单片机 > 单片机程序设计 > 详情
STM32F103 5个串口同时使用
发布时间:2024-08-01 发布时间:
硬件平台:STM32F103(自带5串口)
5个串口同时工作不丢包-_-
相关宏定义
typedef enum
    UartPort1,
    UartPort2,
    UartPort3,
    UartPort4,
    UartPort5,
    UartPort_USB,
}UARTPORT;
#define   RXTIMEOUT    10         // 接收超时时间,如10mSec内未接收任何数据,当作一个接收包
#define   UART_TXBUFFERLEN  0x100         //发送缓冲区大小
#define   UART_RXBUFFERLEN  0x400          //接接缓冲区大小
typedef struct
    //接收
    volatile Uint       rxHead;
    volatile Uint       rxTail;
    volatile Uchar      rxBuf[UART_RXBUFFERLEN];
    volatile Uchar      rxTimeOut_Base;
    volatile Uchar      rxTimeOut;
    //发送
    volatile Uint       txHead;
    volatile Uint       txTail;
    volatile BOOLEAN    txEmpty;
    volatile Uchar      baudrate;
    volatile Uchar      txIdleTimeOut;
    volatile Uchar      txIdleTimeOut_Base;
    volatile Uchar      txBuf[UART_TXBUFFERLEN];
}UART_STRUCT;
static UART_STRUCT uart1;
static UART_STRUCT uart2;
static UART_STRUCT uart3;
static UART_STRUCT uart4;
static UART_STRUCT uart5;
串口1初始化
    USART_InitTypeDef USART_InitStruct;
    GPIO_InitTypeDef GPIO_InitStruct;
    NVIC_InitTypeDef NVIC_InitStruct;
    RCC_APB2PeriphClockCmd( RCC_APB2Periph_USART1, ENABLE );
    GPIO_InitStruct.GPIO_Speed = GPIO_Speed_50MHz;
    /* Configure USART1 Tx (PA9) as alternate function push-pull */
    GPIO_InitStruct.GPIO_Pin = PIN_USART1_TXD;
    GPIO_InitStruct.GPIO_Mode = GPIO_Mode_AF_PP;
    GPIO_Init( PORT_USART1_TXD, &GPIO_InitStruct );
    /* Configure USART1 Rx (PA10) as input floating */
    GPIO_InitStruct.GPIO_Pin = PIN_USART1_RXD;
    GPIO_InitStruct.GPIO_Mode = GPIO_Mode_IN_FLOATING;
    GPIO_Init( PORT_USART1_RXD, &GPIO_InitStruct );
    USART_StructInit(&USART_InitStruct);
    USART_InitStruct.USART_BaudRate = 115200;
    USART_InitStruct.USART_WordLength = USART_WordLength_8b;
    USART_InitStruct.USART_StopBits = USART_StopBits_1;
    USART_InitStruct.USART_Parity = USART_Parity_No ;
    USART_InitStruct.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;
    USART_InitStruct.USART_HardwareFlowControl = USART_HardwareFlowControl_None;
    USART_Init(USART1, &USART_InitStruct);
    /* Enable the USARTx Interrupt */
#if 1
//  USART_ITConfig(USART2, USART_IT_TXE, ENABLE);
    USART_ITConfig(USART1, USART_IT_RXNE, ENABLE);
    NVIC_InitStruct.NVIC_IRQChannel = USART1_IRQn;
    NVIC_InitStruct.NVIC_IRQChannelPreemptionPriority = 0;
    NVIC_InitStruct.NVIC_IRQChannelSubPriority = 0;
    NVIC_InitStruct.NVIC_IRQChannelCmd = ENABLE;
    NVIC_Init(&NVIC_InitStruct);
#endif
    USART_Cmd(USART1, ENABLE);
串口2初始化
    RCC_APB1PeriphClockCmd( RCC_APB1Periph_USART2, ENABLE );
    /* Configure USART2 CTS (PA0) as input floating */
#if UART2_HARDWARE_FLOW
    GPIO_InitStruct.GPIO_Pin = PIN_USART2_CTS;
    GPIO_Init( PORT_USART2_CTS, &GPIO_InitStruct );
#endif
    /* Configure USART2 Rx (PA3) as input floating */
    GPIO_InitStruct.GPIO_Pin = PIN_USART2_RXD;
    GPIO_Init( PORT_USART2_RXD, &GPIO_InitStruct );
    /* Configure USART2 RTS (PA1) as alternate function push-pull */
    GPIO_InitStruct.GPIO_Pin = PIN_USART2_RTS;
    GPIO_Init( PORT_USART2_RTS, &GPIO_InitStruct );
#endif
    /* Configure USART2 Tx (PA2) as alternate function push-pull */
    GPIO_InitStruct.GPIO_Pin = PIN_USART2_TXD;
    GPIO_Init( PORT_USART2_TXD, &GPIO_InitStruct );
    USART_InitStruct.USART_HardwareFlowControl = USART_HardwareFlowControl_RTS;
#else
#endif
    USART_Init(USART2, &USART_InitStruct);
#if 1
    USART_ITConfig(USART2, USART_IT_RXNE, ENABLE);
    NVIC_InitStruct.NVIC_IRQChannel = USART2_IRQn;
#endif
    USART_Cmd(USART2, ENABLE);
串口3初始化
    RCC_APB1PeriphClockCmd( RCC_APB1Periph_USART3, ENABLE );
    /* Configure USART1 Tx (PC10) as alternate function push-pull */
    GPIO_InitStruct.GPIO_Pin = PIN_UART3_TXD;
    GPIO_Init( PORT_UART3_TXD, &GPIO_InitStruct );
    /* Configure USART1 Rx (PC11) as input floating */
    GPIO_InitStruct.GPIO_Pin = PIN_UART3_RXD;
    GPIO_Init( PORT_UART3_RXD, &GPIO_InitStruct );
    USART_Init(USART3, &USART_InitStruct);
#if 1
    USART_ITConfig(USART3, USART_IT_RXNE, ENABLE);
    NVIC_InitStruct.NVIC_IRQChannel = USART3_IRQn;
#endif
    USART_Cmd(USART3, ENABLE);
串口4初始化
    RCC_APB1PeriphClockCmd( RCC_APB1Periph_UART4, ENABLE );
#if 0
    GPIO_InitStruct.GPIO_Pin = PIN_UART4_CTS;
    GPIO_Init( PORT_UART4_CTS, &GPIO_InitStruct );
//    GPIO_ResetBits(PORT_UART4_CTS,PIN_UART4_CTS);
#endif
    GPIO_InitStruct.GPIO_Pin = PIN_UART4_TXD;
    GPIO_Init( PORT_UART4_TXD, &GPIO_InitStruct );
    GPIO_InitStruct.GPIO_Pin = PIN_UART4_RXD;
    GPIO_Init( PORT_UART4_RXD, &GPIO_InitStruct );
    USART_Init(UART4, &USART_InitStruct);
#if 1
    USART_ITConfig(UART4, USART_IT_RXNE, ENABLE);
    NVIC_InitStruct.NVIC_IRQChannel = UART4_IRQn;
#endif
    USART_Cmd(UART4, ENABLE);
串口5初始化
    RCC_APB1PeriphClockCmd( RCC_APB1Periph_UART5, ENABLE );
    GPIO_InitStruct.GPIO_Pin = PIN_UART5_TXD;
    GPIO_Init( PORT_UART5_TXD, &GPIO_InitStruct );
    GPIO_InitStruct.GPIO_Pin = PIN_UART5_RXD;
    GPIO_Init( PORT_UART5_RXD, &GPIO_InitStruct );
    USART_Init(UART5, &USART_InitStruct);
#if 1
    USART_ITConfig(UART5, USART_IT_RXNE, ENABLE);
    NVIC_InitStruct.NVIC_IRQChannel = UART5_IRQn;
#endif
    USART_Cmd(UART5, ENABLE);
中断处理
void USART_Irq_Function(UART_STRUCT *uart,USART_TypeDef *uartdef)
    //接收到数据USART_ GetITStatus
    while (USART_GetITStatus(uartdef, USART_IT_RXNE))
        Uchar temp;
        USART_ClearFlag(uartdef, USART_FLAG_RXNE | USART_FLAG_ORE);
        temp = USART_ReceiveData(uartdef);
        if (((uart->rxHead + 1) % UART_RXBUFFERLEN) != uart->rxTail)
            uart->rxBuf[uart->rxHead] = temp;
            uart->rxHead = (uart->rxHead + 1) % UART_RXBUFFERLEN;
            uart->rxTimeOut = uart->rxTimeOut_Base;
    //发送数据
    if (USART_GetITStatus(uartdef,USART_IT_TXE))
        // USART_ClearFlag(uartdef, USART_FLAG_TXE);
        if (uart->txHead == uart->txTail)
            uart->txEmpty = TRUE;
            USART_ITConfig(uartdef, USART_IT_TXE, DISABLE);
        else
            USART_SendData(uartdef, uart->txBuf[uart->txTail]);
            uart->txTail = (uart->txTail + 1) & (UART_TXBUFFERLEN - 1);
            uart->txIdleTimeOut = uart->txIdleTimeOut_Base;
extern void USART1_IRQHandler(void)
    USART_Irq_Function(&uart1,USART1);
extern void USART2_IRQHandler(void)
    USART_Irq_Function(&uart2,USART2);
extern void USART3_IRQHandler(void)
#ifdef INCLUDE_UARTPORT3
    USART_Irq_Function(&uart3,USART3);
#endif
extern void UART4_IRQHandler(void)
#ifdef INCLUDE_UARTPORT4
    USART_Irq_Function(&uart4,UART4);
#endif
extern void UART5_IRQHandler(void)
#ifdef INCLUDE_UARTPORT5
    USART_Irq_Function(&uart5,UART5);
#endif
超时检查
//函  数:检查是否有收到数据包,1ms调用一次
//参  数无
//返  回:无
extern void checkUartRxTimeOut()
    if (uart1.rxTimeOut)
        if (--uart1.rxTimeOut == 0)
            pushEvent(evCOM1,uart1.rxHead);
    if (uart2.rxTimeOut)
        if (--uart2.rxTimeOut == 0)
            pushEvent(evCOM2,uart2.rxHead);
    if (uart3.rxTimeOut)
        if (--uart3.rxTimeOut == 0)
            pushEvent(evCOM3,uart3.rxHead);
    if (uart4.rxTimeOut)
        if (--uart4.rxTimeOut == 0)
            pushEvent(evCOM4,uart4.rxHead);
    if (uart5.rxTimeOut)
        if (--uart5.rxTimeOut == 0)
            pushEvent(evCOM5,uart5.rxHead);
    if (uart1.txIdleTimeOut) uart1.txIdleTimeOut--;
    if (uart2.txIdleTimeOut) uart2.txIdleTimeOut--;
    if (uart3.txIdleTimeOut) uart3.txIdleTimeOut--;
#endif
    if (uart4.txIdleTimeOut) uart4.txIdleTimeOut--;
#endif
    if (uart5.txIdleTimeOut) uart5.txIdleTimeOut--;
#endif
单片机通用寄存器的分类及应用
