在“stm32f10x.h”这个头文件里:
#define HSE_Value ((uint32_t)8000000) /!< Value of the External oscillator in Hz/
斜体内容默认是8000000,在你修改了外部晶振时,要和你的外部晶振数值相同,不如我的外部晶振时24M,我就把它改成24M,这样就可以了,
还有一处要更改是在“system_stm32f10x.c”里:
static void SetSysClockTo72(void)
__IO uint32_t StartUpCounter = 0, HSEStatus = 0;
/!< SYSCLK, HCLK, PCLK2 and PCLK1 configuration —————————/
/!< Enable HSE /
RCC->CR |= ((uint32_t)RCC_CR_HSEON);
/!< Wait till HSE is ready and if Time out is reached exit /
do
HSEStatus = RCC->CR & RCC_CR_HSERDY;
StartUpCounter++;
} while((HSEStatus == 0) && (StartUpCounter != HSEStartUp_TimeOut));
if ((RCC->CR & RCC_CR_HSERDY) != RESET)
HSEStatus = (uint32_t)0x01;
else
HSEStatus = (uint32_t)0x00;
if (HSEStatus == (uint32_t)0x01)
/!< Enable Prefetch Buffer /
FLASH->ACR |= FLASH_ACR_PRFTBE;
/*!< Flash 2 wait state */
FLASH->ACR &= (uint32_t)((uint32_t)~FLASH_ACR_LATENCY);
FLASH->ACR |= (uint32_t)FLASH_ACR_LATENCY_2;
/*!< HCLK = SYSCLK */
RCC->CFGR |= (uint32_t)RCC_CFGR_HPRE_DIV1;//1
/*!< PCLK2 = HCLK */
RCC->CFGR |= (uint32_t)RCC_CFGR_PPRE2_DIV1;//1
/*!< PCLK1 = HCLK */
RCC->CFGR |= (uint32_t)RCC_CFGR_PPRE1_DIV2;//2
/*!< PLLCLK = 8MHz * 9 = 72 MHz */
RCC->CFGR &= (uint32_t)((uint32_t)~(RCC_CFGR_PLLSRC | RCC_CFGR_PLLXTPRE | RCC_CFGR_PLLMULL));
RCC->CFGR |= (uint32_t)(RCC_CFGR_PLLSRC | RCC_CFGR_PLLMULL3 );//RCC_CFGR_PLLMULL9
/*!< Enable PLL */
RCC->CR |= RCC_CR_PLLON;
/*!< Wait till PLL is ready */
while((RCC->CR & RCC_CR_PLLRDY) == 0)
/*!< Select PLL as system clock source */
RCC->CFGR &= (uint32_t)((uint32_t)~(RCC_CFGR_SW));
RCC->CFGR |= (uint32_t)RCC_CFGR_SW_PLL;
/*!< Wait till PLL is used as system clock source */
while ((RCC->CFGR & (uint32_t)RCC_CFGR_SWS) != (uint32_t)0x08)
else
{ /*!< If HSE fails to start-up, the application will have wrong clock
configuration. User can add here some code to deal with this error */
/*!< Go to infinite loop */
while (1)
endif
“RCC->CFGR |= (uint32_t)(RCC_CFGR_PLLSRC | RCC_CFGR_PLLMULL3 );”给成你合适的倍数,不要超频
