前段时间使用ATMEGA32的TWI,总结如下:
unsigned char WriteRtc( unsigned char SlaAddr, unsigned char RegAddr, unsigned char *SlaData, unsigned char Length )
unsigned char i;
TWCR = ( 1<
TWDR = SlaAddr; //TWDR must be written when TWINT set
TWCR = ( 1<
TWDR = RegAddr; //write register address
TWCR = ( 1<
for( i = 0; i < Length; i++ )
TWDR = *( SlaData+i );
TWCR = ( 1<
TWCR = ( 1<
return(1);
//read RTC
unsigned char ReadRtc( unsigned char SlaAddr, unsigned char RegAddr, unsigned char *pRead, unsigned char Length )
unsigned char i;
TWCR = ( 1<
TWDR = SlaAddr-1; //send slave address
TWCR = ( 1<
TWDR = RegAddr; //send register of device
TWCR = ( 1<
TWCR = ( 1<
DDRC &= 0XFD; //set SDA as input
PORTC |= 0X02; //set pull-up resistor
TWCR = ( 1<
TWDR = SlaAddr;
TWCR = ( 1<
for( i = 0; i < Length - 1; i++ )
TWCR = ( 1<
TWCR = ( 1<
TWCR = ( 1<
DDRC |= 0X03;
return(1);
刚开始用的时候,老是读出错误的数据,最后用Beagle-GUI.抓取I2C,结果发现读I2C时,送出丛机地址和寄存器地址后就退出,原来是从机未发出ACK响应主机,因此关于ATMEGA32的TWI有几点要注意:
1. 首先,关于TWI写顺序是: I2cStart ----> WriteSlaAddr -----> WriteRegAddr ----> WriteData ----> I2cStop;
2. 其次, 关于TWI读N字节的顺序是:I2cStart ----> WriteSlaAddr ----> WriteRegAddr ----> I2cStop ----> I2cStart ---> WriteSlaAddr ----> sendAck----> receive data( (N-1) bytes ) ----->SendNACK ---->receive data ( the last byte) -----> I2cStop;
3. 最后提醒:读TWI的时候,读时的ACK是不一样的,前(N-1)个字节应该发出ACK信号响应,但是最后一个字节应该发送ACK信号。
以上的代码未加入容错机制,需要改善
