* Ubuntu 安装arm-linux-gcc编译器
* 说明:
* Ubuntu下直接安装arm-linux-gcc编译器,省得去配置那些环境。
* 2017-3-21 深圳 南山平山村 曾剑锋
一、参考文档:
Install the ARM cross compiler toolchain on your Linux Ubuntu PC
https://www.acmesystems.it/arm9_toolchain
二、查找支持armhf的软件包名:
zengjf@zengjf:~/zengjf/zengjfos/busybox/busybox-1.26.2$ sudo apt-cache search arm | grep gcc | grep armhf
gcc-arm-linux-gnueabihf - GNU C compiler for the armhf architecture
libgcc-6-dev-armhf-cross - GCC support library (development files)
libgcc1-armhf-cross - GCC support library
gcc-multilib-arm-linux-gnueabihf - GNU C compiler for the armhf architecture
gccgo-arm-linux-gnueabihf - Go compiler (based on GCC) for the armhf architecture
libgcc-4.7-dev-armhf-cross - GCC support library (development files)
libgcc-4.9-dev-armhf-cross - GCC support library (development files)
libgcc-5-dev-armhf-cross - GCC support library (development files)
libgcc1-dbg-armhf-cross - GCC support library (debug symbols)
libsfgcc-4.7-dev-armhf-cross - GCC support library (soft float ABI development files)
libsfgcc-4.9-dev-armhf-cross - GCC support library (soft float ABI development files)
libsfgcc-5-dev-armhf-cross - GCC support library (soft float ABI development files)
libsfgcc-6-dev-armhf-cross - GCC support library (soft float ABI development files)
libsfgcc1-armhf-cross - GCC support library (soft float ABI)
libsfgcc1-dbg-armhf-cross - GCC support library (debug symbols)
三、安装命令:
1. sudo apt-get install gcc-arm-linux-gnueabihf
2. 安装结果:
zengjf@zengjf:~/zengjf/zengjfos/busybox/busybox-1.26.2$ arm
arm2hpdl arm-linux-gnueabihf-gcc arm-linux-gnueabihf-gcov-6 arm-linux-gnueabihf-objdump
arm-linux-gnueabihf-addr2line arm-linux-gnueabihf-gcc-6 arm-linux-gnueabihf-gcov-tool arm-linux-gnueabihf-ranlib
arm-linux-gnueabihf-ar arm-linux-gnueabihf-gcc-ar arm-linux-gnueabihf-gcov-tool-6 arm-linux-gnueabihf-readelf
arm-linux-gnueabihf-as arm-linux-gnueabihf-gcc-ar-6 arm-linux-gnueabihf-gprof arm-linux-gnueabihf-size
arm-linux-gnueabihf-c++filt arm-linux-gnueabihf-gcc-nm arm-linux-gnueabihf-ld arm-linux-gnueabihf-strings
arm-linux-gnueabihf-cpp arm-linux-gnueabihf-gcc-nm-6 arm-linux-gnueabihf-ld.bfd arm-linux-gnueabihf-strip
arm-linux-gnueabihf-cpp-6 arm-linux-gnueabihf-gcc-ranlib arm-linux-gnueabihf-ld.gold
arm-linux-gnueabihf-dwp arm-linux-gnueabihf-gcc-ranlib-6 arm-linux-gnueabihf-nm
arm-linux-gnueabihf-elfedit arm-linux-gnueabihf-gcov arm-linux-gnueabihf-objcopy
