采用8MHz 外部HSE 时钟,程序的时钟设置参数流程如下:
1.将 RCC 寄存器重新设置为默认值:RCC_DeInit();
2.打开外部高速时钟晶振 HSE :RCC_HSEConfig(RCC_HSE_ON);
3.等待外部高速时钟晶振工作: HSEStartUpStatus = RCC_WaitForHSEStartUp();
4.设置 AHB 时钟 (HCLK) :RCC_HCLKConfig(RCC_SYSCLK_Div1);
5.设置APB 2时钟 (APB2) :RCC_PCLK2Config(RCC_HCLK_Div1);
6.设置APB1 时钟 (APB1) :RCC_PCLK1Config(RCC_HCLK_Div2);
7.设置 PLL :RCC_PLLConfig(RCC_PLLSource_HSE_Div1, RCC_PLLMul_9);
8.打开 PLL :RCC_PLLCmd(ENABLE);
9.等待 PLL 工作:while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET);
10.设置系统时钟:RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);
11.判断 PLL 是否是系统时钟:while(RCC_GetSYSCLKSource() != 0x08);
void RCC_config()
ErrorStatus HSEStartUpStatus; // 定义错误状态变量
RCC_DeInit();//将RCC寄存器重新设置为默认值
RCC_HSEConfig(RCC_HSE_ON); //打开外部高速时钟晶振
HSEStartUpStatus = RCC_WaitForHSEStartUp();// 等待外部高速时钟晶振工作
if(HSEStartUpStatus == SUCCESS)
RCC_HCLKConfig(RCC_SYSCLK_Div1);//设置AHB不分频,HCLK=SYSCLK
RCC_PCLK2Config(RCC_HCLK_Div1);//设置APB2不分频,P2CLK=HCLK
RCC_PCLK1Config(RCC_HCLK_Div2); //设置APB1 为2分频,P1CLK=HCLK/2
FLASH_SetLatency(FLASH_Latency_2);//设置FLASH代码延时
FLASH_PrefetchBufferCmd(FLASH_PrefetchBuffer_Enable);//使能预取指缓存
RCC_PLLConfig(RCC_PLLSource_HSE_Div1, RCC_PLLMul_9);//设置PLL时钟源,为HSE的9倍频8MHz * 9 = 72MHz
RCC_PLLCmd(ENABLE);//使能PLL
while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET);//等待PLL准备就绪
RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);//设置PLL为系统时钟源
while(RCC_GetSYSCLKSource() != 0x08);//判断PLL是否是系统时钟
关键字:STM32 RCC配置『本文转载自网络,版权归原作者所有,如有侵权请联系删除』
