//MCU:Mega16;晶振:8MHz;
//PWM:4KHz;滤波器频率:100Hz;系统频率:100Hz;10ms;
//二轮平衡机器人项目
#include
#include
#include
//#define checkbit(var,bit) (var&(0x01<
//#define setbit(var,bit) (var|=(0x01<
//#define clrbit(var,bit) (var&=(~(0x01<
//输出端口初始化
void PORT_initial(void)
DDRA=0B00000000;
PINA=0X00;
PORTA=0X00;
DDRB=0B00000000;
PINB=0X00;
PORTB=0X00;
DDRC=0B00010000;
PINC=0X00;
PORTC=0X00;
DDRD=0B11110010;
PIND=0X00;
PORTD=0X00;
//定时器1初始化
void T1_initial(void)
TCCR1A|=(1<
TCCR1B|=(1<
//定时器2初始化
void T2_initial(void) //T2:计数至OCR2时产生中断
OCR2=0X4E; //T2:计数20ms(0X9C)10ms(0X4E)时产生中断;
TIMSK|=(1<
TCCR2|=(1<
//外部中断初始化
void INT_initial(void)
MCUCR|=(1<
GICR|=(1<
//串口初始化;
void USART_initial( void )
UBRRH = 0X00;
UBRRL = 51; //f=8MHz;设置波特率:9600:51;19200:25;
UCSRB = (1<
UCSRC = (1<
UCSRB|=(1<
//串口发送数据;
void USART_Transmit( unsigned char data )
while ( !( UCSRA & (1<
UDR = data; //将数据放入缓冲器,发送数据;
//串口接收数据中断,确定数据输出的状态;
#pragma interrupt_handler USART_Receive_Int:12
static char USART_State;
void USART_Receive_Int(void)
USART_State=UDR;//USART_Receive();
//计算LH侧轮速:INT0中断;
static int speed_real_LH;
#pragma interrupt_handler SPEEDLHINT_fun:2
void SPEEDLHINT_fun(void)
if (0==(PINB&BIT(0)))
speed_real_LH-=1;
else
speed_real_LH+=1;
//计算RH侧轮速,:INT1中断;
//同时将轮速信号统一成前进方向了;
static int speed_real_RH;
#pragma interrupt_handler SPEEDRHINT_fun:3
void SPEEDRHINT_fun(void)
if (0==(PINB&BIT(1)))
speed_real_RH+=1;
else
speed_real_RH-=1;
//ADport采样:10位,采样基准电压Aref
static int AD_data;
int ADport(unsigned char port)
ADMUX=port;
ADCSRA|=(1<
while(!(ADCSRA&(BIT(ADIF))));
AD_data=ADCL;
AD_data+=ADCH*256;
AD_data-=512;
return (AD_data);
//Kalman滤波,8MHz的处理时间约1.8ms;
static float angle, angle_dot; //外部需要引用的变量
static const float Q_angle=0.001, Q_gyro=0.003, R_angle=0.5, dt=0.01;
//注意:dt的取值为kalman滤波器采样时间;
static float P[2][2] = {
{ 1, 0 },
{ 0, 1 }
static float Pdot[4] ={0,0,0,0};
static const char C_0 = 1;
static float q_bias, angle_err, PCt_0, PCt_1, E, K_0, K_1, t_0, t_1;
void Kalman_Filter(float angle_m,float gyro_m) //gyro_m:gyro_measure
angle+=(gyro_m-q_bias) * dt;
Pdot[0]=Q_angle - P[0][1] - P[1][0];
Pdot[1]=- P[1][1];
Pdot[2]=- P[1][1];
Pdot[3]=Q_gyro;
P[0][0] += Pdot[0] * dt;
P[0][1] += Pdot[1] * dt;
P[1][0] += Pdot[2] * dt;
P[1][1] += Pdot[3] * dt;
angle_err = angle_m - angle;
PCt_0 = C_0 * P[0][0];
PCt_1 = C_0 * P[1][0];
E = R_angle + C_0 * PCt_0;
K_0 = PCt_0 / E;
K_1 = PCt_1 / E;
t_0 = PCt_0;
t_1 = C_0 * P[0][1];
P[0][0] -= K_0 * t_0;
P[0][1] -= K_0 * t_1;
P[1][0] -= K_1 * t_0;
P[1][1] -= K_1 * t_1;
angle += K_0 * angle_err;
q_bias += K_1 * angle_err;
angle_dot = gyro_m-q_bias;
//互补滤波
static float angle,angle_dot; //外部需要引用的变量
static float bias_cf;
static const float dt=0.01;
void complement_filter(float angle_m_cf,float gyro_m_cf)
bias_cf*=0.998; //陀螺仪零飘低通滤波;500次均值;
bias_cf+=gyro_m_cf*0.002;
angle_dot=gyro_m_cf-bias_cf;
angle=(angle+angle_dot*dt)*0.90+angle_m_cf*0.05;
//加速度低通滤波;20次均值;按100次每秒计算,低通5Hz;
//AD采样;
//以角度表示;
//加速度计:1.2V=1g=90°;满量程:1.3V~3.7V;
//陀螺仪:0.5V~4.5V=-80°~+80°;满量程5V=200°=256=200°;
static float gyro,acceler;
void AD_calculate(void)
acceler=ADport(2)+28; //角度校正
gyro=ADport(3);
acceler*=0.004069; //系数换算:2.5/(1.2*512); // 5/(1.2*1024);5为参考电压5V;1.2V灵敏度对应加速度1g;1024为AD精度
acceler=asin(acceler); //反正弦求角度
gyro*=0.00341; //角速度系数:(3.14/180)* 100/512=0.01364;//(3.14/180)* (200*0.025)/1024*0.025既5/1024*0.025
//求得角速度 单位 角度/秒
Kalman_Filter(acceler,gyro); //卡尔曼滤波 带入角度。角速度
//complement_filter(acceler,gyro);
//PWM输出
void PWM_output (int PWM_LH,int PWM_RH)
if (PWM_LH<0)
PORTD|=BIT(6);
PWM_LH*=-1;
else
PORTD&=~BIT(6);
if (PWM_LH>252)
PWM_LH=252;
if (PWM_RH<0)
PORTD|=BIT(7);
PWM_RH*=-1;
else
PORTD&=~BIT(7);
if (PWM_RH>252)
PWM_RH=252;
OCR1AH=0;
OCR1AL=PWM_LH; //OC1A输出;
OCR1BH=0;
OCR1BL=PWM_RH; //OC1B输出;
//计算PWM输出值
//车辆直径:76mm; 12*64pulse/rev; 1m=3216pulses;
//static int speed_diff,speed_diff_all,speed_diff_adjust;
//static float K_speed_P,K_speed_I;
static float K_voltage,K_angle,K_angle_dot,K_position,K_position_dot;
static float K_angle_AD,K_angle_dot_AD,K_position_AD,K_position_dot_AD;
static float position,position_dot;
static float position_dot_filter;
static float PWM;
static int speed_output_LH,speed_output_RH;
static int Turn_Need,Speed_Need;
void PWM_calculate(void)
if ( 0==(~PINA&BIT(1)) ) //左转
Turn_Need=-40;
else if ( 0==(~PINB&BIT(2)) ) //右转
Turn_Need=40;
else //不转
Turn_Need=0;
if ( 0==(~PINC&BIT(0)) ) //前进
Speed_Need=-2;
else if ( 0==(~PINC&BIT(1)) ) //后退
Speed_Need=2;
else //不动
Speed_Need=0;
K_angle_AD=ADport(4)*0.007;
K_angle_dot_AD=ADport(5)*0.007;
K_position_AD=ADport(6)*0.007;
K_position_dot_AD=ADport(7)*0.007;
position_dot=PWM*0.04;
position_dot_filter*=0.9; //车轮速度滤波
position_dot_filter+=position_dot*0.1;
position+=position_dot_filter;
//position+=position_dot;
position+=Speed_Need;
if (position
position=-768;
else if (position>768)
position=768;
PWM = K_angle*angle *K_angle_AD + K_angle_dot*angle_dot *K_angle_dot_AD +
K_position*position *K_position_AD + K_position_dot*position_dot_filter *K_position_dot_AD;
speed_output_RH = PWM;// - Turn_Need;
speed_output_LH = - PWM;// - Turn_Need ;
speed_diff=speed_real_RH-speed_real_LH; //左右轮速差PI控制;
speed_diff_all+=speed_diff;
speed_di
