环境:STM32F103RC,主频 72MHz(外部晶振)或64MHz(HSI)
普通IO口模拟spi
代码实现:
// ADS8339.c
函数名称:Read16BitsData
函数描述:IO口模拟spi读16位数据
Calls:
Called by: GetOnce_ADCData
输入参数:无
返回值:读到的16位数据
static uint16_t Read16BitsData(void)
uint32_t status = 0;
uint16_t data = 0;
ADS8339_CLK_H;
ADS8339_CLK_L;
for (int number = 0; number < 16; number++)
ADS8339_CLK_H;
status = ADS8339_SD0_STATUS();
ADS8339_CLK_L;
if(status)
data |= 1;
data <<= 1;
return data;
函数名称:GetOnce_ADCData
函数描述:按照ADS8339时序图进行IO口模拟spi读16位数据
Calls:
Called by:
输入参数:无
返回值:读到的16位数据
static uint16_t GetOnce_ADCData(void)
uint16_t getValue = 0;
ADS8339_CS_H;
ADS8339_CS_L; // ADC转换开始
while(ADS8339_SD0_STATUS() != GPIO_PIN_RESET); // 一定要确保调用该函数的中断优先级最高(即TIM2中断优先级),否则会出现死机情况
getValue = Read16BitsData();
ADS8339_CS_H;
ADS8339_CS_L;
return getValue;
