因为时间片的原因freeRTOS自身貌似无法进行微秒级的延时,实测通过以下函数可以进行微秒级的消息
dwt_stm32_delay.h
#ifndef DWT_STM32_DELAY_H
#define DWT_STM32_DELAY_H
#ifdef __cplusplus
extern "C" {
#endif
#include "stm32f4xx_hal.h"
* @brief Initializes DWT_Cycle_Count for DWT_Delay_us function
* @return Error DWT counter
* 1: DWT counter Error
* 0: DWT counter works
uint32_t DWT_Delay_Init(void);
* @brief This function provides a delay (in microseconds)
* @param microseconds: delay in microseconds
__STATIC_INLINE void DWT_Delay_us(volatile uint32_t microseconds)
uint32_t clk_cycle_start = DWT->CYCCNT;
/* Go to number of cycles for system */
microseconds *= (HAL_RCC_GetHCLKFreq() / 1000000);
/* Delay till end */
while ((DWT->CYCCNT - clk_cycle_start) < microseconds);
#ifdef __cplusplus
#endif
#endif
dwt_stm32_delay.c
#include "dwt_stm32_delay.h"
* @brief Initializes DWT_Clock_Cycle_Count for DWT_Delay_us function
* 1: clock cycle counter not started
* 0: clock cycle counter works
uint32_t DWT_Delay_Init(void) {
/* Disable TRC */
CoreDebug->DEMCR &= ~CoreDebug_DEMCR_TRCENA_Msk; // ~0x01000000;
/* Enable TRC */
CoreDebug->DEMCR |= CoreDebug_DEMCR_TRCENA_Msk; // 0x01000000;
/* Disable clock cycle counter */
DWT->CTRL &= ~DWT_CTRL_CYCCNTENA_Msk; //~0x00000001;
/* Enable clock cycle counter */
DWT->CTRL |= DWT_CTRL_CYCCNTENA_Msk; //0x00000001;
/* Reset the clock cycle counter value */
DWT->CYCCNT = 0;
/* 3 NO OPERATION instructions */
__ASM volatile ("NOP");
/* Check if clock cycle counter has started */
if(DWT->CYCCNT)
return 0; /*clock cycle counter started*/
else
return 1; /*clock cycle counter not started*/
main.c
/* Includes ------------------------------------------------------------------*/
int main(void)
/* USER CODE BEGIN 1 */
/* USER CODE END 1 */
/* MCU Configuration----------------------------------------------------------*/
/* Reset of all peripherals, Initializes the Flash interface and the Systick. */
HAL_Init();
/* Configure the system clock */
SystemClock_Config();
/* Initialize all configured peripherals */
MX_GPIO_Init();
/* USER CODE BEGIN 2 */
if(DWT_Delay_Init())
Error_Handler(); /* Call Error Handler */
while(1)
/* 10s Delay */
DWT_Delay_us(10000000);
HAL_GPIO_TogglePin(LD2_GPIO_Port, LD2_Pin);
亲测,通过修改stm32f4xx_hal.h头文件为stm32f1xx_hal.h,
f1系列也适应
