基于STM32利用按键点亮LED灯的基本步骤:
(1)打开stm32CubeMX,创建新工程文件
(2)选择需要的芯片,本次实验采用的是STM32F411RETx
(3)黄色代表可被使用的引脚,绿色代表已被确定功能的引脚。左侧设置栏中的红色部分表示:IO口复用造成的重叠,以至不能继续使用。
(4)选好芯片,设置好相关系数参量后,选择与keil5相对应的MDK—ARM V5。
源程序:
1.按键按下LED灯点亮
int main
if(HAL_GPIO_ReadPin(GPIOC,GPIO_PIN_13) == 0){
HAL_Delay(10); //延时去抖
if(HAL_GPIO_ReadPin(GPIOC,GPIO_PIN_13) == 0){ //判断是否有键按下,有则亮
HAL_GPIO_WritePin(GPIOA,GPIO_PIN_5,GPIO_PIN_SET);
}else{
HAL_GPIO_WritePin(GPIOA,GPIO_PIN_5,GPIO_PIN_RESET);
2.按键按下,LED灯亮1s后熄灭
int main
HAL_Delay(10);
if(HAL_GPIO_ReadPin(GPIOC,GPIO_PIN_13) == 0){ //判断时候有键按下
HAL_Delay(1000); //按键按下后灯亮1S
}else{
3.按键按下LED点亮,再按键LED熄灭
int main{
HAL_Delay(100); //延时去抖
if(HAL_GPIO_ReadPin(GPIOC,GPIO_PIN_13) == 0) //判断是否有键按下
//功能代码处
HAL_GPIO_TogglePin(GPIOA,GPIO_PIN_5); //有键按下就反转
//功能代码处
while(HAL_GPIO_ReadPin(GPIOC,GPIO_PIN_13) == 0);
配置引脚的初始化电平
/*Configure GPIO pin Output Level */
HAL_GPIO_WritePin(GPIOD, GPIO_PIN_13, GPIO_PIN_SET);
/*Configure GPIO pin : PC13 */
GPIO_InitStruct.Pin = GPIO_PIN_13;
GPIO_InitStruct.Mode = GPIO_MODE_INPUT;
GPIO_InitStruct.Pull = GPIO_NOPULL;
HAL_GPIO_Init(GPIOC, &GPIO_InitStruct);
/*Configure GPIO pin : PA5 */
GPIO_InitStruct.Pin = GPIO_PIN_5;
GPIO_InitStruct.Mode = GPIO_MODE_OUTPUT_PP;
GPIO_InitStruct.Speed = GPIO_SPEED_LOW;
HAL_GPIO_Init(GPIOA, &GPIO_InitStruct);
