单片机 > 单片机程序设计 > 详情
用单片机做一个计算器
发布时间:2025-09-17 发布时间:
硬件电路
用单片机做一个计算器 - 汪政伟 - 我的博客
程序
#include
#define  DIN P1_0
#define  CLK P1_2
#define  LOAD P1_1
unsigned char key_h,key_l,key_code;
unsigned char ADS,i,j,m,n;
unsigned char n_bit=0;
unsigned char flag=0;
unsigned char key_num[16]={7,8,9,'/',4,5,6,'*',1,2,3,'-','c',0,'=','+'};
unsigned char data1[6]={0};
unsigned char data2[6]={0};
unsigned int result;
void delay(unsigned int n)
 while(n--);
void send(unsigned char addr,unsigned char dat)
 LOAD=0;
 i=0;
 while(i<16)
  if(i<8) ADS=addr;
  else
   ADS=dat;
  for(j=8;j>=1;j--)
   DIN=ADS&0x80;
   ADS<<=1;
   CLK=1;
   CLK=0;
  i+=8;
 LOAD=1;
void clear()
 for(m=1;m<=5;m++)
  send(m,0xff);
 send(0x06,0);
 n_bit=6;
void calc()
 unsigned int temp1;
 unsigned int tmep2;
 unsigned char temp;
 temp1=data1[5]+data1[4]*10+data1[3]*100+data1[2]*1000+data1[1]*10000;
 tmep2=data2[5]+data2[4]*10+data2[3]*100+data2[2]*1000+data2[1]*10000;
 switch(flag)
 case 1: result=temp1+tmep2; break;
 case 2: result=temp1-tmep2; break;
 case 3: result=temp1*tmep2; break;
 case 4: result=temp1/tmep2; break;
 clear();
 for(n=6;n>1;n--)
  temp=(unsigned char)result%10;
  if(temp) send(n,temp);
  result/=10;
  data2[n-1]=data1[n-1]=0;
 flag=0;
 while((P2&0xf0)!=0xf0);
void keyScan()   //键盘扫描程序
 if((P2&0xf0)!=0xf0)
  delay(20);
 if((P2&0xf0)!=0xf0)
  key_h=P2&0xf0;
  P2=0xf0|0x01;
  if((P2&0xf0)==0xf0) key_l=0;
  P2=0xf0|0x02;
  if((P2&0xf0)==0xf0) key_l=1;
  P2=0xf0|0x04;
  if((P2&0xf0)==0xf0) key_l=2;
  P2=0xf0|0x08;
  if((P2&0xf0)==0xf0) key_l=3;
  P2=0xf0;
  switch((~P2)&0xf0)
  case 0x10: key_h=0x0; break;
  case 0x20: key_h=0x1; break;
  case 0x40: key_h=0x2; break;
  case 0x80: key_h=0x3; break;
  key_code=key_l*4+key_h;
  switch(key_code)
  case 3:  flag=4;n_bit=7;break; //+
  case 7:  flag=3;n_bit=7;break; //-
  case 11: flag=2;n_bit=7;break; //*
  case 15: flag=1;n_bit=7;break; ///
  case 14: calc();n_bit=7;return; //=
  case 12: clear();break; //C
  default:
   if(n_bit>1)
    if(n_bit==7)
     clear();
    send(n_bit--,key_num[key_code]);
    if(!flag)
     data1[n_bit]=key_num[key_code];
    else
     data2[n_bit]=key_num[key_code];
void main(void)
 P2=0xf0;
 send(0x0c,0x01);
 send(0x0b,0x05);
 send(0x0a,0xf5);
 send(0x09,0xff);
 //  send(0x01,0x8f);
 //  send(0x02,0x82);
 //  send(0x03,0x83);
 //  send(0x04,0x84);
 //  send(0x05,0x85);
 //  send(0x06,0x86);
 //  send(0x07,0x87);
 //  send(0x08,0x08);
 clear();
 n_bit=6;
 while(1)
  keyScan();
关键字:单片机  计算器
