0x00);//inter 64 kHZ clock.internal clock is not available at the clk pin.
WriteToReg(0x40);//write to Communication register.The next step is to read from Status register.
ReadFromReg(1);
while((DataRead[0]&0x80)==0x80)//wait for the end of convertion by polling the status register RDY bit
WriteToReg(0x40);
ReadFromReg(1);
WriteToReg(0x58);//write to Communication register.The next step is to read from Data register.
// WriteToReg(0x60) ;
ReadFromReg(2);
memcpy(&iData[0],&DataRead[0],2);
sprintf(str,"%d",iData[0]);
SSD1305_ShowASC16(10,20,6,str) ;
// printf("Data:%02BX %02BXrn",DataRead[0],DataRead[1]); }
嗯。出来了。。。。下面 就是自己配置寄存器,看读出来是哪个通道的值!
