#include
#include
#define uchar unsigned char
#define uint unsigned int
static volatile unsigned char acc @ 0x20;
static volatile bit acc0 @ (unsigned)&acc*8+0;
static volatile bit acc7 @ (unsigned)&acc*8+7;
#define PORTAIT(add,bit) ((unsigned)(&add)*8+(bit))
#define PORTBIT(add,bit) ((unsigned)(&add)*8+(bit))
#define PORTCIT(add,bit) ((unsigned)(&add)*8+(bit))
static bit RS @ PORTCIT(PORTC,0);
static bit RW @ PORTCIT(PORTC,1);
static bit E @ PORTCIT(PORTC,2);
static bit T_RST @ PORTCIT(PORTC,5);
static bit T_CLK @ PORTCIT(PORTC,6);
static bit T_IO @ PORTCIT(PORTC,7);
static bit PORTA_0 @ PORTAIT(PORTA,0); ///*定义PORTA 0位*/
static bit PORTA_1 @ PORTAIT(PORTA,1); ///*定义PORTA 1位*/
static bit PORTA_2 @ PORTAIT(PORTA,2); ///*定义PORTA 2位*/
static bit PORTA_5 @ PORTAIT(PORTA,5);
static bit RB_7 @ PORTBIT(PORTB,7);
const unsigned char Da
const unsigned char Ds1302[] = {9, 9, 0, 7, 1, 9 ,3,9, 2,4, 5, 9 ,5,9,};
// // 年 星期 月 日 时 分 秒
const unsigned char ds1302_sub[ ]={0};
uchar DisCash[]={0x00,0x30,0x09,0x1,0x06,0x06,0x06};
//初始化参数 秒 分 时 日 月 星期 年
unsigned char y,i;
char *pc;
uchar BCD[3];
uchar get1302[7];
uchar appear[]={0,0,0,0,0,0, 0,0,0,0,0,0,0,0,0};
void Delay ( );
void enable ();
void display();//显示程序
//延时子程序
void delay()
unsigned int i=1000;
while(i--) //for(i=6000;0
; // continue;
////////////////十六进制转十进制程序
void H_BCD (uchar x)
//i,j,t1,t2;
BCD [2]=x%10;
BCD [1]=(x%100)/10;
BCD [0]=x/100;
//////////写入数据子程序////////////////////////////
void W_da
Delay();//判断液晶显示器是否忙
RS=1;
RW=0;
PORTB=y;
// enable();//写入控制命令子程序
E=1;
E=0;
//////写入控制命令子程序////////////////////////////
void enable ()
{ Delay();
RS=0;
RW=0;
PORTB =y;
E=1;
E=0;
///////判断液晶显示器是否忙///////////////////////
void Delay ()
RS=0;
RW=1;
E=0;
NOP();
TRISB=0x80;
E=1;
while(RB_7==1 )
RS=0;
RW=1;
E=0;
NOP();
E=1;
TRISB=0x00;
void interrupt adint(void)
ADIF=0;//清/AD中断标志位
////////系统 各I/O初始化子程序///////////////////////////////////////////
void initial ()
{ TRISB=0;
TRISC=0;
TRISA=0x0ff;
//////////A/D转换初始化子程序//////////////////////////////
void adinitial()
ADCON1=15;//;设置RA为A/D甬道模拟输入
//;RC时钟。打开A/D转换器。先中通道0
ADCON0=0x0c1;// B'11000001' // ;A/D时钟为RC。RA0作A/D输入等
ADIE=1; //时。开放中断
ADIF=0; //清/AD中断标志位 PIR1,
PEIE=1; //开放外围部件中断INTCON,
GIE=1; //开放总中断 INTCON,
/////往1302写入1Byte数据////////////////////////
void RTInputByte(uchar d)
uchar i;
acc = d;
TRISC=0x00;
for(i=8; i>0; i--)
T_IO = acc0;//CARRY;//ACC0; //*相当于汇编中的 RRC */
T_CLK = 1;
T_CLK = 0;
acc = acc >> 1;
///////从1302读取1Byte数据////////////////////////
uchar RTOutputByte(void)
uchar i;
TRISC=0x80;
for(i=8; i>0; i--)
acc = acc >>1; //*相当于汇编中的 RRC */
acc7= T_IO;// CARRY
T_CLK = 1;
T_CLK = 0;
return(acc);
///////先写地址,后写命令/数据//////////////////////////
void W1302(uchar ucAddr, uchar ucDa)
T_RST = 0;
T_CLK = 0;
T_RST = 1;
RTInputByte(ucAddr); // /* 地址,命令 */
RTInputByte(ucDa); // /* 写1Byte数据*/
T_CLK = 1;
T_RST = 0;
///////先写地址,后读命令/数据////////////////////////
uchar R1302(uchar ucAddr)
uchar ucData;
T_RST = 0;
T_CLK = 0;
T_RST = 1;
ucData = RTOutputByte(); // /* 读1Byte数据 */
T_CLK = 1;
T_RST = 0;
return(ucData);
/////////向1302写入 秒 分 时 日 月 星期 年 */////////////
void Set1302(uchar *pClock)
uchar i;
uchar ucAddr = 0x80;
W1302(0x8e,0x00); ///* 控制命令,WP=0,允许写操作*/
for(i =7; i>0; i--)
W1302(ucAddr,*pClock); ///* 秒 分 时 日 月 星期 年 */
pClock++;
ucAddr +=2;
W1302(0x8e,0x80); // /* 控制命令,WP=1,写保护*/
////////从1302读出 秒 分 时 日 月 星期 年 *//////////////////
void v_Get1302(unsigned char ucCurtime[])
unsigned char i;
unsigned char ucAddr = 0x81;
for (i=0;i<7;i++)
ucCurtime[i] = R1302(ucAddr);///*格式为: 秒 分 时 日 月 星期 年 */
ucAddr += 2;
//////////拆字子程序///////////////////////////////////////
void bcd_bcd( )
{ uchar a=6;
for (i=0;i<=15;)
appear[i]=(get1302[a]&0xf0)/16;
i++;
appear[i]=get1302[a]&0x0f;
i++;
a--;
////////按键扫描///////////////////////////////////////////////////
//////////按键扫描/////////////////////////////////////////////////
void Key()
uchar a,b,c,i;
di();
a=PORTA ;
if(56!=(a&56))
display();
a=PORTA ;
if(56!=(a&56))
for (b=0;b<14;)
uchar z,x;
for(z=50;z>0&&b<14;z--)
{ z--;
display();// delay();
delay();
a=PORTA;
a=a&56;
switch(a)
case 48 :
if(Ds1302[b]!=appear[b] )
(appear[b])++;
a=PORTA ;
for(x=20;x>0&&56!=(a&56);x--)
{ display();// delay();
delay();
} break; // 年 星期 月 日 时 分 秒
case 40 : if(appear[b]!=0)(appear[b])--;
a=PORTA ;
delay();
} break;// 年 星期 月 日 时 分 秒
case 24 : b++; while( PORTA_5==0); break;
a=PORTA ;
for(z=50;( z>0&&56==(a&56));z--)
i=appear[b];
appear[b]=10;
display( );
delay();
appear[b]=i;
a=PORTA;
//a=a&56;
z--;
while( PORTA_5==0);
i=13;
c=12;
for(b=0;b<7;b++)
DisCash[b]=((appear[c]&0x0f)*16)|(appear[i]&0x0f);
i=i-2;
c=c-2;
Set1302(&DisCash[0]);
a=PORTA ;
//////////显示子程序/////////////////////////////////////////////
void display()//显示程序
y=0x80;//0x0C0;写入起始地址
for(i=0;i<8;)
y=Da
W_da
// delay();
i++;
y=Da
W_da
// delay();
i++;
y='-'; // 1';//0x47;
W_da
//delay();
y=0x0C0;
for(i=8;i<14;)
y=Da
W_da
//delay();
i++;
y=Da
W_da
// delay();
i++;
y=':'; // 1';//0x47;
W_da
// delay();
W_da
// delay();
for(i=0;i<3;i++)
y=Da
W_da
///////主程序//////////////////////////////////////////////////////
void main()
// TRISB=0x00;
// TRISC=0x00;
initial ();//系统 各I/O初始化子程序
adinitial();//A/D转换初始化子程序/
y=0x01;//PORTB
y=0x38;//8位2行5X7点阵0x3c
y=0x0C;//显示器开,F=光标开,闪烁开。
y=0x06; //文字不动,光标自动右移。
while(1)
v_Get1302(get1302);//从1302读出 秒 分 时 日 月 星期 年
bcd_bcd(get1302);//拆字子程序
H_BCD ( ADRES ); //十六进制转十进制程序
ei();
ADGO=1; //启动A/D转换 ADCON0,
display();
Key();
