随着学习的深入,渐渐发现,编程时更多的工作是不断的配置寄存器,做着许多重复的工作。所以就感觉很有必要把经常使用的寄存器、配置结构罗列出来,以方便使用!!这是其中的一部分,其他的慢慢来
本页所包含的配置函数有:
void SysTick_Configuration(void);
void GPIO_Configuration(void);
void EXTI_Configuration(void);
void NVIC_Configuration(void);
void RCC_Configuration(void);
void IWDG_Configuration(void);
//同时需要配置的结构体变量
EXTI_InitTypeDef EXTI_InitStructure;
NVIC_InitTypeDef NVIC_InitStructure;
*******//Cortex系统定时器(SysTick)*********************
//选择系统定时器(SysTick)的时钟源
SysTick_CLKSourceConfig(SysTick_CLKSource_HCLK);
SysTick_SetReload(72000);
SysTick_ITConfig(ENABLE);
*********///GPIO的配置程序***************************************
void GPIO_Configuration(void) void RCC_Configuration(void)
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
GPIO_Init(GPIOC, &GPIO_InitStructure);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
GPIO_Init(GPIOB, &GPIO_InitStructure);
//中断线路初始化
EXTI_InitStructure.EXTI_Line = EXTI_Line9;
EXTI_InitStructure.EXTI_Mode = EXTI_Mode_Interrupt;
EXTI_InitStructure.EXTI_Trigger = EXTI_Trigger_Falling;
EXTI_InitStructure.EXTI_LineCmd = ENABLE;
EXTI_Init(&EXTI_InitStructure);
EXTI_InitStructure.EXTI_Line = EXTI_Line13;
///嵌套中断向量NVIC**********************************
GPIO_EXTILineConfig(GPIO_PortSourceGPIOB, GPIO_PinSource9);
NVIC_PriorityGroupConfig(NVIC_PriorityGroup_1);
NVIC_InitStructure.NVIC_IRQChannel=EXTI0_IRQChannel;
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority=0;
NVIC_InitStructure.NVIC_IRQChannelSubPriority=0;
NVIC_InitStructure.NVIC_IRQChannelCmd=ENABLE;
NVIC_Init(&NVIC_InitStructure);
//为EXTI_Line9使能并配置中断向量
//为EXTI_Line0使能并配置中断向量
NVIC_InitStructure.NVIC_IRQChannel=EXTI9_5_IRQChannel;
//为EXTI_Line13使能并配置中断向量
NVIC_InitStructure.NVIC_IRQChannel=EXTI15_10_IRQChannel;
}[page]
**************系统时钟的配置RCC_Configuration**********************
RCC_DeInit();
RCC_HSEConfig(RCC_HSE_ON);
HSEStartUpStatus = RCC_WaitForHSEStartUp();
if(HSEStartUpStatus == SUCCESS)
RCC_HCLKConfig(RCC_SYSCLK_Div1);
RCC_PCLK2Config(RCC_HCLK_Div1);
RCC_PCLK1Config(RCC_HCLK_Div2);
FLASH_SetLatency(FLASH_Latency_2);
FLASH_PrefetchBufferCmd(FLASH_PrefetchBuffer_Enable);
RCC_PLLConfig(RCC_PLLSource_HSE_Div1, RCC_PLLMul_9);
RCC_PLLCmd(ENABLE);
while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET)
RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);
while(RCC_GetSYSCLKSource() != 0x08)
*****************//初始化独立看门狗******************************
//是能或者失能对寄存器IWDG_PR和IWDG_RLR
IWDG_WriteAccessCmd(IWDG_WriteAccess_Enable);
//选定工作频率
IWDG_SetPrescaler(IWDG_Prescaler_32);
//设置重装载值
IWDG_SetReload(230);
//按照重装载器的值重装载IWDG计数器的值-----------此动作相当于“喂狗”
IWDG_ReloadCounter();
//使能IWDG
IWDG_Enable();
TIM_DeInit(TIM1); //将外设TIMx寄存器重设为缺省值
//2、基础设置
TIM1_TimeBaseStructure.TIM_Prescaler = 0x0; //预分频,此值+1为分频的除数得到计数周期;
TIM1_TimeBaseStructure.TIM_Period = 0xFFFF;//计数周期 (即当计数值达到“计数值”时,刚好用时一个计数周期)
TIM1_TimeBaseStructure.TIM_ClockDivision = 0x0;//时钟因子
TIM1_TimeBaseStructure.TIM_RepetitionCounter = 0x0;
TIM1_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up; //计数器模式
//TIM_CounterMode_Dowm 向下计数
//TIM_CounterMode_CenterAligned1 中心对齐方式1
// TIM_CounterMode_CenterAligned2 中心对齐方式2
// TIM_CounterMode_CenterAligned3 中心对齐方式3
TIM_TimeBaseInit(TIM1,&TIM1_TimeBaseStructure);
// 3、输出通道设置
TIM1_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM2;
//TIM_OCMode_Timing输出比较时间模式(输出引脚冻结无效)
//TIM_OCMode_Active 输出比较主动模式(匹配时设置输出引脚为有效电平,当计数值为比较/捕获寄存器值相同时,强制输出为高平) TIM_OCMode_Inactive; 输出比较非主动模式 (匹配时设置输出引脚为无效电平,当计数值为比较/捕获寄存器值相同时,强制输出为低电平)
//TIM_OCMode_Toggle 输出比较触发模式(翻转。当计数值与比较/捕获寄存器值相同时,翻转输出引脚的电平)
//TIM_OCMode_PWM1向上计数时,当TIMx_CNT < TIMx_CCR*时,输出电平有效,否则为无效,
//向下计数时,当TIMx_CNT > TIMx_CCR*时,输出电平无效,否则为有效
//TIM_OCMode_PWM2 ;与PWM1模式相反
TIM1_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;
TIM1_OCInitStructure.TIM_OutputNState = TIM_OutputNState_Enable;
TIM1_OCInitStructure.TIM_Pulse = CCR1_Val;
TIM1_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_Low;
TIM1_OCInitStructure.TIM_OCNPolarity = TIM_OCNPolarity_Low;
TIM1_OCInitStructure.TIM_OCIdleState = TIM_OCIdleState_Set;
TIM1_OCInitStructure.TIM_OCNIdleState = TIM_OCIdleState_Reset;
TIM_OC1Init(TIM1,&TIM1_OCInitStructure);
TIM1_OCInitStructure.TIM_Pulse = CCR2_Val;
TIM_OC2Init(TIM1,&TIM1_OCInitStructure);
TIM1_OCInitStructure.TIM_Pulse = CCR3_Val;
TIM_OC3Init(TIM1,&TIM1_OCInitStructure);
TIM1_BDTRInitStructure.TIM_OSSRState = TIM_OSSRState_Enable;
TIM1_BDTRInitStructure.TIM_OSSIState = TIM_OSSIState_Enable;
TIM1_BDTRInitStructure.TIM_LOCKLevel = TIM_LOCKLevel_1;
TIM1_BDTRInitStructure.TIM_DeadTime = 0x75;
TIM1_BDTRInitStructure.TIM_Break = TIM_Break_Enable;
TIM1_BDTRInitStructure.TIM_BreakPolarity = TIM_BreakPolarity_High;
TIM1_BDTRInitStructure.TIM_AutomaticOutput = TIM_AutomaticOutput_Enable;
TIM_BDTRConfig(TIM1,&TIM1_BDTRInitStructure);
TIM_Cmd(TIM1,ENABLE);
TIM_CtrlPWMOutputs(TIM1,ENABLE);
关键字:ARM 编程技巧
