start.S源码:
.global _start
_start:
ldr sp, =0xD0030000 // 初始化栈,因为后面要调用C函数
bl clock_init // 初始化时钟
bl ddr_init // 初始化内存
bl nand_init // 初始化NAND
ldr r0, =0x36000000 // 要拷贝到DDR中的位置
ldr r1, =0x0 // 从NAND的0地址开始拷贝
ldr r2, =bss_start // BSS段的开始地址
sub r2,r2,r0 // 要拷贝的大小
bl nand_read // 拷贝数据
clean_bss:
ldr r0, =bss_start
ldr r1, =bss_end
mov r3, #0
cmp r0, r1
ldreq pc, =on_ddr
clean_loop:
str r3, [r0], #4
cmp r0, r1
bne clean_loop
ldr pc, =on_ddr
on_ddr:
ldr sp, =0x33000000 // 重新初始化栈,指向内存
ldr pc, =main
clock.c源码:
#define APLL_CON (*(volatile unsigned int *)0xe0100100)
#define CLK_SRC0 (*(volatile unsigned int *)0xe0100200)
#define CLK_DIV0 (*(volatile unsigned int *)0xe0100300)
#define MPLL_CON (*(volatile unsigned int *)0xe0100108)
void clock_init(void)
// 设置时钟为:
// ARMCLK=1000MHz, HCLKM=200MHz, HCLKD=166.75MHz
// HCLKP =133.44MHz, PCLKM=100MHz, PCLKD=83.375MHz,
// PCLKP =66.7MHz
// SDIV[2:0] : S = 1
// PDIV[13:8] : P = 0x3
// MDIV[25:16]: M = 0x7d
// LOCKED [29]: 1 = 使能锁
// ENABLE [31]: 1 = 使能APLL控制器
// 得出FoutAPLL = 500MHz
APLL_CON = (1<<31)|(1<<29)|(0x7d<<16)|(0x3<<8)|(1<<0);
// 时钟源的设置
// APLL_SEL[0] :1 = FOUTAPLL
// MPLL_SEL[4] :1 = FOUTMPLL
// EPLL_SEL[8] :1 = FOUTEPLL
// VPLL_SEL[12]:1 = FOUTVPLL
// MUX_MSYS_SEL[16]:0 = SCLKAPLL
// MUX_DSYS_SEL[20]:0 = SCLKMPLL
// MUX_PSYS_SEL[24]:0 = SCLKMPLL
// ONENAND_SEL [28]:1 = HCLK_DSYS
CLK_SRC0 = (1<<28)|(1<<12)|(1<<8)|(1<<4)|(1<<0);
// 设置分频系数
// APLL_RATIO[2:0]: APLL_RATIO = 0x0
// A2M_RATIO [6:4]: A2M_RATIO = 0x4
// HCLK_MSYS_RATIO[10:8]: HCLK_MSYS_RATIO = 0x4
// PCLK_MSYS_RATIO[14:12]:PCLK_MSYS_RATIO = 0x1
// HCLK_DSYS_RATIO[19:16]:HCLK_DSYS_RATIO = 0x3
// PCLK_DSYS_RATIO[22:20]:PCLK_DSYS_RATIO = 0x1
// HCLK_PSYS_RATIO[27:24]:HCLK_PSYS_RATIO = 0x4
// PCLK_PSYS_RATIO[30:28]:PCLK_PSYS_RATIO = 0x1
CLK_DIV0 = (0x1<<28)|(0x4<<24)|(0x1<<20)|(0x3<<16)|(0x1<<12)|(0x4<<8)|(0x4<<4);
// PDIV[13:8] : P = 0xc
// MDIV[25:16]: M = 0x29b
// VSEL [27]: 0
// ENABLE [31]: 1 = 使能MPLL控制器
// 得出FoutAPLL = 667MHz
APLL_CON = (1<<31)|(1<<29)|(0x29d<<16)|(0xc<<8)|(1<<0);
mem_setup.S源码:
// SDRAM Controller
#define APB_DMC_0_BASE 0xF0000000
#define APB_DMC_1_BASE 0xF1400000
#define ASYNC_MSYS_DMC0_BASE 0xF1E00000
#define ELFIN_GPIO_BASE 0xE0200000
// MemControl BL=4, 1Chip, DDR2 Type, dynamic self refresh, force precharge, dynamic power down off
#define DMC0_MEMCONTROL 0x00202400
// MemConfig0 256MB config, 8 banks,Mapping Method[12:15]0:linear, 1:linterleaved, 2:Mixed
#define DMC0_MEMCONFIG_0 0x20E00323
#define DMC0_MEMCONFIG_1 0x00E00323 // MemConfig1
// TimingAref 7.8us*133MHz=1038(0x40E), 100MHz=780(0x30C), 20MHz=156(0x9C), 10MHz=78(0x4E)
#define DMC0_TIMINGA_REF 0x00000618
#define DMC0_TIMING_ROW 0x2B34438A // TimingRow for @200MHz
#define DMC0_TIMING_DATA 0x24240000 // TimingData CL=3
#define DMC0_TIMING_PWR 0x0BDC0343 // TimingPower
// MemControl BL=4, 2 chip, DDR2 type, dynamic self refresh, force precharge, dynamic power down off
#define DMC1_MEMCONTROL 0x00202400
// MemConfig0 512MB config, 8 banks,Mapping Method[12:15]0:linear, 1:linterleaved, 2:Mixed
#define DMC1_MEMCONFIG_0 0x40F00313
#define DMC1_MEMCONFIG_1 0x00F00313 // MemConfig1
#define DMC1_TIMINGA_REF 0x00000618
#define DMC1_TIMING_ROW 0x2B34438A // TimingRow for @200MHz
#define DMC1_TIMING_DATA 0x24240000 // TimingData CL=3
#define DMC1_TIMING_PWR 0x0BDC0343 // TimingPower
#define MP1_0DRV_SR_OFFSET 0x3CC
#define MP1_1DRV_SR_OFFSET 0x3EC
#define MP1_2DRV_SR_OFFSET 0x40C
#define MP1_3DRV_SR_OFFSET 0x42C
#define MP1_4DRV_SR_OFFSET 0x44C
#define MP1_5DRV_SR_OFFSET 0x46C
#define MP1_6DRV_SR_OFFSET 0x48C
#define MP1_7DRV_SR_OFFSET 0x4AC
#define MP1_8DRV_SR_OFFSET 0x4CC
#define MP2_0DRV_SR_OFFSET 0x4EC
#define MP2_1DRV_SR_OFFSET 0x50C
#define MP2_2DRV_SR_OFFSET 0x52C
#define MP2_3DRV_SR_OFFSET 0x54C
#define MP2_4DRV_SR_OFFSET 0x56C
#define MP2_5DRV_SR_OFFSET 0x58C
#define MP2_6DRV_SR_OFFSET 0x5AC
#define MP2_7DRV_SR_OFFSET 0x5CC
#define MP2_8DRV_SR_OFFSET 0x5EC
#define DMC_CONCONTROL 0x00
#define DMC_MEMCONTROL 0x04
#define DMC_MEMCONFIG0 0x08
#define DMC_MEMCONFIG1 0x0C
#define DMC_DIRECTCMD 0x10
#define DMC_PRECHCONFIG 0x14
#define DMC_PHYCONTROL0 0x18
#define DMC_PHYCONTROL1 0x1C
#define DMC_RESERVED 0x20
#define DMC_PWRDNCONFIG 0x28
#define DMC_TIMINGAREF 0x30
#define DMC_TIMINGROW 0x34
#define DMC_TIMINGDATA 0x38
#define DMC_TIMINGPOWER 0x3C
#define DMC_PHYSTATUS 0x40
#define DMC_CHIP0STATUS 0x48
#define DMC_CHIP1STATUS 0x4C
#define DMC_AREFSTATUS 0x50
#define DMC_MRSTATUS 0x54
#define DMC_PHYTEST0 0x58
#define DMC_PHYTEST1 0x5C
#define DMC_QOSCONTROL0 0x60
#define DMC_QOSCONFIG0 0x64
#define DMC_QOSCONTROL1 0x68
#define DMC_QOSCONFIG1 0x6C
#define DMC_QOSCONTROL2 0x70
#define DMC_QOSCONFIG2 0x74
#define DMC_QOSCONTROL3 0x78
#define DMC_QOSCONFIG3 0x7C
#define DMC_QOSCONTROL4 0x80
#define DMC_QOSCONFIG4 0x84
#define DMC_QOSCONTROL5 0x88
#define DMC_QOSCONFIG5 0x8C
#define DMC_QOSCONTROL6 0x90
#define DMC_QOSCONFIG6 0x94
#define DMC_QOSCONTROL7 0x98
#define DMC_QOSCONFIG7 0x9C
#define DMC_QOSCONTROL8 0xA0
#define DMC_QOSCONFIG8 0xA4
#define DMC_QOSCONTROL9 0xA8
#define DMC_QOSCONFIG9 0xAC
#define DMC_QOSCONTROL10 0xB0
#define DMC_QOSCONFIG10 0xB4
#define DMC_QOSCONTROL11 0xB8
#define DMC_QOSCONFIG11 0xBC
#define DMC_QOSCONTROL12 0xC0
#define DMC_QOSCONFIG12 0xC4
#define DMC_QOSCONTROL13 0xC8
#define DMC_QOSCONFIG13 0xCC
#define DMC_QOSCONTROL14 0xD0
#define DMC_QOSCONFIG14 0xD4
#define DMC_QOSCONTROL15 0xD8
#define DMC_QOSCONFIG15 0xDC
// SDRAM Controller
.globl ddr_init
ddr_init:
// DMC0 Drive Strength (Setting 2X)
ldr r0, =ELFIN_GPIO_BASE
ldr r1, =0x0000AAAA
str r1, [r0, #0x3cc]
str r1, [r0, #MP1_0DRV_SR_OFFSET]
ldr r1, =0x0000AAAA
str r1, [r0, #MP1_1DRV_SR_OFFSET]
ldr r1, =0x0000AAAA
str r1, [r0, #MP1_2DRV_SR_OFFSET]
ldr r1, =0x0000AAAA
str r1, [r0, #MP1_3DRV_SR_OFFSET]
ldr r1, =0x0000AAAA
str r1, [r0, #MP1_4DRV_SR_OFFSET]
ldr r1, =0x0000AAAA
str r1, [r0, #MP1_5DRV_SR_OFFSET]
ldr r1, =0x0000AAAA
str r1, [r0, #MP1_6DRV_SR_OFFSET]
ldr r1, =0x0000AAAA
str r1, [r0, #MP1_7DRV_SR_OFFSET]
ldr r1, =0x00002AAA
str r1, [r0, #MP1_8DRV_SR_OFFSET]
// DMC0 initialization at single Type
ldr r0, =APB_DMC_0_BASE
ldr r1, =0x00101000 @PhyControl0 DLL parameter setting, manual 0x00101000
str r1, [r0, #DMC_PHYCONTROL0]
ldr r1, =0x00000086 @PhyControl1 DLL parameter setting, LPDDR/LPDDR2 Case
str r1, [r0, #DMC_PHYCONTROL1]
ldr r1, =0x00101002 @PhyControl0 DLL on
ldr r1, =0x00101003 @PhyControl0 DLL start
find_lock_val:
ldr r1, [r0, #DMC_PHYSTATUS] @Load Phystatus register value
and r2, r1, #0x7
cmp r2, #0x7 @Loop until DLL is locked
bne find_lock_val
and r1, #0x3fc0
mov r2, r1, LSL #18
orr r2, r2, #0x100000
orr r2 ,r2, #0x1000
orr r1, r2, #0x3 @Force Value locking
// setting DDR2
ldr r1, =0x0FFF2010 @ConControl auto refresh off
str r1, [r0, #DMC_CONCONTROL]
ldr r1, =DMC0_MEMCONTROL @MemControl BL=4, 1 chip, DDR2 type, dynamic self refresh, force precharge, dynamic power down off
str r1, [r0, #DMC_MEMCONTROL]
ldr r1, =DMC0_MEMCONFIG_0 @MemConfig0 256MB config, 8 banks,Mapping Method[12:15]0:linear, 1:linterleaved, 2:Mixed
str r1, [r0, #DMC_MEMCONFIG0]
ldr r1, =DMC0_MEMCONFIG_1 @MemConfig1
str r1, [r0, #DMC_MEMCONFIG1]
ldr r1, =0xFF000000 @PrechConfig
str r1, [r0, #DMC_PRECHCONFIG]
ldr r1, =DMC0_TIMINGA_REF @TimingAref 7.8us*133MHz=1038(0x40E), 100MHz=780(0x30C), 20MHz=156(0x9C), 10MHz=78(0x4E)
str r1, [r0, #DMC_TIMINGAREF]
ldr r1, =DMC0_TIMING_ROW @TimingRow for @200MHz
str r1, [r0, #DMC_TIMINGROW]
ldr r1, =DMC0_TIMING_DATA @TimingData CL=4
str r1, [r0, #DMC_TIMINGDATA]
ldr r1, =DMC0_TIMING_PWR @TimingPower
str r1, [r0, #DMC_TIMINGPOWER]
ldr r1, =0x07000000 @DirectCmd chip0 Deselect
str r1, [r0, #DMC_DIRECTCMD]
ldr r1, =0x01000000 @DirectCmd chip0 PALL
ldr r1, =0x00020000 @DirectCmd chip0 EMRS2
ldr r1, =0x00030000 @DirectCmd chip0 EMRS3
ldr r1, =0x00010400 @DirectCmd chip0 EMRS1 (MEM DLL on, DQS# disable)
ldr r1, =0x00000542 @DirectCmd chip0 MRS (MEM DLL reset) CL=4, BL=4
ldr r1, =0x05000000 @DirectCmd chip0 REFA
ldr r1, =0x00000442 @DirectCmd chip0 MRS (MEM DLL unreset)
ldr r1, =0x00010780 @DirectCmd chip0 EMRS1 (OCD default)
ldr r1, =0x00010400 @DirectCmd chip0 EMRS1 (OCD exit)
ldr r1, =0x07100000 @DirectCmd chip1 Deselect
ldr r1, =0x01100000 @DirectCmd chip1 PALL
ldr r1, =0x00120000 @DirectCmd chip1 EMRS2
ldr r1, =0x00130000 @DirectCmd chip1 EMRS3
ldr r1, =0x00110400 @DirectCmd chip1 EMRS1 (MEM DLL on, DQS# disable)
ldr r1, =0x00100542 @DirectCmd chip1 MRS (MEM DLL reset) CL=4, BL=4
ldr r1, =0x05100000 @DirectCmd chip1 REFA
ldr r1, =0x00100442 @DirectCmd chip1 MRS (MEM DLL unreset)
ldr r1, =0x00110780 @DirectCmd chip1 EMRS1 (OCD default)
ldr r1, =0x00110400 @DirectCmd chip1 EMRS1 (OCD exit)
ldr r1, =0x0FF02030 @ConControl auto refresh on
ldr r1, =0xFFFF00FF @PwrdnConfig
str r1, [r0, #DMC_PWRDNCONFIG]
ldr r1, =0x00202400 @MemControl BL=4, 1 chip, DDR2 type, dynamic self refresh, force precharge, dynamic power down off
mov pc, lr
nand.c源码:
#define NFCONF (*(volatile unsigned int *)0xB0E00000)
#define NFCONT (*(volatile unsigned int *)0xB0E00004)
#define NFCMMD (*(volatile unsigned char *)0xB0E00008)
#define NFADDR (*(volatile unsigned char *)0xB0E0000C)
#define NFDATA (*(volatile unsigned char *)0xB0E00010)
#define NFSTAT (*(volatile unsigned int *)0xB0E00028)
#define MP0_3CON (*(volatile unsigned int *)0xE0200320)
#define MP0_1CON (*(volatile unsigned int *)0xE02002E0)
#define PAGE_SIZE 2048
#define NAND_SECTOR_SIZE_LP 2048
void wait_idle(void)
int i;
while(!(NFSTAT&(1<<0)));
for(i=0; i<10; i++);
void nand_select_chip(void)
int i;
NFCONT &= ~(1<<1);
void nand_deselect_chip(void)
NFCONT |= (1<<1);
void write_cmd(int cmd)
NFCMMD = cmd;
void write_addr(unsigned int addr)
int i;
NFADDR = (addr>>0) & 0xFF;
wait_idle();
NFADDR = (addr>>8) & 0x7;
wait_idle();
NFADDR = (addr>>11) & 0xFF;
wait_idle();
NFADDR = (addr>>19) & 0xFF;
wait_idle();
NFADDR = (addr>>27) & 0x1;
wait_idle();
unsigned char read_data(void)
return NFDATA;
static void nand_reset(void)
nand_select_chip();
write_cmd(0xff); // 复位命令
wait_idle();
nand_deselect_chip();
void nand_init(void)
// 设置时间参数(HCLK_PSYS = 667MHz/5 = 133MHz)
// TACLS[15:12]: TACLS = 1 1/133Mhz = 7.5ns
// TWRPH0[11:8]: TWRPH0 = 1 7.5ns * 2 = 15ns
// TWRPH1 [7:4]: TWRPH1 = 1 7.5ns * 2 = 15ns
// AddrCycle[1]: 1 = 指明地址周期为5次,这个是和2440的区别
NFCONF |= 1<<12 | 1<<8 | 1<<4;
NFCONF |= 1<<1;
// 使能NAND控制器
// 关闭片选信号
NFCONT |= (1<<0)|(1<<1);
// 设置相应管脚用于Nand Flash控制器
MP0_3CON = 0x22222222;
// 复位NAND Flash
nand_reset();
return;
// 读ID
void nand_read_id(char id[])
int i;
nand_select_chip();
write_cmd(0x90);
write_addr(0x00);
for (i = 0; i < 5; i++)
id[i] = read_data();
// 读一页的函数
void nand_read(unsigned char *buf, unsigned long start_addr, int size)
int i, j;
// 选中芯片
nand_select_chip();
for(i=start_addr; i < (start_addr + size);) {
// 发出READ0命令
write_cmd(0);
// Write Address
write_addr(i);
write_cmd(0x30);
wait_idle();
for(j=0; j < NAND_SECTOR_SIZE_LP; j++, i++) {
*buf = read_data();
buf++;
// 取消片选信号
void nand_write(int sdram_addr, int nand_addr, int size)
main.c源码:
#include "command.h"
#include "clock.h"
#include "led.h"
#include "uart.h"
#include "lib.h"
#include "nand.h"
#define CFG_PROMPT "WY_BOOT # " // Monitor Command Prompt
#define CFG_CBSIZE 256 // Console I/O Buffer Size
char *argv[10];
int readline (const char *const prompt)
char console_buffer[CFG_CBSIZE]; // console I/O buffer
char *buf = console_buffer;
int argc = 0;
int state = 0;
//puts(prompt);
wy_printf("%s",prompt);
gets(console_buffer);
while (*buf)
if (*buf != ' ' && state == 0)
argv[argc++] = buf;
state = 1;
if (*buf == ' ' && state == 1)
*buf = '\0';
state = 0;
buf++;
return argc;
void message(void)
wy_printf("\nThis bootloader support some command to test peripheral:\n");
wy_printf("Such as: LCD, IIS, BUZZER \n");
wy_printf("Try 'help' to learn them \n\n");
int main(void)
char buf[6];
int argc = 0;
int i = 0;
led_init(); // 设置对应管脚为输出
uart_init(); // 初始化UART0
nand_read_id(buf);
wy_printf("\n**********************************************************\n");
wy_printf(" wy_bootloader\n");
wy_printf(" vars: %d \n",2012);
wy_printf(" nand id:");
putchar_hex(buf[0]);
putchar_hex(buf[1]);
putchar_hex(buf[2]);
putchar_hex(buf[3]);
putchar_hex(buf[4]);
while (1)
argc = readline (CFG_PROMPT);
if(argc == 0 && i ==0)
message();
i=1;
run_command(argc, argv);
return 0;
command.c源码:
#include "lib.h"
#include "nand.h"
#include "setup.h"
int help(int argc, char * argv[])
wy_printf("do_command 《%s》 \n", argv[0]); //"《"为"
wy_printf("help message: \n");
wy_printf("md - memory dispaly\n");
wy_printf("mw - memory write\n");
wy_printf("nand read - nand read sdram_addr nand_addr size\n");
wy_printf("nand write - nand write sdram_addr nand_addr size\n");
wy_printf("bootm - boot zImage\n");
return 0;
int md(int argc, char * argv[])
unsigned long *p = (unsigned long *)0;
int i, j;
if (argc <= 1) {
wy_printf ("Usage:\n%s\n", "md address");
return 1;
if (argc >= 2)
p = (unsigned long *)atoi(argv[1]);
for (j = 0; j < 16; j++)
wy_printf("%x: ", p);
for (i = 0; i < 4; i++)
wy_printf("%x ", *p++);
wy_printf("\n");
return 0;
int mw(int argc, char * argv[])
int v = 0;
if (argc <= 2) {
wy_printf ("Usage:\n%s\n", "md address data");
return 1;
if (argc >= 2)
if (argc >= 3)
v = atoi(argv[2]);
*p = v;
return 0;
int nand(int argc, char *argv[])
int nand_addr, sdram_addr;
unsigned int size;
if (argc < 5)
wy_printf("nand read sdram_addr nand_addr size\n");
wy_printf("nand write sdram_addr nand_addr size\n");
return 0;
sdram_addr = atoi(argv[2]);
nand_addr = atoi(argv[3]);
size = atoi(argv[4]);
wy_printf("sdram 0x%x, nand 0x%x, size 0x%x\n", sdram_addr, nand_addr, size);
if (strcmp(argv[1], "read") == 0)
nand_read((unsigned char *)sdram_addr, nand_addr, size);
if (strcmp(argv[1], "write") == 0)
nand_write(sdram_addr, nand_addr, size);
wy_printf("nand %s finished!\n", argv[1]);
return 0;
const char cmd[] = "root=/dev/nfs nfsroot=192.168.1.104:/work/nfs_root/wy_fs ip=192.168.1.17 console=ttySAC0";
void init_tag(int addr)
struct tag * p;
int i;
p = (struct tag*) addr;
p->hdr.tag = ATAG_CORE;
p->hdr.size = tag_size(tag_core);
p->u.core.flags = 1;
p->u.core.pagesize = 4096;
p->u.core.rootdev = 0x00000000;
p = tag_next(p);
p->hdr.tag = ATAG_CMDLINE;
p->hdr.size = (sizeof (cmd) + sizeof(struct tag_header) + 3) >>2;
for(i=0; i< sizeof (cmd); i++)
p->u.cmdline.cmdline[i] = cmd[i];
p = tag_next(p);
p->hdr.tag = ATAG_MEM;
p->hdr.size = tag_size(tag_mem32);
p->u.mem.size = 256*1024*1024;
p->u.mem.start = 0x20000000;
p = tag_next(p);
p->hdr.tag = ATAG_NONE;
p->hdr.size = 0;
int bootm(int argc, char * argv[])
int addr = 0x20008000;
void (*fp)(int, int, int);
int taglist_mem_address = 0x20000100;
wy_printf("loading linux from 0x400000 to 0x20008000...\n");
nand_read(0x20008000, 0x400000, 0x800000);
fp = (void (*)(int, int, int))addr;
init_tag(taglist_mem_address);
wy_printf("boot linux ...\n");
fp(0, 2456, taglist_mem_address);
return 0;
void run_command(int argc, char * argv[])
if (strcmp(argv[0], "help") == 0)
help(argc, argv);
return;
if (strcmp(argv[0], "md") == 0)
md(argc, argv);
return;
if (strcmp(argv[0], "mw") == 0)
mw(argc, argv);
return;
if (strcmp(argv[0], "bootm") == 0)
bootm(argc, argv);
return;
if (strcmp(argv[0], "nand") == 0)
nand(argc, argv);
if(argc >= 1)
wy_printf("Unknown command '%s' - try 'help' \n",argv[0]);
return;
Makefile文件:
uart.bin:start.s main.c uart.c clock.c led.c lib.c command.c nand.c mem_setup.S
arm-linux-gcc -nostdlib -c start.s -o start.o
arm-linux-gcc -nostdlib -c main.c -o main.o
arm-linux-gcc -nostdlib -c uart.c -o uart.o
arm-linux-gcc -nostdlib -c lib.c -o lib.o
arm-linux-gcc -nostdlib -c clock.c -o clock.o
arm-linux-gcc -nostdlib -c led.c -o led.o
arm-linux-gcc -nostdlib -c command.c -o command.o
arm-linux-gcc -nostdlib -c nand.c -o nand.o
arm-linux-gcc -nostdlib -c mem_setup.S -o mem_setup.o
arm-linux-ld -T bootloader.lds start.o main.o uart.o lib.o clock.o led.o command.o nand.o mem_setup.o -o uart_elf
arm-linux-objcopy -O binary -S uart_elf uart.bin
clean:
rm -rf *.o *.bin uart_elf *.dis
bootloader.lds链接文件:
SECTIONS {
. = 0x36000010;
.text : {
* (.text)
. = ALIGN(4);
.rodata : {
* (.rodata)
. = ALIGN(4);
.data : {
* (.data)
. = ALIGN(4);
bss_start = .;
.bss : { *(.bss) *(COMMON) }
bss_end = .;
要成功启动Linux内核,无非就是要真确的传入函数theKernel(int zero, int arch, uint params)的参数,和跳到正确的地址去执行而已。(这些知识在韦东山自己写bootloader的相关视频中已经讲得非常的详细了)。
我就从三个参数入手吧:
参数一:必须为0,这就没有什么好讲解的了;
参数二:机器ID,该参数很重要,往往不能成功启动内核,就是该参数捣的鬼。
接下来我就讲讲如何一步一步找到自己内核的机器ID的:(也许对于很多人来说,接下来说的都是废话,但是为了顾及少部分人,再加上这章没有什么可以说的(韦老大把什么都说了),就请允许我把废话说完吧)
步骤如下(以S5PV210为例):
1).进入装有官方提供的配置文件的目录:cd arch/arm/configs/;
2).找到官方为S5PV210提供的配置文件,将其拷贝到要编译的内核的更目录下:
cp s5pv210_defconfig ../../..
3).将配置文件拷贝成.config文件:
cd ../../..
cp s5pv210_defconfig ./.config
4).make menuconfig
5).make uImage
6).当编译完成后,查看/arch/arm目录下面的哪个开发板被编译成为了.o文件,当然查找是要更具名字,看哪个像,然后进入该文件确认,我最终发现mach-s5pv210目录有点像,进去发现mach-smdkv210.c被编译成为了.o文件;
7).打开程序mach-smdkv210.c,发现:
MACHINE_START(SMDKV210, "SMDKV210")
这只是一个宏,他的参数一SMDKV210就和我们的机器ID密切相关,那么该是多少呢?
8).打开\arch\arm\tools\mach-types,在该文件下收索SMDKV210,发现如下:
smdkv210 MACH_SMDKV210 SMDKV210 2456
从而说明此时的机器ID是2456。
注意:
这个过程说得有点绕和啰嗦,再次抱歉。
参数三:一句话,实在是没有什么可以说的,韦老大的视频里面讲得太详细了!!
大家直接看视频和我上传的关于这章的代码吧,放在了"Tiny210学习日记_代码"目录下了,名为"9_bootm"。
注意:
本章写的代码,只能通过bootm命令来启动内核,延时自动启动内核,我会在后面章节讲到。
