#include "linux/kernel.h"
#include "linux/module.h"
#include "linux/i2c.h"
#include "linux/init.h"
#include "linux/time.h"
#include "linux/interrupt.h"
#include "linux/delay.h"
#include "linux/errno.h"
#include "linux/err.h"
#include "linux/platform_device.h"
#include "linux/pm_runtime.h"
#include "linux/clk.h"
#include "linux/cpufreq.h"
#include "linux/slab.h"
#include "linux/io.h"
#include "linux/of_i2c.h"
#include "linux/of_gpio.h"
#include "plat/gpio-cfg.h"
#include "mach/regs-gpio.h"
#include "asm/irq.h"
#include "plat/regs-iic.h"
#include "plat/iic.h"
//#define PRINTK printk
#define PRINTK(...)
enum s3c24xx_i2c_state {
STATE_IDLE,
STATE_START,
STATE_READ,
STATE_WRITE,
STATE_STOP
struct s3c2440_i2c_regs {
unsigned int iiccon;
unsigned int iicstat;
unsigned int iicadd;
unsigned int iicds;
unsigned int iiclc;
struct s3c2440_i2c_xfer_data {
struct i2c_msg *msgs;
int msn_num;
int cur_msg;
int cur_ptr;
int state;
int err;
wait_queue_head_t wait;
static struct s3c2440_i2c_xfer_data s3c2440_i2c_xfer_data;
static struct s3c2440_i2c_regs *s3c2440_i2c_regs;
static void s3c2440_i2c_start(void)
s3c2440_i2c_xfer_data.state = STATE_START;
if (s3c2440_i2c_xfer_data.msgs->flags & I2C_M_RD) // 读 //
s3c2440_i2c_regs->iicds = s3c2440_i2c_xfer_data.msgs->addr << 1;
s3c2440_i2c_regs->iicstat = 0xb0; // 主机接收,启动
else // 写 //
s3c2440_i2c_regs->iicstat = 0xf0; // 主机发送,启动
static void s3c2440_i2c_stop(int err)
s3c2440_i2c_xfer_data.state = STATE_STOP;
s3c2440_i2c_xfer_data.err = err;
PRINTK("STATE_STOP, err = %d\n", err);
// 下面两行恢复I2C操作,发出P信号
s3c2440_i2c_regs->iicstat = 0x90;
s3c2440_i2c_regs->iiccon = 0xaf;
ndelay(50); // 等待一段时间以便P信号已经发出
else // 写 //
// 下面两行用来恢复I2C操作,发出P信号
s3c2440_i2c_regs->iicstat = 0xd0;
// 唤醒 //
wake_up(&s3c2440_i2c_xfer_data.wait);
static int s3c2440_i2c_xfer(struct i2c_adapter *adap,
struct i2c_msg *msgs, int num)
unsigned long timeout;
// 把num个msg的I2C数据发送出去/读进来 //
s3c2440_i2c_xfer_data.msgs = msgs;
s3c2440_i2c_xfer_data.msn_num = num;
s3c2440_i2c_xfer_data.cur_msg = 0;
s3c2440_i2c_xfer_data.cur_ptr = 0;
s3c2440_i2c_xfer_data.err = -ENODEV;
s3c2440_i2c_start();
// 休眠 //
timeout = wait_event_timeout(s3c2440_i2c_xfer_data.wait, (s3c2440_i2c_xfer_data.state == STATE_STOP), HZ * 5);
if (0 == timeout)
printk("s3c2440_i2c_xfer time out\n");
return -ETIMEDOUT;
else
return s3c2440_i2c_xfer_data.err;
static u32 s3c2440_i2c_func(struct i2c_adapter *adap)
return I2C_FUNC_I2C | I2C_FUNC_SMBUS_EMUL | I2C_FUNC_PROTOCOL_MANGLING;
static const struct i2c_algorithm s3c2440_i2c_algo = {
// .smbus_xfer = ,
.master_xfer = s3c2440_i2c_xfer,
.functionality = s3c2440_i2c_func,
// 1. 分配/设置i2c_adapter
static struct i2c_adapter s3c2440_i2c_adapter = {
.name = "s3c2440_100ask",
.algo = &s3c2440_i2c_algo,
.owner = THIS_MODULE,
static int isLastMsg(void)
return (s3c2440_i2c_xfer_data.cur_msg == s3c2440_i2c_xfer_data.msn_num - 1);
static int isEndData(void)
return (s3c2440_i2c_xfer_data.cur_ptr >= s3c2440_i2c_xfer_data.msgs->len);
static int isLastData(void)
return (s3c2440_i2c_xfer_data.cur_ptr == s3c2440_i2c_xfer_data.msgs->len - 1);
static irqreturn_t s3c2440_i2c_xfer_irq(int irq, void *dev_id)
unsigned int iicSt;
iicSt = s3c2440_i2c_regs->iicstat;
if(iicSt & 0x8){ printk("Bus arbitration failed\n\r"); }
switch (s3c2440_i2c_xfer_data.state)
case STATE_START : // 发出S和设备地址后,产生中断 //
PRINTK("Start\n");
// 如果没有ACK, 返回错误 //
if (iicSt & S3C2410_IICSTAT_LASTBIT)
s3c2440_i2c_stop(-ENODEV);
break;
if (isLastMsg() && isEndData())
s3c2440_i2c_stop(0);
break;
// 进入下一个状态 //
s3c2440_i2c_xfer_data.state = STATE_READ;
goto next_read;
else
s3c2440_i2c_xfer_data.state = STATE_WRITE;
case STATE_WRITE:
PRINTK("STATE_WRITE\n");
// 如果没有ACK, 返回错误 //
break;
if (!isEndData()) // 如果当前msg还有数据要发送 //
s3c2440_i2c_regs->iicds = s3c2440_i2c_xfer_data.msgs->buf[s3c2440_i2c_xfer_data.cur_ptr];
s3c2440_i2c_xfer_data.cur_ptr++;
// 将数据写入IICDS后,需要一段时间才能出现在SDA线上
ndelay(50);
s3c2440_i2c_regs->iiccon = 0xaf; // 恢复I2C传输
break;
else if (!isLastMsg())
// 开始处理下一个消息 //
s3c2440_i2c_xfer_data.msgs++;
s3c2440_i2c_xfer_data.cur_msg++;
// 发出START信号和发出设备地址 //
break;
else
// 是最后一个消息的最后一个数据 //
break;
break;
case STATE_READ:
PRINTK("STATE_READ\n");
// 读出数据 //
s3c2440_i2c_xfer_data.msgs->buf[s3c2440_i2c_xfer_data.cur_ptr] = s3c2440_i2c_regs->iicds;
next_read:
if (!isEndData()) // 如果数据没读完, 继续发起读操作 //
if (isLastData()) // 如果即将读的数据是最后一个, 不发ack //
s3c2440_i2c_regs->iiccon = 0x2f; // 恢复I2C传输,接收到下一数据时无ACK
else
s3c2440_i2c_regs->iiccon = 0xaf; // 恢复I2C传输,接收到下一数据时发出ACK
break;
// 开始处理下一个消息 //
break;
else
break;
break;
default: break;
// 清中断 //
s3c2440_i2c_regs->iiccon &= ~(S3C2410_IICCON_IRQPEND);
return IRQ_HANDLED;
* I2C初始化
static void s3c2440_i2c_init(void)
struct clk *clk;
clk = clk_get(NULL, "i2c");
clk_enable(clk);
// 选择引脚功能:GPE15:IICSDA, GPE14:IICSCL
s3c_gpio_cfgpin(S3C2410_GPE(14), S3C2410_GPE14_IICSCL);
s3c_gpio_cfgpin(S3C2410_GPE(15), S3C2410_GPE15_IICSDA);
// bit[7] = 1, 使能ACK
* bit[6] = 0, IICCLK = PCLK/16
* bit[5] = 1, 使能中断
* bit[3:0] = 0xf, Tx clock = IICCLK/16
* PCLK = 50MHz, IICCLK = 3.125MHz, Tx Clock = 0.195MHz
s3c2440_i2c_regs->iiccon = (1<<7) | (0<<6) | (1<<5) | (0xf); // 0xaf
s3c2440_i2c_regs->iicadd = 0x10; // S3C24xx slave address = [7:1]
s3c2440_i2c_regs->iicstat = 0x10; // I2C串行输出使能(Rx/Tx)
static int i2c_bus_s3c2440_init(void)
// 2. 硬件相关的设置 //
s3c2440_i2c_regs = ioremap(0x54000000, sizeof(struct s3c2440_i2c_regs));
s3c2440_i2c_init();
request_irq(IRQ_IIC, s3c2440_i2c_xfer_irq, 0, "s3c2440-i2c", NULL);
init_waitqueue_head(&s3c2440_i2c_xfer_data.wait);
// 3. 注册i2c_adapter //
i2c_add_adapter(&s3c2440_i2c_adapter);
return 0;
static void i2c_bus_s3c2440_exit(void)
i2c_del_adapter(&s3c2440_i2c_adapter);
free_irq(IRQ_IIC, NULL);
iounmap(s3c2440_i2c_regs);
module_init(i2c_bus_s3c2440_init);
module_exit(i2c_bus_s3c2440_exit);
MODULE_LICENSE("GPL");
解析:
编写"总线(适配器adapter)"驱动
Device Drivers
I2C support
I2C Hardware Bus support
< > S3C2410 I2C Driver
nfs 30000000 192.168.1.123:/work/nfs_root/uImage_noi2cbus; bootm 30000000
应用程序发送消息出去时,会调用适配器adapter里面的算法函数algo里面的master_xfer函数,先把消息记录下来之后调用start函数,start函数里发送start启动信号并且把设备地址发送出去,然后休眠。发送完之后产生一个中断,在中断函数里面读出状态,如果没有ack的话认为发生错误发出停止信号唤醒应用程序;如果有ack信号而且是最后一个消息,最后一个数据则发出停止信号,否则进入下一个状态读/写,如果是写判断是否是最后一个数据,若还有数据要发送把数据发送出去,若是最后一个数据但是不是最后一个消息的话开始处理下一个消息,发出start信号和设备地址,若是最后一个消息的最后一个数据则发出停止信号;如果是读判断数据是否读完,如果没有读完但是接收到的不是最后一个数据则发送ack信号,若接收到最后一个数据否则无ack,但若数据已经读完则处理下一个消息发送start信号。
