51单片机串口调试程序一列
/*定义为中断方式串口处理*/
#define INTERSENDSTR
/*不为8032系列芯片 */
//#define CHIP_8032
#include
#include
#include
#include "err.h"
#ifdef INTERSENDSTR
unsigned char xdata sSendComBuf[256],sRecComBuf[256];
unsigned char data bOut,bIn,bSout,bSin;
#else
#define DEFSENDCHAR TI=0;SBUF=ACC;while(!TI);TI=0;
#endif
//bps设置 9600就是 PSetBps(96)(11.0592Mhz)
unsigned char PSetBps(unsigned int bps) SMALL
unsigned int t1;
unsigned char t2;
#ifdef INTERSENDSTR
/*如果使用中断方式发送数据,必须等待串口发送数据完毕才能更换波特率 */
while(bSin!=bSout)
ES=0;
#endif
#ifdef CHIP_8032
if(3456%bps)
return ERR_SET_BPS;
t1=3456/bps;
t1--;t1=~t1;
RCAP2H=t1/256;RCAP2L=t1;
T2MOD=0x00;
/*使用定时器2做波特率发生器 */
T2CON=0x34;/*TF2=0;EXF2=0;RCLK=1;TCLK=1;EXEN2=0;TR2=1;C/T2=0;CP/RL2=0
#else
t1=576/bps;
if((576%bps)||((t1==0))||(t1>=2*256))
return ERR_SET_BPS;
if(t1>256)
PCON=00;
t2=256-(288/bps);
else
PCON=0x80;
t2=256-t1;
TH1=t2;TL1=t2;
TR1=1;
#endif
/*模式3*/
SM0=0;
RI=0;TI=0;
REN=1;
SM1=1;
SM2=1;
#ifdef INTERSENDSTR
bOut=bIn;
bSout=bSin;
ES=1;
#endif
return OK;
void PSendChar(unsigned char ch) SMALL
#ifdef INTERSENDSTR
unsigned char tch;
tch=bSin+1;
while(tch==bSout)
sSendComBuf[bSin]=ch;
ES=0;
if((bSout==bSin))
SBUF=sSendComBuf[bSin];
bSin++;
else
bSin++;
ES=1;
#else
ACC=ch;
DEFSENDCHAR;
#endif
unsigned char PGetChar() SMALL
unsigned char ch;
#ifdef INTERSENDSTR
ch=sRecComBuf[bOut];
bOut++;
return ch;
#else
ch=SBUF;
RI=0;
#endif
bit PCharInCom() SMALL
#ifdef INTERSENDSTR
if(bIn!=bOut)
return 1;
return 0;
#else
return RI;
#endif
void PSendString(unsigned char *st) SMALL
while(*st)
PSendChar(*st);
st++;
void PSendArray(unsigned char *st,unsigned int len) SMALL
unsigned int ii;
for(ii=0;ii
PSendChar(st[ii]);
#ifdef INTERSENDSTR
void PSerialInt() interrupt 4
if(RI)
sRecComBuf[bIn]=SBUF;
bIn++;
RI=0;
if(TI)
TI=0;
if(bSout!=bSin)
bSout++;
if(bSout!=bSin)
SBUF=sSendComBuf[bSout];
#endif
