一、初始化SysTick
按1ms来设置systick,也可以除以1000000。按1us来设置
SysTick_Config(SystemCoreClock / 1000); //SysTick开启系统tick定时器并初始化其中断,1ms
二、systick的函数
// cycles per microsecond
static volatile uint32_t usTicks = 0;
// current uptime for 1kHz systick timer. will rollover after 49 days. hopefully we won't care.
volatile uint32_t sysTickUptime = 0;
// SysTick
void SysTick_Handler(void)
sysTickUptime++;
//delay ms
void DelayMs(uint16_t nms)
uint32_t t0=micros();
while(micros() - t0 < nms * 1000);
// Return system uptime in microseconds (rollover in 70minutes)
//返回 us
uint32_t micros(void)
register uint32_t ms, cycle_cnt;
do {
ms = sysTickUptime;
cycle_cnt = SysTick->VAL;
} while (ms != sysTickUptime);
return (ms * 1000) + (usTicks * 1000 - cycle_cnt) / usTicks;
// Return system uptime in milliseconds (rollover in 49 days)
uint32_t millis(void)
return sysTickUptime;
systick启动后会进入SysTick_Handler()的中断,
三、少了重要的一部,哭~T.T
开启RCC时钟!!!!!
void cycleCounterInit(void)
RCC_ClocksTypeDef clocks;
RCC_GetClocksFreq(&clocks);
usTicks = clocks.SYSCLK_Frequency / 1000000;
遇到的错误:我在初始化MPU6050时,写入数据特别慢。明明计时都准的,不知道为什么特别慢。其他还都能顺利运行。
最后发现时RCC的时钟有问题。
