一、卡尔曼滤波九轴融合算法stm32尝试
1、Kalman滤波文件[.h已经封装为结构体]
1 /* Copyright (C) 2012 Kristian Lauszus, TKJ Electronics-> All rights reserved->
3 This software may be distributed and modified under the terms of the GNU
4 General Public License version 2 (GPL2) as published by the Free Software
5 Foundation and appearing in the file GPL2->TXT included in the packaging of
6 this file-> Please note that GPL2 Section 2[b] requires that all works based
7 on this software must also be made publicly available under the terms of
8 the GPL2 ("Copyleft")->
9
10 Contact information
11 -------------------
12
13 Kristian Lauszus, TKJ Electronics
14 Web : http://www->tkjelectronics->com
15 e-mail : kristianl@tkjelectronics->com
16 */
17
18 #ifndef _Kalman_h
19 #define _Kalman_h
20 struct Kalman {
21 /* Kalman filter variables */
22 double Q_angle; // Process noise variance for the accelerometer
23 double Q_bias; // Process noise variance for the gyro bias
24 double R_measure; // Measurement noise variance - this is actually the variance of the measurement noise
25
26 double angle; // The angle calculated by the Kalman filter - part of the 2x1 state vector
27 double bias; // The gyro bias calculated by the Kalman filter - part of the 2x1 state vector
28 double rate; // Unbiased rate calculated from the rate and the calculated bias - you have to call getAngle to update the rate
29
30 double P[2][2]; // Error covariance matrix - This is a 2x2 matrix
31 double K[2]; // Kalman gain - This is a 2x1 vector
32 double y; // Angle difference
33 double S; // Estimate error
34 };
35
36 void Init(struct Kalman* klm){
37 /* We will set the variables like so, these can also be tuned by the user */
38 klm->Q_angle = 0.001;
39 klm->Q_bias = 0.003;
40 klm->R_measure = 0.03;
41
42 klm->angle = 0; // Reset the angle
43 klm->bias = 0; // Reset bias
44
45 klm->P[0][0] = 0; // Since we assume that the bias is 0 and we know the starting angle (use setAngle), the error covariance matrix is set like so - see: http://en->wikipedia->org/wiki/Kalman_filter#Example_application->2C_technical
46 klm->P[0][1] = 0;
47 klm->P[1][0] = 0;
48 klm->P[1][1] = 0;
49 }
50
51 // The angle should be in degrees and the rate should be in degrees per second and the delta time in seconds
52 double getAngle(struct Kalman * klm, double newAngle, double newRate, double dt) {
53 // KasBot V2 - Kalman filter module - http://www->x-firm->com/?page_id=145
54 // Modified by Kristian Lauszus
55 // See my blog post for more information: http://blog->tkjelectronics->dk/2012/09/a-practical-approach-to-kalman-filter-and-how-to-implement-it
56
57 // Discrete Kalman filter time update equations - Time Update ("Predict")
58 // Update xhat - Project the state ahead
59 /* Step 1 */
60 klm->rate = newRate - klm->bias;
61 klm->angle += dt * klm->rate;
62
63 // Update estimation error covariance - Project the error covariance ahead
64 /* Step 2 */
65 klm->P[0][0] += dt * (dt*klm->P[1][1] - klm->P[0][1] - klm->P[1][0] + klm->Q_angle);
66 klm->P[0][1] -= dt * klm->P[1][1];
67 klm->P[1][0] -= dt * klm->P[1][1];
68 klm->P[1][1] += klm->Q_bias * dt;
69
70 // Discrete Kalman filter measurement update equations - Measurement Update ("Correct")
71 // Calculate Kalman gain - Compute the Kalman gain
72 /* Step 4 */
73 klm->S = klm->P[0][0] + klm->R_measure;
74 /* Step 5 */
75 klm->K[0] = klm->P[0][0] / klm->S;
76 klm->K[1] = klm->P[1][0] / klm->S;
77
78 // Calculate angle and bias - Update estimate with measurement zk (newAngle)
79 /* Step 3 */
80 klm->y = newAngle - klm->angle;
81 /* Step 6 */
82 klm->angle += klm->K[0] * klm->y;
83 klm->bias += klm->K[1] * klm->y;
84
85 // Calculate estimation error covariance - Update the error covariance
86 /* Step 7 */
87 klm->P[0][0] -= klm->K[0] * klm->P[0][0];
88 klm->P[0][1] -= klm->K[0] * klm->P[0][1];
89 klm->P[1][0] -= klm->K[1] * klm->P[0][0];
90 klm->P[1][1] -= klm->K[1] * klm->P[0][1];
91
92 return klm->angle;
93 }
94
95 void setAngle(struct Kalman* klm, double newAngle) { klm->angle = newAngle; } // Used to set angle, this should be set as the starting angle
96 double getRate(struct Kalman* klm) { return klm->rate; } // Return the unbiased rate
97
98 /* These are used to tune the Kalman filter */
99 void setQangle(struct Kalman* klm, double newQ_angle) { klm->Q_angle = newQ_angle; }
100 void setQbias(struct Kalman* klm, double newQ_bias) { klm->Q_bias = newQ_bias; }
101 void setRmeasure(struct Kalman* klm, double newR_measure) { klm->R_measure = newR_measure; }
102
103 double getQangle(struct Kalman* klm) { return klm->Q_angle; }
104 double getQbias(struct Kalman* klm) { return klm->Q_bias; }
105 double getRmeasure(struct Kalman* klm) { return klm->R_measure; }
106
2、I2C总线代码[这里把MPU和HMC挂接到上面,通过改变SlaveAddress的值来和不同的设备通信]
1 #include "stm32f10x.h"
3 /*标志是否读出数据*/
4 char test=0;
5 /*I2C从设备*/
6 unsigned char SlaveAddress;
7 /*模拟IIC端口输出输入定义*/
8 #define SCL_H GPIOB->BSRR = GPIO_Pin_10
9 #define SCL_L GPIOB->BRR = GPIO_Pin_10
10 #define SDA_H GPIOB->BSRR = GPIO_Pin_11
11 #define SDA_L GPIOB->BRR = GPIO_Pin_11
12 #define SCL_read GPIOB->IDR & GPIO_Pin_10
13 #define SDA_read GPIOB->IDR & GPIO_Pin_11
14
15 /*I2C的端口初始化---------------------------------------*/
16 void I2C_GPIO_Config(void)
17 {
18 GPIO_InitTypeDef GPIO_InitStructure;
19
20 GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;
21 GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
22 GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_OD;
23 GPIO_Init(GPIOB, &GPIO_InitStructure);
24
25 GPIO_InitStructure.GPIO_Pin = GPIO_Pin_11;
26 GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
27 GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_OD;
28 GPIO_Init(GPIOB, &GPIO_InitStructure);
29 }
30
31 /*I2C的延时函数-----------------------------------------*/
32 void I2C_delay(void)
33 {
34 u8 i=30; //这里可以优化速度 ,经测试最低到5还能写入
35 while(i)
36 {
37 i--;
38 }
39 }
40
41 /*I2C的等待5ms函数--------------------------------------*/
42 void delay5ms(void)
43 {
44 int i=5000;
45 while(i)
46 {
47 i--;
48 }
49 }
50
51 /*I2C启动函数-------------------------------------------*/
52 bool I2C_Start(void)
53 {
54 SDA_H;
55 SCL_H;
56 I2C_delay();
57 if(!SDA_read)return FALSE; //SDA线为低电平则总线忙,退出
58 SDA_L;
59 I2C_delay();
60 if(SDA_read) return FALSE; //SDA线为高电平则总线出错,退出
61 SDA_L;
62 I2C_delay();
63 return TRUE;
64 }
65
66 /*I2C停止函数-------------------------------------------*/
67 void I2C_Stop(void)
68 {
69 SCL_L;
70 I2C_delay();
71 SDA_L;
72 I2C_delay();
73 SCL_H;
74 I2C_delay();
75 SDA_H;
76 I2C_delay();
77 }
78
79 /*I2C的ACK函数------------------------------------------*/
80 void I2C_Ack(void)
81 {
82 SCL_L;
83 I2C_delay();
84 SDA_L;
85 I2C_delay();
86 SCL_H;
87 I2C_delay();
88 SCL_L;
89 I2C_delay();
90 }
91
92 /*I2C的NoACK函数----------------------------------------*/
93 void I2C_NoAck(void)
94 {
95 SCL_L;
96 I2C_delay();
97 SDA_H;
98 I2C_delay();
99 SCL_H;
100 I2C_delay();
101 SCL_L;
102 I2C_delay();
103 }
104
105 /*I2C等待ACK函数----------------------------------------*/
106 bool I2C_WaitAck(void) //返回为:=1有ACK,=0无ACK
107 {
108 SCL_L;
109 I2C_delay();
110 SDA_H;
111 I2C_delay();
112 SCL_H;
113 I2C_delay();
114 if(SDA_read)
115 {
116 SCL_L;
117 I2C_delay();
118 return FALSE;
119 }
120 SCL_L;
121 I2C_delay();
122 return TRUE;
123 }
124
125 /*I2C发送一个u8数据函数---------------------------------*/
126 void I2C_SendByte(u8 SendByte) //数据从高位到低位//
127 {
128 u8 i=8;
129 while(i--)
130 {
131 SCL_L;
132 I2C_delay();
133 if(SendByte&0x80)
134 SDA_H;
135 else
136 SDA_L;
137 SendByte<<=1;
138 I2C_delay();
139 SCL_H;
140 I2C_delay();
141 }
142 SCL_L;
143 }
144
145 /*I2C读取一个u8数据函数---------------------------------*/
146 unsigned char I2C_RadeByte(void) //数据从高位到低位//
147 {
148 u8 i=8;
149 u8 ReceiveByte=0;
150
151 SDA_H;
152 while(i--)
153 {
154 ReceiveByte<<=1;
155 SCL_L;
156 I2C_delay();
157 SCL_H;
158 I2C_delay();
159 if(SDA_read)
160 {
161 ReceiveByte|=0x01;
162 }
163 }
164 SCL_L;
165 return ReceiveByte;
166 }
167
168 /*I2C向指定设备指定地址写入u8数据-----------------------*/
169 void Single_WriteI2C(unsigned char REG_Address,unsigned char REG_data)//单字节写入
170 {
171 if(!I2C_Start())return;
172 I2C_SendByte(SlaveAddress); //发送设备地址+写信号//I2C_SendByte(((REG_Address & 0x0700) >>7) | SlaveAddress & 0xFFFE);//设置高起始地址+器件地址
173 if(!I2C_WaitAck()){I2C_Stop(); return;}
174 I2C_SendByte(REG_Address ); //设置低起始地址
175 I2C_WaitAck();
176 I2C_SendByte(REG_data);
177 I2C_WaitAck();
178 I2C_Stop();
179 delay5ms();
180 }
181
182 /*I2C向指定设备指定地址读出u8数据-----------------------*/
183 unsigned char Single_ReadI2C(unsigned char REG_Address)//读取单字节
184 {
185 unsigned char REG_data;
186 if(!I2C_Start())return FALSE;
187 I2C_SendByte(SlaveAddress); //I2C_SendByte(((REG_Address & 0x0700) >>7) | REG_Address & 0xFFFE);//设置高起始地址+器件地址
188 if(!I2C_WaitAck()){I2C_Stop();test=1; return FALSE;}
189 I2C_SendByte((u8) REG_Address); //设置低起始地址
190 I2C_WaitAck();
191 I2C_Start();
192 I2C_SendByte(SlaveAddress+1);
193 I2C_WaitAck();
194
195 REG_data= I2C_RadeByte();
196 I2C_NoAck();
197 I2C_Stop();
198 //return TRUE;
199 return REG_data;
200 }
3、MPU6050的驱动代码[updataMPU6050中获取数据为什么一正一负不是很清楚,是按照GitHub上arduino版本改的]
1 #define SlaveAddressMPU 0x68 //定义器件5883在IIC总线中的从地址
3 typedef unsigned char uchar;
5 extern int accX, accY, accZ;
6 extern int gyroX, gyroY, gyroZ;
7 extern uchar SlaveAddress; //IIC写入时的地址字节数据,+1为读取
8 extern uchar Single_ReadI2C(uchar REG_Address); //读取I2C数据
9 extern void Single_WriteI2C(uchar REG_Address,uchar REG_data); //向I2C写入数据
10
11 //****************************************
12 // 定义MPU6050内部地址
13 //****************************************
14 #define SMPLRT_DIV 0x19 //陀螺仪采样率,典型值:0x07(125Hz)
15 #define CONFIG 0x1A //低通滤波频率,典型值:0x06(5Hz)
16 #define GYRO_CONFIG 0x1B //陀螺仪自检及测量范围,典型值:0x18(不自检,2000deg/s)
17 #define ACCEL_CONFIG 0x1C //加速计自检、测量范围及高通滤波频率,典型值:0x01(不自检,2G,5Hz)
18 #define ACCEL_XOUT_H 0x3B
19 #define ACCEL_XOUT_L 0x3C
20 #define ACCEL_YOUT_H 0x3D
21 #define ACCEL_YOUT_L 0x3E
22 #define ACCEL_ZOUT_H 0x3F
23 #define ACCEL_ZOUT_L 0x40
24 #define TEMP_OUT_H 0x41
25 #define TEMP_OUT_L 0x42
26 #define GYRO_XOUT_H 0x43
27 #define GYRO_XOUT_L 0x44
28 #define GYRO_YOUT_H 0x45
29 #define GYRO_YOUT_L 0x46
30 #define GYRO_ZOUT_H 0x47
31 #define GYRO_ZOUT_L 0x48
32 #define PWR_MGMT_1 0x6B //电源管理,典型值:0x00(正常启用)
33 #define WHO_AM_I 0x75 //IIC地址寄存器(默认数值0x68,只读)
34 #define MPU6050_Addr 0xD0 //IIC写入时的地址字节数据,+1为读取
35 //**************************************
36 //初始化MPU6050
37 //**************************************
38 void InitMPU6050()
39 {
40 SlaveAddress=MPU6050_Addr;
41 Single_WriteI2C(PWR_MGMT_1, 0x00); //解除休眠状态
42 Single_WriteI2C(SMPLRT_DIV, 0x07);// Set the sample rate to 1000Hz - 8kHz/(7+1) = 1000Hz
43 Single_WriteI2C(CONFIG, 0x00);// Disable FSYNC and set 260 Hz Acc filtering, 256 Hz Gyro filtering, 8 KHz sampling
44 Single_WriteI2C(GYRO_CONFIG, 0x00);// Set Gyro Full Scale Range to ±250deg/s
45 Single_WriteI2C(ACCEL_CONFIG, 0x00);// Set Accelerometer Full Scale Range to ±2g
46 Single_WriteI2C(PWR_MGMT_1, 0x01);// PLL with X axis gyroscope reference and disable sleep mode
47 }
48 //**************************************
49 //// Get accelerometer and gyroscope values
50 //**************************************
51 void updateMPU6050()
52 {
53 SlaveAddress=MPU6050_Addr;// Get accelerometer and gyroscope values
54
55 accX=((Single_ReadI2C(ACCEL_XOUT_H)<<8)+Single_ReadI2C(ACCEL_XOUT_L));
56 accY=-((Single_ReadI2C(ACCEL_YOUT_H)<<8)+Single_ReadI2C(ACCEL_YOUT_L));
57 accZ=((Single_ReadI2C(ACCEL_ZOUT_H)<<8)+Single_ReadI2C(ACCEL_ZOUT_L));
58
59 gyroX=-((Single_ReadI2C(GYRO_XOUT_H)<<8)+Single_ReadI2C(GYRO_XOUT_L));
60 gyroY=((Single_ReadI2C(GYRO_YOUT_H)<<8)+Single_ReadI2C(GYRO_YOUT_L));
61 gyroZ=-((Single_ReadI2C(GYRO_ZOUT_H)<<8)+Single_ReadI2C(GYRO_ZOUT_L));
62 }
4、HMC5883的驱动代码[updataHMC5883直接获取源数据,并未做大的处理]
1 #define uchar unsigned char
2 #define uint unsigned int
4 //定义器件在IIC总线中的从地址,根据ALT ADDRESS地址引脚不同修改
5 #define HMC5883_Addr 0x3C //磁场传感器器件地址
7 unsigned char BUF[8]; //接收数据缓存区
8 extern uchar SlaveAddress; //IIC写入时的地址字节数据,+1为读取
9
10 extern int magX, magY, magZ; //hmc最原始数据
11 extern uchar SlaveAddress; //IIC写入时的地址字节数据,+1为读取
12 extern uchar Single_ReadI2C(uchar REG_Address); //读取I2C数据
13 extern void Single_WriteI2C(uchar REG_Address,uchar REG_data); //向I2C写入数据
14 //**************************************
15 //初始化HMC5883,根据需要请参考pdf进行修改
16 //**************************************
17 void InitHMC5883()
18 {
19 SlaveAddress=HMC5883_Addr;
20 Single_WriteI2C(0x02,0x00); //
21 Single_WriteI2C(0x01,0xE0); //
22 }
23 //**************************************
24 //从HMC5883连续读取6个数据放在BUF中
25 //**************************************
26 void updateHMC5883()
27 {
28 SlaveAddress=HMC5883_Addr;
29 Single_WriteI2C(0x00,0x14);
30 Single_WriteI2C(0x02,0x00);
31 // Delayms(10);
32
33 BUF[1]=Single_ReadI2C(0x03);//OUT_X_L_A
34 BUF[2]=Single_ReadI2C(0x04);//OUT_X_H_A
35 BUF[3]=Single_ReadI2C(0x07);//OUT_Y_L_A
36 BUF[4]=Single_ReadI2C(0x08);//OUT_Y_H_A
37 BUF[5]=Single_ReadI2C(0x05);//OUT_Z_L_A
38 BUF[6]=Single_ReadI2C(0x06);//OUT_Y_H_A
39
40 magX=(BUF[1] << 8) | BUF[2]; //Combine MSB and LSB of X Data output register
41 magY=(BUF[3] << 8) | BUF[4]; //Combine MSB and LSB of Y Data output register
42 magZ=(BUF[5] << 8) | BUF[6]; //Combine MSB and LSB of Z Data output register
43
44 // if(magX>0x7fff)magX-=0xffff;//补码表示滴~所以要转化一下
45 // if(magY>0x7fff)magY-=0xffff;
46 // if(magZ>0x7fff)magZ-=0xffff;
47 }
5、USART简单的单字节发送的串口驱动文件
3 void USART1_Configuration(void);
4 void USART1_SendData(u8 SendData);
5 extern void Delayms(vu32 m);
7 void USART1_Configuration()
8 {
9 GPIO_InitTypeDef GPIO_InitStructure;
10 USART_InitTypeDef USART_InitStructure;
11 USART_ClockInitTypeDef USART_ClockInitStructure;
12
13 RCC_APB2PeriphClockCmd( RCC_APB2Periph_GPIOA | RCC_APB2Periph_GPIOB ,ENABLE );//| RCC_APB2Periph_GPIOC | RCC_APB2Periph_GPIOD, ENABLE );
14 RCC_APB2PeriphClockCmd(RCC_APB2Periph_TIM1 |RCC_APB2Periph_USART1, ENABLE );
15
16 /* Configure USART1 Tx (PA.09) as alternate function push-pull */
17 GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9; // 选中管脚9
18 GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; // 复用推挽输出
19 GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; // 最高输出速率50MHz
20 GPIO_Init(GPIOA, &GPIO_InitStructure); // 选择A端口
21
22 /* Configure USART1 Rx (PA.10) as input floating */
23 GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10; //选中管脚10
24 GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING; //浮空输入
25 GPIO_Init(GPIOA, &GPIO_InitStructure); //选择A端口
26
27
28 USART_ClockInitStructure.USART_Clock = USART_Clock_Disable; // 时钟低电平活动
29 USART_ClockInitStructure.USART_CPOL = USART_CPOL_Low; // 时钟低电平
30 USART_ClockInitStructure.USART_CPHA = USART_CPHA_2Edge; // 时钟第二个边沿进行数据捕获
31 USART_ClockInitStructure.USART_LastBit = USART_LastBit_Disable; // 最后一位数据的时钟脉冲不从SCLK输出
32 /* Configure the USART1 synchronous paramters */
33 USART_ClockInit(USART1, &USART_ClockInitStructure); // 时钟参数初始化设置
34
35 USART_InitStructure.USART_BaudRate = 9600; // 波特率为:115200
36 USART_InitStructure.USART_WordLength = USART_WordLength_8b; // 8位数据
37 USART_InitStructure.USART_StopBits = USART_StopBits_1; // 在帧结尾传输1个停止位
38 USART_InitStructure.USART_Parity = USART_Parity_No ; // 奇偶失能
39 USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None; // 硬件流控制失能
40
41 USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx; // 发送使能+接收使能
42 /* Configure USART1 basic and asynchronous paramters */
43 USART_Init(USART1, &USART_InitStructure);
44
45 /* Enable USART1 */
46 USART_ClearFlag(USART1, USART_IT_RXNE); //清中断,以免一启用中断后立即产生中断
47 USART_ITConfig(USART1,USART_IT_RXNE, ENABLE); //使能USART1中断源
48 USART_Cmd(USART1, ENABLE); //USART1总开关:开启
49 }
50 void USART1_SendData(u8 SendData)
51 {
52 USART_SendData(USART1, SendData);
53 while(USART_GetFlagStatus(USART1, USART_FLAG_TC)==RESET);
54 }
6、非精确延时函数集[其他文件所需的一些延时放在这里]
4 void Delay(vu32 nCount)
5 {
6 for(; nCount != 0; nCount--);
7 }
8 void Delayms(vu32 m)
9 {
10 u32 i;
11 for(; m != 0; m--)
12 for (i=0; i<50000; i++);
13 }
7、main函数文件
2 #include "Kalman.h"
3 #include
4 #define RESTRICT_PITCH // Comment out to restrict roll to ±90deg instead - please read: http://www.freescale.com/files/sensors/doc/app_note/AN3461.pdf
6 struct Kalman kalmanX, kalmanY, kalmanZ; // Create the Kalman instances
8 /* IMU Data MPU6050 AND HMC5883 Data*/
9 int accX, accY, accZ;
10 int gyroX, gyroY, gyroZ;
11 int magX, magY, magZ;
12
13
14 double roll, pitch, yaw; // Roll and pitch are calculated using the accelerometer while yaw is calculated using the magnetometer
15
16 double gyroXangle, gyroYangle, gyroZangle; // Angle calculate using the gyro only 只用陀螺仪计算角度
17 double compAngleX, compAngleY, compAngleZ; // Calculated angle using a complementary filter 用电磁计计算角度
18 double kalAngleX, kalAngleY, kalAngleZ; // Calculated angle using a Kalman filter 用kalman计算角度
19
20 //uint32_t timer,micros; //上一次时间与当前时间
21 uint8_t i2cData[14]; // Buffer for I2C data
22
23 #define MAG0MAX 603
24 #define MAG0MIN -578
25
26 #define MAG1MAX 542
27 #define MAG1MIN -701
28
29 #define MAG2MAX 547
30 #define MAG2MIN -556
31
32 #define RAD_TO_DEG 57.295779513082320876798154814105 // 弧度转角度的转换率
33 #define DEG_TO_RAD 0.01745329251994329576923690768489 // 角度转弧度的转换率
34
35 float magOffset[3] = { (MAG0MAX + MAG0MIN) / 2, (MAG1MAX + MAG1MIN) / 2, (MAG2MAX + MAG2MIN) / 2 };
36 double magGain[3];
37
38 void SYSTICK_Configuration(void); //系统滴答中断配置
39 void RCC_Configuration(void);
40 void updatePitchRoll(void); //根据加速计刷新Pitch和Roll数据
41 void updateYaw(void); //根据磁力计刷新Yaw角
42 void InitAll(void); //循环前的初始化
43 void func(void); //循环里的内容
44 extern void InitMPU6050(void); //初始化MPU6050
45 extern void InitHMC5883(void); //初始化HMC5883
46 extern void updateMPU6050(void); //Get accelerometer and gyroscope values
47 extern void updateHMC5883(void); //Get magnetometer values
48 extern void USART1_Configuration(void); //串口初始化
49 extern void USART1_SendData(u8 SendData); //串口发送函数
50 extern void I2C_GPIO_Config(void); //I2C初始化函数
51 /****************************************************************************
52 * 名 称:int main(void)
53 * 功 能:主函数
54 * 入口参数:无
55 * 出口参数:无
56 * 说 明:
57 * 调用方法:无
58 ****************************************************************************/
59 int main(void)
60 {
61 RCC_Configuration(); //系统时钟配置
62 USART1_Configuration();
63 I2C_GPIO_Config();
64 InitHMC5883();
65 InitMPU6050();
66 InitAll();
67 // SYSTICK_Configuration();
68 while(1)
69 {
70 func();
71 }
72 }
73 ///*
74 //系统滴答中断配置
75 //*/
76 //void SYSTICK_Configuration(void)
77 //{
78 // micros=0;//全局计数时间归零
79 // if (SysTick_Config(72000)) //时钟节拍中断时1000ms一次 用于定时
80 // {
81 // /* Capture error */
82 //// while (1);
83 // }
84 //}
85 ///*
86 //当前时间++.为了防止溢出当其大于2^20时,令其归零
87 //*/
88 //void SysTickHandler(void)
89 //{
90 // micros++;
91 // if(micros>(1<<20))
92 // micros=0;
93 //}
94 /****************************************************************************
95 * 名 称:void RCC_Configuration(void)
96 * 功 能:系统时钟配置为72MHZ
97 * 入口参数:无
98 * 出口参数:无
99 * 说 明:
100 * 调用方法:无
101 ****************************************************************************/
102 void RCC_Configuration(void)
103 {
104 SystemInit();
105 }
106
107 void InitAll()
108 {
109 /* Set Kalman and gyro starting angle */
110 updateMPU6050();
111 updateHMC5883();
112 updatePitchRoll();
113 updateYaw();
114
115 setAngle(&kalmanX,roll); // First set roll starting angle
116 gyroXangle = roll;
117 compAngleX = roll;
118
119 setAngle(&kalmanY,pitch); // Then pitch
120 gyroYangle = pitch;
121 compAngleY = pitch;
122
123 setAngle(&kalmanZ,yaw); // And finally yaw
124 gyroZangle = yaw;
125 compAngleZ = yaw;
126
127 // timer = micros; // Initialize the timer
128 }
129
130 void send(double xx,double yy,double zz)
131 {
132 int a[3];
133 u8 i,sendData[12];
134 a[0]=(int)xx;a[1]=(int)yy;a[2]=(int)zz;
135 for(i=0;i<3;i++)
136 {
137 if(a[i]<0){
138 sendData[i*4]='-';
139 a[i]=-a[i];
140 }
141 else sendData[i*4]=' ';
142 sendData[i*4+1]=(u8)(a[i]%1000/100+0x30);
143 sendData[i*4+2]=(u8)(a[i]%100/10+0x30);
144 sendData[i*4+3]=(u8)(a[i]%10+0x30);
145 }
146 for(i=0;i<12;i++)
147 {
148 USART1_SendData(sendData[i]);
149 }
150 USART1_SendData(0x0D);
151 USART1_SendData(0x0A);
152 }
153
154 void func()
155 {
156 double gyroXrate,gyroYrate,gyroZrate,dt=0.01;
157 /* Update all the IMU values */
158 updateMPU6050();
159 updateHMC5883();
160
161 // dt = (double)(micros - timer) / 1000; // Calculate delta time
162 // timer = micros;
163 // if(dt<0)dt+=(1<<20); //时间是周期性的,有可能当前时间小于上次时间,因为这个周期远大于两次积分时间,所以最多相差1<<20
164
165 /* Roll and pitch estimation */
166 updatePitchRoll(); //用采集的加速计的值计算roll和pitch的值
167 gyroXrate = gyroX / 131.0; // Convert to deg/s 把陀螺仪的角加速度按照当初设定的量程转换为°/s
168 gyroYrate = gyroY / 131.0; // Convert to deg/s
169
170 #ifdef RESTRICT_PITCH //如果上面有#define RESTRICT_PITCH就采用这种方法计算,防止出现-180和180之间的跳跃
171 // This fixes the transition problem when the accelerometer angle jumps between -180 and 180 degrees
172 if ((roll < -90 && kalAngleX > 90) || (roll > 90 && kalAngleX < -90)) {
173 setAngle(&kalmanX,roll);
174 compAngleX = roll;
175 kalAngleX = roll;
176 gyroXangle = roll;
177 } else
178 kalAngleX = getAngle(&kalmanX, roll, gyroXrate, dt); // Calculate the angle using a Kalman filter
179
180 if (fabs(kalAngleX) > 90)
181 gyroYrate = -gyroYrate; // Invert rate, so it fits the restricted accelerometer reading
182 kalAngleY = getAngle(&kalmanY,pitch, gyroYrate, dt);
183 #else
184 // This fixes the transition problem when the accelerometer angle jumps between -180 and 180 degrees
185 if ((pitch < -90 && kalAngleY > 90) || (pitch > 90 && kalAngleY < -90)) {
186 kalmanY.setAngle(pitch);
187 compAngleY = pitch;
188 kalAngleY = pitch;
189 gyroYangle = pitch;
190 } else
191 kalAngleY = getAngle(&kalmanY, pitch, gyroYrate, dt); // Calculate the angle using a Kalman filter
192
193 if (abs(kalAngleY) > 90)
194 gyroXrate = -gyroXrate; // Invert rate, so it fits the restricted accelerometer reading
195 kalAngleX = getAngle(&kalmanX, roll, gyroXrate, dt); // Calculate the angle using a Kalman filter
196 #endif
197
198
199 /* Yaw estimation */
200 updateYaw();
201 gyroZrate = gyroZ / 131.0; // Convert to deg/s
202 // This fixes the transition problem when the yaw angle jumps between -180 and 180 degrees
203 if ((yaw < -90 && kalAngleZ > 90) || (yaw > 90 && kalAngleZ < -90)) {
204 setAngle(&kalmanZ,yaw);
205 compAngleZ = yaw;
206 kalAngleZ = yaw;
207 gyroZangle = yaw;
208 } else
209 kalAngleZ = getAngle(&kalmanZ, yaw, gyroZrate, dt); // Calculate the angle using a Kalman filter
210
211
212 /* Estimate angles using gyro only */
213 gyroXangle += gyroXrate * dt; // Calculate gyro angle without any filter
214 gyroYangle += gyroYrate * dt;
215 gyroZangle += gyroZrate * dt;
216 //gyroXangle += kalmanX.getRate() * dt; // Calculate gyro angle using the unbiased rate from the Kalman filter
217 //gyroYangle += kalmanY.getRate() * dt;
218 //gyroZangle += kalmanZ.getRate() * dt;
219
220 /* Estimate angles using complimentary filter */
221 compAngleX = 0.93 * (compAngleX + gyroXrate * dt) + 0.07 * roll; // Calculate the angle using a Complimentary filter
222 compAngleY = 0.93 * (compAngleY + gyroYrate * dt) + 0.07 * pitch;
223 compAngleZ = 0.93 * (compAngleZ + gyroZrate * dt) + 0.07 * yaw;
224
225 // Reset the gyro angles when they has drifted too much
226 if (gyroXangle < -180 || gyroXangle > 180)
227 gyroXangle = kalAngleX;
228 if (gyroYangle < -180 || gyroYangle > 180)
229 gyroYangle = kalAngleY;
230 if (gyroZangle < -180 || gyroZangle > 180)
231 gyroZangle = kalAngleZ;
232
233
234 send(roll,pitch,yaw);
235 // send(gyroXangle,gyroYangle,gyroZangle);
236 // send(compAngleX,compAngleY,compAngleZ);
237 // send(kalAngleX,kalAngleY,kalAngleZ);
238 // send(kalAngleY,compAngleY,gyroYangle);
239
240
241 /* Print Data */
242 // //#if 1
243 // printf("%lf %lf %lf %lf\n",roll,gyroXangle,compAngleX,kalAngleX);
244 // printf("%lf %lf %lf %lf\n",pitch,gyroYangle,compAngleY,kalAngleY);
245 // printf("%lf %lf %lf %lf\n",yaw,gyroZangle,compAngleZ,kalAngleZ);
246 //#endif
247
248 // //#if 0 // Set to 1 to print the IMU data
249 // printf("%lf %lf %lf\n",accX / 16384.0,accY / 16384.0,accZ / 16384.0);
250 // printf("%lf %lf %lf\n",gyroXrate,gyroYrate,gyroZrate);
251 // printf("%lf %lf %lf\n",magX,magY,magZ);
252 //#endif
253
254 //#if 0 // Set to 1 to print the temperature
255 //Serial.print("\t");
256 //
257 //double temperature = (double)tempRaw / 340.0 + 36.53;
258 //Serial.print(temperature); Serial.print("\t");
259 //#endif
260 // delay(10);
261 }
262
263 //****************************************
264 //根据加速计刷新Pitch和Roll数据
265 //这里采用两种方法计算roll和pitch,如果最上面没有#define RESTRICT_PITCH就采用第二种计算方法
266 //****************************************
267 void updatePitchRoll() {
268 // Source: http://www.freescale.com/files/sensors/doc/app_note/AN3461.pdf eq. 25 and eq. 26
269 // atan2 outputs the value of -π to π (radians) - see http://en.wikipedia.org/wiki/Atan2
270 // It is then converted from radians to degrees
271 #ifdef RESTRICT_PITCH // Eq. 25 and 26
272 roll = atan2(accY,accZ) * RAD_TO_DEG;
273 pitch = atan(-accX / sqrt(accY * accY + accZ * accZ)) * RAD_TO_DEG;
274 #else // Eq. 28 and 29
275 roll = atan(accY / sqrt(accX * accX + accZ * accZ)) * RAD_TO_DEG;
276 pitch = atan2(-accX, accZ) * RAD_TO_DEG;
277 #endif
278 }
279 //****************************************
280 //根据磁力计刷新Yaw角
281 //****************************************
282 void updateYaw() { // See: http://www.freescale.com/files/sensors/doc/app_note/AN4248.pdf
283 double rollAngle,pitchAngle,Bfy,Bfx;
284
285 magX *= -1; // Invert axis - this it done here, as it should be done after the calibration
286 magZ *= -1;
287
288 magX *= magGain[0];
289 magY *= magGain[1];
290 magZ *= magGain[2];
291
292 magX -= magOffset[0];
293 magY -= magOffset[1];
294 magZ -= magOffset[2];
295
296
297 rollAngle = kalAngleX * DEG_TO_RAD;
298 pitchAngle = kalAngleY * DEG_TO_RAD;
299
300 Bfy = magZ * sin(rollAngle) - magY * cos(rollAngle);
301 Bfx = magX * cos(pitchAngle) + magY * sin(pitchAngle) * sin(rollAngle) + magZ * sin(pitchAngle) * cos(rollAngle);
302 yaw = atan2(-Bfy, Bfx) * RAD_TO_DEG;
303
304 yaw *= -1;
305 }
程序说明:
1 int main(void)
2 {
3 RCC_Configuration(); //系统时钟配置
4 USART1_Configuration();
5 I2C_GPIO_Config();
6 InitHMC5883();
7 InitMPU6050();
8 InitAll();
9 // SYSTICK_Configuration();
10 while(1)
11 {
12 func();
13 }
14 }
主函数首先初始化系统时钟、串口、I2C总线、HMC5883磁力计和MPU6050加速计&陀螺仪,这里重点讲InitAll()函数和func()函数
1 void InitAll()
2 {
3 /* Set Kalman and gyro starting angle */
4 updateMPU6050();
5 updateHMC5883();
7 updateYaw();
8
9 setAngle(&kalmanX,roll); // First set roll starting angle
10 gyroXangle = roll;
11 compAngleX = roll;
12
13 setAngle(&kalmanY,pitch); // Then pitch
14 gyroYangle = pitch;
15 compAngleY = pitch;
16
17 setAngle(&kalmanZ,yaw); // And finally yaw
18 gyroZangle = yaw;
19 compAngleZ = yaw;
20
21 // timer = micros; // Initialize the timer
22 }
第4、5两行从传感器中读取原数据,第6行函数根据加速计的值由空间几何的知识刷新Pitch和Roll数据,第7行函数根据复杂计算(这个实在看不懂,大概是磁力计有偏差,一方面进行误差校正,另一方面还用到了kalman滤波的数据,挺麻烦的)其实就是刷新yaw的值。
后面把kalman滤波值、陀螺仪计量值、磁力计计算值都赋值为上面计算的roll、pitch、yaw的值。
1 void func()
2 {
3 double gyroXrate,gyroYrate,gyroZrate,dt=0.01;
4 /* Update all the IMU values */
5 updateMPU6050();
6 updateHMC5883();
8 // dt = (double)(micros - timer) / 1000; // Calculate delta time
9 // timer = micros;
10 // if(dt<0)dt+=(1<<20); //时间是周期性的,有可能当前时间小于上次时间,因为这个周期远大于两次积分时间,所以最多相差1<<20
11
12 /* Roll and pitch estimation */
13 updatePitchRoll(); //用采集的加速计的值计算roll和pitch的值
14 gyroXrate = gyroX / 131.0; // Convert to deg/s 把陀螺仪的角加速度按照当初设定的量程转换为°/s
15 gyroYrate = gyroY / 131.0; // Convert to deg/s
16
17 #ifdef RESTRICT_PITCH //如果上面有#define RESTRICT_PITCH就采用这种方法计算,防止出现-180和180之间的跳跃
18 // This fixes the transition problem when the accelerometer angle jumps between -180 and 180 degrees
19 if ((roll < -90 && kalAngleX > 90) || (roll > 90 && kalAngleX < -90)) {
20 setAngle(&kalmanX,roll);
21 compAngleX = roll;
22 kalAngleX = roll;
23 gyroXangle = roll;
24 } else
25 kalAngleX = getAngle(&kalmanX, roll, gyroXrate, dt); // Calculate the angle using a Kalman filter
26
27 if (fabs(kalAngleX) > 90)
28 gyroYrate = -gyroYrate; // Invert rate, so it fits the restricted accelerometer reading
29 kalAngleY = getAngle(&kalmanY,pitch, gyroYrate, dt);
30 #else
31 // This fixes the transition problem when the accelerometer angle jumps between -180 and 180 degrees
32 if ((pitch < -90 && kalAngleY > 90) || (pitch > 90 && kalAngleY < -90)) {
33 kalmanY.setAngle(pitch);
34 compAngleY = pitch;
35 kalAngleY = pitch;
36 gyroYangle = pitch;
37 } else
38 kalAngleY = getAngle(&kalmanY, pitch, gyroYrate, dt); // Calculate the angle using a Kalman filter
39
40 if (abs(kalAngleY) > 90)
41 gyroXrate = -gyroXrate; // Invert rate, so it fits the restricted accelerometer reading
42 kalAngleX = getAngle(&kalmanX, roll, gyroXrate, dt); // Calculate the angle using a Kalman filter
43 #endif
44
45
46 /* Yaw estimation */
47 updateYaw();
48 gyroZrate = gyroZ / 131.0; // Convert to deg/s
49 // This fixes the transition problem when the yaw angle jumps between -180 and 180 degrees
50 if ((yaw < -90 && kalAngleZ > 90) || (yaw > 90 && kalAngleZ < -90)) {
51 setAngle(&kalmanZ,yaw);
52 compAngleZ = yaw;
53 kalAngleZ = yaw;
54 gyroZangle = yaw;
55 } else
56 kalAngleZ = getAngle(&kalmanZ, yaw, gyroZrate, dt); // Calculate the angle using a Kalman filter
57
58
59 /* Estimate angles using gyro only */
60 gyroXangle += gyroXrate * dt; // Calculate gyro angle without any filter
61 gyroYangle += gyroYrate * dt;
62 gyroZangle += gyroZrate * dt;
63 //gyroXangle += kalmanX.getRate() * dt; // Calculate gyro angle using the unbiased rate from the Kalman filter
64 //gyroYangle += kalmanY.getRate() * dt;
65 //gyroZangle += kalmanZ.getRate() * dt;
66
67 /* Estimate angles using complimentary filter */互补滤波算法
68 compAngleX = 0.93 * (compAngleX + gyroXrate * dt) + 0.07 * roll; // Calculate the angle using a Complimentary filter
69 compAngleY = 0.93 * (compAngleY + gyroYrate * dt) + 0.07 * pitch;
70 compAngleZ = 0.93 * (compAngleZ + gyroZrate * dt) + 0.07 * yaw;
71
72 // Reset the gyro angles when they has drifted too much
73 if (gyroXangle < -180 || gyroXangle > 180)
74 gyroXangle = kalAngleX;
75 if (gyroYangle < -180 || gyroYangle > 180)
76 gyroYangle = kalAngleY;
77 if (gyroZangle < -180 || gyroZangle > 180)
78 gyroZangle = kalAngleZ;
79
80
81 send(roll,pitch,yaw);
82 // send(gyroXangle,gyroYangle,gyroZangle);
83 // send(compAngleX,compAngleY,compAngleZ);
84 // send(kalAngleX,kalAngleY,kalAngleZ);
85 // send(kalAngleY,compAngleY,gyroYangle);
86 }
5、6两行获取传感器原数据
8~10行计算两次测量的时间差dt[因为我采用很多方法试验来计算时间差都不奏效,所以最终还是放弃了这种算法,还是用我原来的DMP算法,DMP对水平方向的很好,z方向的不好,要用磁力计来纠正!可以参考这里面的算法!]
13~56行是用kalman滤波来求当前的3个角并稳值
60~62行是用陀螺仪的角速度积分获得当前陀螺仪测量的3个角度值
67~70行使用互补滤波算法对磁力计当前测量3个角的值进行计算
72~78行是稳值
81行是串口发送
PS:总的来说按照arduino的代码进行照抄移植成c语言版的,当前卡在了如何较为准确的计算dt,即:两次测量的时间差(这里为了测试我给了dt一个定值0.01s,这是很不准确的做法!!!)[我采用定时器的方法总是会莫名的跑偏,我想可能是中断的影响,好吧,还是用原来实验的DMP吧,这个算法看似高大上,其实比较占MCU的资源啦,自带的DMP也存在一些缺陷,对水平方向的偏角测量较为精准,误差在1°左右,而在z轴方向上的误差较大,容易跑偏,所以还要用磁力计进行纠正Z轴的测量值~]
