TMOD = 0X21;
TH1 = 0XFD;
TL1 = 0XFD;
SM0 = 0;
SM1 = 1;
REN = 1;
TR1 = 1;
//ES = 1;//串口中断影响外部中断0 这句话会让程序无法进入外部中断服务
TH0 = 0;
TL0 = 0;
ET0 = 0;//关闭定时器0
IT0 = 1;//外部中断下降沿触发*/
EX0 = 1;//打开外部中断
EA = 1;
//ES = 1;
void Send_data(unsigned char dat)
SBUF = dat;
while(!TI);
TI = 0;
int j;
void main()
unsigned int i;
LED = LED_ON;
//LED = LED_OFF;
flag_test_high = ON;
IN0 = 1;
Usart_INT0_init();
EX0 = 1;
while(1)
/*i=40000;
while(i--);*/
/*flag_test_high = ON;
EX0 = 1;
while(flag_test_high == ON);
EX0 = 0;
//Send_data('a');*/
Send_data(result|0x30);
void EX_int(void) interrupt 0
EX0 = 0;
ET0 = 1;//打开定时器
TR0 = 1;
while(IN0 == 0);
TR0 = 0;
tem_TH = TH0;
tem_TL = TL0;
sum = tem_TH*256 + tem_TL;
sum = (int)sum/1000;
result = 9 - sum;
//result = 9-(int)(10*(TH0*256 + TL0)/10000);//分步计算避免出错
TH0 = 0;
TL0 = 0;
LED = LED_OFF;
//Send_data(result|0x30);
flag_test_high = OFF;
ET0 = 0;//关闭定时器
EX0 = 1;
