start.S源码:
.global _start
_start:
ldr sp, =0xD0030000 // 初始化栈,因为后面要调用C函数
bl clock_init // 初始化时钟
bl ddr_init // 初始化内存
bl nand_init // 初始化NAND
ldr r0, =0x36000000 // 要拷贝到DDR中的位置
ldr r1, =0x0 // 从NAND的0地址开始拷贝
ldr r2, =bss_start // BSS段的开始地址
sub r2,r2,r0 // 要拷贝的大小
bl nand_read // 拷贝数据
clean_bss:
ldr r0, =bss_start
ldr r1, =bss_end
mov r3, #0
cmp r0, r1
ldreq pc, =on_ddr
clean_loop:
str r3, [r0], #4
cmp r0, r1
bne clean_loop
ldr pc, =on_ddr
on_ddr:
ldr sp, =0x3f000000 // 重新初始化栈,指向内存
ldr pc, =main
clock.c源码:
#define APLL_CON (*(volatile unsigned int *)0xe0100100)
#define CLK_SRC0 (*(volatile unsigned int *)0xe0100200)
#define CLK_DIV0 (*(volatile unsigned int *)0xe0100300)
#define MPLL_CON (*(volatile unsigned int *)0xe0100108)
void clock_init(void)
// 设置时钟为:
// ARMCLK=1000MHz, HCLKM=200MHz, HCLKD=166.75MHz
// HCLKP =133.44MHz, PCLKM=100MHz, PCLKD=83.375MHz,
// PCLKP =66.7MHz
// SDIV[2:0] : S = 1
// PDIV[13:8] : P = 0x3
// MDIV[25:16]: M = 0x7d
// LOCKED [29]: 1 = 使能锁
// ENABLE [31]: 1 = 使能APLL控制器
// 得出FoutAPLL = 500MHz
APLL_CON = (1<<31)|(1<<29)|(0x7d<<16)|(0x3<<8)|(1<<0);
// 时钟源的设置
// APLL_SEL[0] :1 = FOUTAPLL
// MPLL_SEL[4] :1 = FOUTMPLL
// EPLL_SEL[8] :1 = FOUTEPLL
// VPLL_SEL[12]:1 = FOUTVPLL
// MUX_MSYS_SEL[16]:0 = SCLKAPLL
// MUX_DSYS_SEL[20]:0 = SCLKMPLL
// MUX_PSYS_SEL[24]:0 = SCLKMPLL
// ONENAND_SEL [28]:1 = HCLK_DSYS
CLK_SRC0 = (1<<28)|(1<<12)|(1<<8)|(1<<4)|(1<<0);
// 设置分频系数
// APLL_RATIO[2:0]: APLL_RATIO = 0x0
// A2M_RATIO [6:4]: A2M_RATIO = 0x4
// HCLK_MSYS_RATIO[10:8]: HCLK_MSYS_RATIO = 0x4
// PCLK_MSYS_RATIO[14:12]:PCLK_MSYS_RATIO = 0x1
// HCLK_DSYS_RATIO[19:16]:HCLK_DSYS_RATIO = 0x3
// PCLK_DSYS_RATIO[22:20]:PCLK_DSYS_RATIO = 0x1
// HCLK_PSYS_RATIO[27:24]:HCLK_PSYS_RATIO = 0x4
// PCLK_PSYS_RATIO[30:28]:PCLK_PSYS_RATIO = 0x1
CLK_DIV0 = (0x1<<28)|(0x4<<24)|(0x1<<20)|(0x3<<16)|(0x1<<12)|(0x4<<8)|(0x4<<4);
// PDIV[13:8] : P = 0xc
// MDIV[25:16]: M = 0x29b
// VSEL [27]: 0
// ENABLE [31]: 1 = 使能MPLL控制器
// 得出FoutAPLL = 667MHz
APLL_CON = (1<<31)|(1<<29)|(0x29d<<16)|(0xc<<8)|(1<<0);
memset.S中DDR初始化汇编源码:
// SDRAM Controller
#define APB_DMC_0_BASE 0xF0000000
#define APB_DMC_1_BASE 0xF1400000
#define ASYNC_MSYS_DMC0_BASE 0xF1E00000
#define ELFIN_GPIO_BASE 0xE0200000
#define DMC0_MEMCONTROL 0x00202400 // MemControl BL=4, 1Chip, DDR2 Type, dynamic self refresh, force precharge, dynamic power down off
#define DMC0_MEMCONFIG_0 0x20E00323 // MemConfig0 256MB config, 8 banks,Mapping Method[12:15]0:linear, 1:linterleaved, 2:Mixed
#define DMC0_MEMCONFIG_1 0x00E00323 // MemConfig1
#define DMC0_TIMINGA_REF 0x00000618 // TimingAref 7.8us*133MHz=1038(0x40E), 100MHz=780(0x30C), 20MHz=156(0x9C), 10MHz=78(0x4E)
#define DMC0_TIMING_ROW 0x2B34438A // TimingRow for @200MHz
#define DMC0_TIMING_DATA 0x24240000 // TimingData CL=3
#define DMC0_TIMING_PWR 0x0BDC0343 // TimingPower
#define DMC1_MEMCONTROL 0x00202400 // MemControl BL=4, 2 chip, DDR2 type, dynamic self refresh, force precharge, dynamic power down off
#define DMC1_MEMCONFIG_0 0x40F00313 // MemConfig0 512MB config, 8 banks,Mapping Method[12:15]0:linear, 1:linterleaved, 2:Mixed
#define DMC1_MEMCONFIG_1 0x00F00313 // MemConfig1
#define DMC1_TIMINGA_REF 0x00000618 // TimingAref 7.8us*133MHz=1038(0x40E), 100MHz=780(0x30C), 20MHz=156(0x9C), 10MHz=78(0x4E)
#define DMC1_TIMING_ROW 0x2B34438A // TimingRow for @200MHz
#define DMC1_TIMING_DATA 0x24240000 // TimingData CL=3
#define DMC1_TIMING_PWR 0x0BDC0343 // TimingPower
#define MP1_0DRV_SR_OFFSET 0x3CC
#define MP1_1DRV_SR_OFFSET 0x3EC
#define MP1_2DRV_SR_OFFSET 0x40C
#define MP1_3DRV_SR_OFFSET 0x42C
#define MP1_4DRV_SR_OFFSET 0x44C
#define MP1_5DRV_SR_OFFSET 0x46C
#define MP1_6DRV_SR_OFFSET 0x48C
#define MP1_7DRV_SR_OFFSET 0x4AC
#define MP1_8DRV_SR_OFFSET 0x4CC
#define MP2_0DRV_SR_OFFSET 0x4EC
#define MP2_1DRV_SR_OFFSET 0x50C
#define MP2_2DRV_SR_OFFSET 0x52C
#define MP2_3DRV_SR_OFFSET 0x54C
#define MP2_4DRV_SR_OFFSET 0x56C
#define MP2_5DRV_SR_OFFSET 0x58C
#define MP2_6DRV_SR_OFFSET 0x5AC
#define MP2_7DRV_SR_OFFSET 0x5CC
#define MP2_8DRV_SR_OFFSET 0x5EC
#define DMC_CONCONTROL 0x00
#define DMC_MEMCONTROL 0x04
#define DMC_MEMCONFIG0 0x08
#define DMC_MEMCONFIG1 0x0C
#define DMC_DIRECTCMD 0x10
#define DMC_PRECHCONFIG 0x14
#define DMC_PHYCONTROL0 0x18
#define DMC_PHYCONTROL1 0x1C
#define DMC_RESERVED 0x20
#define DMC_PWRDNCONFIG 0x28
#define DMC_TIMINGAREF 0x30
#define DMC_TIMINGROW 0x34
#define DMC_TIMINGDATA 0x38
#define DMC_TIMINGPOWER 0x3C
#define DMC_PHYSTATUS 0x40
#define DMC_CHIP0STATUS 0x48
#define DMC_CHIP1STATUS 0x4C
#define DMC_AREFSTATUS 0x50
#define DMC_MRSTATUS 0x54
#define DMC_PHYTEST0 0x58
#define DMC_PHYTEST1 0x5C
#define DMC_QOSCONTROL0 0x60
#define DMC_QOSCONFIG0 0x64
#define DMC_QOSCONTROL1 0x68
#define DMC_QOSCONFIG1 0x6C
#define DMC_QOSCONTROL2 0x70
#define DMC_QOSCONFIG2 0x74
#define DMC_QOSCONTROL3 0x78
#define DMC_QOSCONFIG3 0x7C
#define DMC_QOSCONTROL4 0x80
#define DMC_QOSCONFIG4 0x84
#define DMC_QOSCONTROL5 0x88
#define DMC_QOSCONFIG5 0x8C
#define DMC_QOSCONTROL6 0x90
#define DMC_QOSCONFIG6 0x94
#define DMC_QOSCONTROL7 0x98
#define DMC_QOSCONFIG7 0x9C
#define DMC_QOSCONTROL8 0xA0
#define DMC_QOSCONFIG8 0xA4
#define DMC_QOSCONTROL9 0xA8
#define DMC_QOSCONFIG9 0xAC
#define DMC_QOSCONTROL10 0xB0
#define DMC_QOSCONFIG10 0xB4
#define DMC_QOSCONTROL11 0xB8
#define DMC_QOSCONFIG11 0xBC
#define DMC_QOSCONTROL12 0xC0
#define DMC_QOSCONFIG12 0xC4
#define DMC_QOSCONTROL13 0xC8
#define DMC_QOSCONFIG13 0xCC
#define DMC_QOSCONTROL14 0xD0
#define DMC_QOSCONFIG14 0xD4
#define DMC_QOSCONTROL15 0xD8
#define DMC_QOSCONFIG15 0xDC
// SDRAM Controller
.globl ddr_init
ddr_init:
// DMC0 Drive Strength (Setting 2X)
ldr r0, =ELFIN_GPIO_BASE
ldr r1, =0x0000AAAA
str r1, [r0, #0x3cc]
str r1, [r0, #MP1_0DRV_SR_OFFSET]
ldr r1, =0x0000AAAA
str r1, [r0, #MP1_1DRV_SR_OFFSET]
ldr r1, =0x0000AAAA
str r1, [r0, #MP1_2DRV_SR_OFFSET]
ldr r1, =0x0000AAAA
str r1, [r0, #MP1_3DRV_SR_OFFSET]
ldr r1, =0x0000AAAA
str r1, [r0, #MP1_4DRV_SR_OFFSET]
ldr r1, =0x0000AAAA
str r1, [r0, #MP1_5DRV_SR_OFFSET]
ldr r1, =0x0000AAAA
str r1, [r0, #MP1_6DRV_SR_OFFSET]
ldr r1, =0x0000AAAA
str r1, [r0, #MP1_7DRV_SR_OFFSET]
ldr r1, =0x00002AAA
str r1, [r0, #MP1_8DRV_SR_OFFSET]
// DMC0 initialization at single Type
ldr r0, =APB_DMC_0_BASE
ldr r1, =0x00101000 @PhyControl0 DLL parameter setting, manual 0x00101000
str r1, [r0, #DMC_PHYCONTROL0]
ldr r1, =0x00000086 @PhyControl1 DLL parameter setting, LPDDR/LPDDR2 Case
str r1, [r0, #DMC_PHYCONTROL1]
ldr r1, =0x00101002 @PhyControl0 DLL on
ldr r1, =0x00101003 @PhyControl0 DLL start
find_lock_val:
ldr r1, [r0, #DMC_PHYSTATUS] @Load Phystatus register value
and r2, r1, #0x7
cmp r2, #0x7 @Loop until DLL is locked
bne find_lock_val
and r1, #0x3fc0
mov r2, r1, LSL #18
orr r2, r2, #0x100000
orr r2 ,r2, #0x1000
orr r1, r2, #0x3 @Force Value locking
// setting DDR2
ldr r1, =0x0FFF2010 @ConControl auto refresh off
str r1, [r0, #DMC_CONCONTROL]
ldr r1, =DMC0_MEMCONTROL @MemControl BL=4, 1 chip, DDR2 type, dynamic self refresh, force precharge, dynamic power down off
str r1, [r0, #DMC_MEMCONTROL]
ldr r1, =DMC0_MEMCONFIG_0 @MemConfig0 256MB config, 8 banks,Mapping Method[12:15]0:linear, 1:linterleaved, 2:Mixed
str r1, [r0, #DMC_MEMCONFIG0]
ldr r1, =DMC0_MEMCONFIG_1 @MemConfig1
str r1, [r0, #DMC_MEMCONFIG1]
ldr r1, =0xFF000000 @PrechConfig
str r1, [r0, #DMC_PRECHCONFIG]
ldr r1, =DMC0_TIMINGA_REF @TimingAref 7.8us*133MHz=1038(0x40E), 100MHz=780(0x30C), 20MHz=156(0x9C), 10MHz=78(0x4E)
str r1, [r0, #DMC_TIMINGAREF]
ldr r1, =DMC0_TIMING_ROW @TimingRow for @200MHz
str r1, [r0, #DMC_TIMINGROW]
ldr r1, =DMC0_TIMING_DATA @TimingData CL=4
str r1, [r0, #DMC_TIMINGDATA]
ldr r1, =DMC0_TIMING_PWR @TimingPower
str r1, [r0, #DMC_TIMINGPOWER]
ldr r1, =0x07000000 @DirectCmd chip0 Deselect
str r1, [r0, #DMC_DIRECTCMD]
ldr r1, =0x01000000 @DirectCmd chip0 PALL
ldr r1, =0x00020000 @DirectCmd chip0 EMRS2
ldr r1, =0x00030000 @DirectCmd chip0 EMRS3
ldr r1, =0x00010400 @DirectCmd chip0 EMRS1 (MEM DLL on, DQS# disable)
ldr r1, =0x00000542 @DirectCmd chip0 MRS (MEM DLL reset) CL=4, BL=4
ldr r1, =0x05000000 @DirectCmd chip0 REFA
ldr r1, =0x00000442 @DirectCmd chip0 MRS (MEM DLL unreset)
ldr r1, =0x00010780 @DirectCmd chip0 EMRS1 (OCD default)
ldr r1, =0x00010400 @DirectCmd chip0 EMRS1 (OCD exit)
ldr r1, =0x07100000 @DirectCmd chip1 Deselect
ldr r1, =0x01100000 @DirectCmd chip1 PALL
ldr r1, =0x00120000 @DirectCmd chip1 EMRS2
ldr r1, =0x00130000 @DirectCmd chip1 EMRS3
ldr r1, =0x00110400 @DirectCmd chip1 EMRS1 (MEM DLL on, DQS# disable)
ldr r1, =0x00100542 @DirectCmd chip1 MRS (MEM DLL reset) CL=4, BL=4
ldr r1, =0x05100000 @DirectCmd chip1 REFA
ldr r1, =0x00100442 @DirectCmd chip1 MRS (MEM DLL unreset)
ldr r1, =0x00110780 @DirectCmd chip1 EMRS1 (OCD default)
ldr r1, =0x00110400 @DirectCmd chip1 EMRS1 (OCD exit)
ldr r1, =0x0FF02030 @ConControl auto refresh on
ldr r1, =0xFFFF00FF @PwrdnConfig
str r1, [r0, #DMC_PWRDNCONFIG]
ldr r1, =0x00202400 @MemControl BL=4, 1 chip, DDR2 type, dynamic self refresh, force precharge, dynamic power down off
mov pc, lr
nand.c源码:
#define NFCONF (*(volatile unsigned int *)0xB0E00000)
#define NFCONT (*(volatile unsigned int *)0xB0E00004)
#define NFCMMD (*(volatile unsigned char *)0xB0E00008)
#define NFADDR (*(volatile unsigned char *)0xB0E0000C)
#define NFDATA (*(volatile unsigned char *)0xB0E00010)
#define NFSTAT (*(volatile unsigned int *)0xB0E00028)
#define MP0_3CON (*(volatile unsigned int *)0xE0200320)
#define MP0_1CON (*(volatile unsigned int *)0xE02002E0)
#define PAGE_SIZE 2048
#define NAND_SECTOR_SIZE_LP 2048
void wait_idle(void)
int i;
while(!(NFSTAT&(1<<0)));
for(i=0; i<10; i++);
void nand_select_chip(void)
int i;
NFCONT &= ~(1<<1);
void nand_deselect_chip(void)
NFCONT |= (1<<1);
void write_cmd(int cmd)
NFCMMD = cmd;
void write_addr(unsigned int addr)
int i;
NFADDR = (addr>>0) & 0xFF;
wait_idle();
NFADDR = (addr>>8) & 0x7;
wait_idle();
NFADDR = (addr>>11) & 0xFF;
wait_idle();
NFADDR = (addr>>19) & 0xFF;
wait_idle();
NFADDR = (addr>>27) & 0x1;
wait_idle();
unsigned char read_data(void)
return NFDATA;
static void nand_reset(void)
nand_select_chip();
write_cmd(0xff); // 复位命令
wait_idle();
nand_deselect_chip();
void nand_init(void)
// 设置时间参数(HCLK_PSYS = 667MHz/5 = 133MHz)
// TACLS[15:12]: TACLS = 1 1/133Mhz = 7.5ns
// TWRPH0[11:8]: TWRPH0 = 1 7.5ns * 2 = 15ns
// TWRPH1 [7:4]: TWRPH1 = 1 7.5ns * 2 = 15ns
// AddrCycle[1]: 1 = 指明地址周期为5次,这个是和2440的区别
NFCONF |= 1<<12 | 1<<8 | 1<<4;
NFCONF |= 1<<1;
// 使能NAND控制器
// 关闭片选信号
NFCONT |= (1<<0)|(1<<1);
// 设置相应管脚用于Nand Flash控制器
MP0_3CON = 0x22222222;
// 复位NAND Flash
nand_reset();
return;
// 读ID
void nand_read_id(char id[])
int i;
nand_select_chip();
write_cmd(0x90);
write_addr(0x00);
for (i = 0; i < 5; i++)
id[i] = read_data();
// 读一页的函数
void nand_read(unsigned char *buf, unsigned long start_addr, int size)
int i, j;
// 选中芯片
nand_select_chip();
for(i=start_addr; i < (start_addr + size);)
// 发出READ0命令
write_cmd(0);
// Write Address
write_addr(i);
write_cmd(0x30);
wait_idle();
for(j=0; j < NAND_SECTOR_SIZE_LP; j++, i++)
*buf = read_data();
buf++;
// 取消片选信号
void nand_write(int sdram_addr, int nand_addr, int size)
main.c源码:
#include "command.h"
#include "clock.h"
#include "led.h"
#include "uart.h"
#include "lib.h"
#include "nand.h"
#define CFG_PROMPT "WY_BOOT # " // Monitor Command Prompt
#define CFG_CBSIZE 256 // Console I/O Buffer Size
char *argv[10];
int readline (const char *const prompt)
char console_buffer[CFG_CBSIZE]; // console I/O buffer
char *buf = console_buffer;
int argc = 0;
int state = 0;
//puts(prompt);
wy_printf("%s",prompt);
gets(console_buffer);
while (*buf)
if (*buf != ' ' && state == 0)
argv[argc++] = buf;
state = 1;
if (*buf == ' ' && state == 1)
*buf = '\0';
state = 0;
buf++;
return argc;
void message(void)
wy_printf("\nThis bootloader support some command to test peripheral:\n");
wy_printf("Such as: LCD, IIS, BUZZER \n");
wy_printf("Try 'help' to learn them \n\n");
int main(void)
char buf[6];
int argc = 0;
int i = 0;
led_init(); // 设置对应管脚为输出
uart_init(); // 初始化UART0
nand_read_id(buf);
wy_printf("\n**********************************************************\n");
wy_printf(" wy_bootloader\n");
wy_printf(" vars: %d \n",2012);
wy_printf(" nand id:");
putchar_hex(buf[0]);
putchar_hex(buf[1]);
putchar_hex(buf[2]);
putchar_hex(buf[3]);
putchar_hex(buf[4]);
while (1)
argc = readline (CFG_PROMPT);
if(argc == 0 && i ==0)
message();
i=1;
run_command(argc, argv);
return 0;
uart.c源码:
#define GPA0CON (*(volatile unsigned int *)0xE0200000)
#define ULCON0 (*(volatile unsigned int *)0xE2900000)
#define UCON0 (*(volatile unsigned int *)0xE2900004)
#define UTRSTAT0 (*(volatile unsigned int *)0xE2900010)
#define UTXH0 (*(volatile unsigned char *)0xE2900020)
#define URXH0 (*(volatile unsigned char *)0xE2900024)
#define UBRDIV0 (*(volatile unsigned int *)0xE2900028)
#define UDIVSLOT0 (*(volatile unsigned int *)0xE290002C)
void uart_init(void)
// 设置对应GPIO用于UART0
GPA0CON |= 0x22;
// 设置UART0寄存器
// bit[1:0]:0x3 = 8位数据位
// 其他位默认,即1位停止位,无校验,正常模式
ULCON0 |= (0x3<<0);
// Receive Mode [1:0]:1 = 接收采用查询或者中断模式
// Transmit Mode[3:2]:1 = 发送采用查询或者中断模式
// bit[6]:1 = 产生错误中断
// bit[10]:0 = 时钟源为PCLK
UCON0 = (1<<6)|(1<<2)|(1<<0);
// 设置波特率(详细信息请参考手册或者学习日记)
// DIV_VAL = UBRDIVn + (num of 1's in UDIVSLOTn)/16
// DIV_VAL = (PCLK / (bps x 16)) - 1
UBRDIV0 = 0x23;
UDIVSLOT0 = 0x808;
return;
char uart_getchar(void)
char c;
// 查询状态寄存器,直到有有效数据
while (!(UTRSTAT0 & (1<<0)));
c = URXH0; // 读取接收寄存器的值
return c;
void uart_putchar(char c)
// 查询状态寄存器,直到发送缓存为空
while (!(UTRSTAT0 & (1<<2)));
UTXH0 = c; // 写入发送寄存器
return;
Makefile文件:
uart.bin:start.s main.c uart.c clock.c led.c lib.c command.c nand.c mem_setup.S
arm-linux-gcc -nostdlib -c start.s -o start.o
arm-linux-gcc -nostdlib -c main.c -o main.o
arm-linux-gcc -nostdlib -c uart.c -o uart.o
arm-linux-gcc -nostdlib -c lib.c -o lib.o
arm-linux-gcc -nostdlib -c clock.c -o clock.o
arm-linux-gcc -nostdlib -c led.c -o led.o
arm-linux-gcc -nostdlib -c command.c -o command.o
arm-linux-gcc -nostdlib -c nand.c -o nand.o
arm-linux-gcc -nostdlib -c mem_setup.S -o mem_setup.o
arm-linux-ld -T bootloader.lds start.o main.o uart.o lib.o clock.o led.o command.o nand.o mem_setup.o -o uart_elf
arm-linux-objcopy -O binary -S uart_elf uart.bin
clean:
rm -rf *.o *.bin uart_elf *.dis
bootloader.lds链接文件:
SECTIONS {
. = 0x36000010;
.text : {
* (.text)
. = ALIGN(4);
.rodata : {
* (.rodata)
. = ALIGN(4);
.data : {
* (.data)
. = ALIGN(4);
bss_start = .;
.bss : { *(.bss) *(COMMON) }
bss_end = .;
要支持DDR,仅仅只需要做一些初始化工作就行,而在S5PV210芯片手册中的598页已经给出了相信的初始化话步骤,我就不再多说什么了。
另外大家可以听一下韦东三的6410的一期视频里面关于DDR的视频,会对大家对DDR的了解有所帮助。
另外推荐大家看两篇文章:
1).DDR2_SDRAM操作时序.pdf
2).内存的原理和时序(SDRAM、DDR、DDR-Ⅱ、Rambus_DRAM).pdf
参考代码我已经给出(其实我也是参考u-boot里面的,只是自己从头对照寄存器去理解了一下,完全符合598页的初始化步骤),放在了"Tiny210学习日记_代码"目录下了,名为"7_ddr"
注意:之前的代码,包括该部分代码,都没有重定位的操作,IROM最多可以拷贝16K的代码到IRAM中,够用了!
但是,由于后面我会讲到LCD显示图片,声卡播放WAV文件,bootloader也随之慢慢变大,16K的大小可能不够,再加上现在已经把重定位的条件都准备好了,所以接下来将是重定位。(相关知识,大家可以学习韦东三一期视频的重定位部分),这里,我就不在细说,直接给出代码,和讲几个关键地方。
以下为start.s的代码:
.global _start
_start:
// 以下将BSS段清0
clean_bss:
ldr r0, =bss_start
ldr r1, =bss_end
mov r3, #0
cmp r0, r1
ldreq pc, =on_ddr
clean_loop:
str r3, [r0], #4
cmp r0, r1
bne clean_loop
ldr pc, =on_ddr
on_ddr:
ldr pc, =main
注意:
1).ldr r1, =0x0不能写成adr r1, =_start,因为拷贝数据是从Nand Flash的0地址开始拷贝,而adr r1, =_start表示当前程序执行的地址,该地址是0xD0020000而不是0(我在"Tiny210学习日记(2)"中已讲过)。
2).大家注意位置无关码,以及r0对应C函数的参数1,r1对应C函数的参数2,r2对应C函数的参数3的问题!!
以下为连接脚本:
SECTIONS {
. = 0x36000010; // 注意这个值
.text : {
* (.text)
. = ALIGN(4);
.rodata : {
* (.rodata)
. = ALIGN(4);
.data : {
* (.data)
. = ALIGN(4);
bss_start = .;
bss_end = .;
注意:
连接地址一定要是0x36000010,而不是0x36000000,虽然我们是将Nand Flash的数据拷贝到0x36000000地址处,但是我在"Tiny210学习日记(2)"中已讲过,前16字节的数据是头部信息,而不是真正的可执行代码!!
重定位的相应代码放在了"Tiny210学习日记_代码"目录下了,名为"8_reload"。
