#include "stm32f10x.h"
#include
#define SCL_H (GPIOB->BSRR = GPIO_Pin_6)
#define SCL_L (GPIOB->BRR = GPIO_Pin_6)
#define SDA_H (GPIOB->BSRR = GPIO_Pin_7)
#define SDA_L (GPIOB->BRR = GPIO_Pin_7)
#define SCL_READ (GPIOB->IDR & GPIO_Pin_6)
#define SDA_READ (GPIOB->IDR & GPIO_Pin_7)
#define I2C_DELAY (I2C_delay())
/* RCC时钟配置 */
void RCC_config(void)
ErrorStatus HSEStartUpStatus;
/* RCC寄存器设置为默认配置 */
RCC_DeInit();
/* 打开外部高速时钟 */
RCC_HSEConfig(RCC_HSE_ON);
/* 等待外部高速时钟稳定 */
HSEStartUpStatus = RCC_WaitForHSEStartUp();
if(HSEStartUpStatus == SUCCESS)
/* 设置HCLK = SYSCLK */
RCC_HCLKConfig(RCC_SYSCLK_Div1);
/* 设置PCLK2 = HCLK */
RCC_PCLK2Config(RCC_HCLK_Div1);
/* 设置PCLK1 = HCLK / 2 */
RCC_PCLK1Config(RCC_HCLK_Div2);
// /* 设置FLASH代码延时 */
// FLASH_SetLatency(FLASH_Latency_2);
// /* 使能预取址缓存 */
// FLASH_PrefetchBufferCmd(FLASH_PrefetchBuffer_Enable);
/* 设置PLL时钟源为HSE倍频9 72MHz */
RCC_PLLConfig(RCC_PLLSource_HSE_Div1, RCC_PLLMul_9);
/* 使能PLL */
RCC_PLLCmd(ENABLE);
/* 等待PLL稳定 */
while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET);
/* 设置PLL为系统时钟源 */
RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);
/* 等待系统时钟源切换到PLL */
while(RCC_GetSYSCLKSource() != 0x08);
/* GPIO配置 */
void GPIO_config(void)
/* 时钟配置 */
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB, ENABLE);
/* SDA、SCL开漏输出 */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6 | GPIO_Pin_7;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_OD;
GPIO_Init(GPIOB, &GPIO_InitStructure);
/* 毫秒延时函数 */
void delay_ms(uint16_t time)
uint16_t i = 0;
while(time--)
i = 12000;
while(i--);
/* I2C延时函数 */
void I2C_delay(void)
uint8_t i = 100;
while(i)
i--;
/* I2C开始信号 */
bool I2C_Start(void)
SDA_H;
SCL_H;
I2C_DELAY;
if(!SDA_READ)
return false;
SDA_L;
I2C_DELAY;
if(SDA_READ)
return false;
SDA_L;
I2C_DELAY;
return true;
/* I2C停止信号 */
void I2C_Stop(void)
SCL_L;
I2C_DELAY;
SDA_L;
I2C_DELAY;
SCL_H;
I2C_DELAY;
SDA_H;
I2C_DELAY;
/* I2C响应信号 */
void I2C_Ack(void)
SCL_L;
I2C_DELAY;
SDA_L;
I2C_DELAY;
SCL_H;
I2C_DELAY;
SCL_L;
I2C_DELAY;
/* I2C未响应信号 */
void I2C_NoAck(void)
SCL_L;
I2C_DELAY;
SDA_H;
I2C_DELAY;
SCL_H;
I2C_DELAY;
SCL_L;
I2C_DELAY;
/* 等待应答信号 */
bool I2C_WaitAck(void)
SCL_L;
I2C_DELAY;
SDA_H;
I2C_DELAY;
SCL_H;
I2C_DELAY;
if(SDA_READ)
SCL_L;
return false;
SCL_L;
return true;
/* I2C发送一个字节 */
void I2C_SendByte(uint8_t SendByte)
uint8_t i = 8;
while(i--)
SCL_L;
I2C_DELAY;
if(SendByte & 0x80)
SDA_H;
else
SDA_L;
SendByte <<= 1;
I2C_DELAY;
SCL_H;
I2C_DELAY;
SCL_L;
/* I2C接收一个字节 */
uint8_t I2C_ReceiveByte(void)
uint8_t i = 8;
uint8_t ReceiveByte = 0;
SDA_H;
while(i--)
ReceiveByte<<=1;
SCL_L;
I2C_DELAY;
SCL_H;
I2C_DELAY;
if(SDA_READ)
ReceiveByte|=0x01;
SCL_L;
return ReceiveByte;
#define CTRL_CODE 0xA0
/* 写一个字节 */
bool EEPROM_Write_Byte(uint8_t block, uint8_t addr, uint8_t *data)
uint8_t cnt = 10;
/* 确认写周期结束,并写入控制字 */
do
I2C_Start();
I2C_SendByte((CTRL_CODE | (block & 0x0E)) & 0xFE);
}while((I2C_WaitAck() == false) && (--cnt > 0));
if(cnt == 0)
I2C_Stop();
return false;
/* 写入地址 */
I2C_SendByte(addr);
if(I2C_WaitAck() == false)
I2C_Stop();
return false;
/* 写入数据 */
I2C_SendByte(*data);
I2C_Stop();
return false;
I2C_Stop();
return true;
/* 读一个字节 */
bool EEPROM_Read_Byte(uint8_t block, uint8_t addr, uint8_t *data)
uint8_t cnt = 10;
do
I2C_Start();
if(cnt == 0)
I2C_Stop();
return false;
/* 写入地址 */
I2C_SendByte(addr);
I2C_Stop();
return false;
/* 写入控制字 */
I2C_Start();
I2C_SendByte(CTRL_CODE | (block & 0x0E) | 0x01);
I2C_Stop();
return false;
/* 读出数据 */
*data = I2C_ReceiveByte();
I2C_NoAck();
I2C_Stop();
return true;
/* 主函数 */
int main(void)
uint8_t data = 3;
/* RCC时钟配置 */
RCC_config();
/* GPIO配置 */
GPIO_config();
EEPROM_Write_Byte(0, 0, &data);
data = 6;
EEPROM_Read_Byte(0, 0, &data);
while(1)
delay_ms(1000);
关键字:STM32 I2C例程 24C02『本文转载自网络,版权归原作者所有,如有侵权请联系删除』
