下面是原理图:
下面是SHT11与MCU连接的典型电路:
下面是源代码:
- #include
- #include
- 宏定义
- #define uint unsigned int
- #define uchar unsigned char
- #define noACK 0
- #define ACK 1
- #define STATUS_REG_W 0x06
- #define STATUS_REG_R 0x07
- #define MEASURE_TEMP 0x03
- #define MEASURE_HUMI 0x05
- #define RESET 0x1e
- enum {TEMP,HUMI};
- typedef union //定义共用同类型
- unsigned int i;
- float f;
- } value;
- 位定义
- sbit lcdrs=P2^0;
- sbit lcdrw=P2^1;
- sbit lcden=P2^2;
- sbit SCK = P1^0;
- sbit DATA = P1^1;
- 变量定义
- uchar table2[]="SHT11 温湿度检测";
- uchar table3[]="温度为: ℃";
- uchar table4[]="湿度为:";
- uchar table5[]=".";
- uchar wendu[6];
- uchar shidu[6];
- 1ms延时函数
- void delay(int z)
- int x,y;
- for(x=z;x>0;x--)
- for(y=125;y>0;y--);
- 50us延时函数
- void delay_50us(uint t)
- uint j;
- for(;t>0;t--)
- for(j=19;j>0;j--);
- 50ms延时函数
- void delay_50ms(uint t)
- uint j;
- for(;t>0;t--)
- for(j=6245;j>0;j--);
- 12864液晶写指令
- void write_12864com(uchar com)
- lcdrs=0;
- lcdrw=0;
- delay_50us(1);
- P0=com;
- lcden=1;
- delay_50us(10);
- lcden=0;
- delay_50us(2);
- 12864液晶写数据
- void write_dat(uchar dat)
- lcdrs=1;
- lcdrw=0;
- delay_50us(1);
- P0=dat;
- lcden=1;
- delay_50us(10);
- lcden=0;
- delay_50us(2);
- 12864液晶初始化
- void init12864lcd(void)
- delay_50ms(2);
- write_12864com(0x30);
- delay_50us(4);
- delay_50us(4);
- write_12864com(0x0f);
- delay_50us(4);
- write_12864com(0x01);
- delay_50us(240);
- write_12864com(0x06);
- delay_50us(10);
- write_12864com(0x0c);
- delay_50us(10);
- 12864液晶显示函数
- void display1(void)
- uchar i;
- write_12864com(0x80);
- for(i=0;i<18;i++)
- write_dat(table2[i]);
- delay_50us(1);
- 12864液晶显示函数
- void display2(void)
- uchar i;
- write_12864com(0x90);
- for(i=0;i<18;i++)
- write_dat(table3[i]);
- delay_50us(1);
- 12864液晶显示函数
- void display3(void)
- uchar i;
- write_12864com(0x88);
- for(i=0;i<8;i++)
- write_dat(table4[i]);
- delay_50us(1);
- 12864液晶显示函数
- void displaywendu(void)
- uchar i;
- write_12864com(0x94);
- for(i=0;i<3;i++)
- write_dat(wendu[i]);
- delay_50us(1);
- for(i=0;i<1;i++)
- write_dat(table5[i]);
- delay_50us(1);
- for(i=4;i<5;i++)
- delay_50us(1);
- 12864液晶显示函数
- void displayshidu(void)
- uchar i;
- write_12864com(0x8C);
- for(i=0;i<3;i++)
- write_dat(shidu[i]);
- delay_50us(1);
- for(i=0;i<1;i++)
- delay_50us(1);
- for(i=4;i<5;i++)
- delay_50us(1);
- SHT11写字节程序
- char s_write_byte(unsigned char value)
- unsigned char i,error=0;
- for (i=0x80;i>0;i>>=1) //高位为1,循环右移
- if (i&value) DATA=1; //和要发送的数相与,结果为发送的位
- else DATA=0;
- SCK=1;
- _nop_();_nop_();_nop_(); //延时3us
- SCK=0;
- DATA=1; //释放数据线
- SCK=1;
- error=DATA; //检查应答信号,确认通讯正常
- SCK=0;
- DATA=1;
- return error; //error=1 通讯错误
- SHT11读字节程序
- char s_read_byte(unsigned char ack)
- unsigned char i,val=0;
- DATA=1; //释放数据线
- for(i=0x80;i>0;i>>=1) //高位为1,循环右移
- SCK=1;
- if(DATA) val=(val|i); //读一位数据线的值
- SCK=0;
- DATA=!ack; //如果是校验,读取完后结束通讯;
- SCK=1;
- SCK=0;
- DATA=1; //释放数据线
- return val;
- SHT11启动传输
- void s_transstart(void)
- DATA=1; SCK=0; //准备
- _nop_();
- SCK=1;
- _nop_();
- DATA=0;
- _nop_();
- SCK=0;
- SCK=1;
- _nop_();
- DATA=1;
- _nop_();
- SCK=0;
- SHT11连接复位
- void s_connectionreset(void)
- unsigned char i;
- for(i=0;i<9;i++) //DATA保持高,SCK时钟触发9次,发送启动传输,通迅即复位
- SCK=1;
- SCK=0;
- s_transstart(); //启动传输
- SHT11温湿度检测
- char s_measure(unsigned char *p_value, unsigned char *p_checksum, unsigned char mode)
- unsigned error=0;
- unsigned int i;
- switch(mode) //选择发送命令
- case TEMP : error+=s_write_byte(MEASURE_TEMP); break; //测量温度
- case HUMI : error+=s_write_byte(MEASURE_HUMI); break; //测量湿度
- default : break;
- for (i=0;i<65535;i++) if(DATA==0) break; //等待测量结束
- if(DATA) error+=1; // 如果长时间数据线没有拉低,说明测量错误
- *(p_value) =s_read_byte(ACK); //读第一个字节,高字节 (MSB)
- *(p_value+1)=s_read_byte(ACK); //读第二个字节,低字节 (LSB)
- *p_checksum =s_read_byte(noACK); //read CRC校验码
- return error; // error=1 通讯错误
- SHT11温湿度值标度变换及温度补偿
- void calc_sth10(float *p_humidity ,float *p_temperature)
- const float C1=-4.0; // 12位湿度精度 修正公式
- const float C2=+0.0405; // 12位湿度精度 修正公式
- const float C3=-0.0000028; // 12位湿度精度 修正公式
- const float T1=+0.01; // 14位温度精度 5V条件 修正公式
- const float T2=+0.00008; // 14位温度精度 5V条件 修正公式
- float rh=*p_humidity; // rh: 12位 湿度
- float t=*p_temperature; // t: 14位 温度
- float rh_lin; // rh_lin: 湿度 linear值
- float rh_true; // rh_true: 湿度 ture值
- float t_C; // t_C : 温度 ℃
- t_C=t*0.01 - 40; //补偿温度
- rh_lin=C3*rh*rh + C2*rh + C1; //相对湿度非线性补偿
- rh_true=(t_C-25)*(T1+T2*rh)+rh_lin; //相对湿度对于温度依赖性补偿
- if(rh_true>100)rh_true=100; //湿度最大修正
- if(rh_true<0.1)rh_true=0.1; //湿度最小修正
- *p_temperature=t_C; //返回温度结果
- *p_humidity=rh_true; //返回湿度结果
- 主函数
- void main(void)
- unsigned int temp,humi;
- value humi_val,temp_val; //定义两个共同体,一个用于湿度,一个用于温度
- unsigned char error; //用于检验是否出现错误
- unsigned char checksum; //CRC
- init12864lcd();
- display1();
- display2();
- display3();
- s_connectionreset(); //启动连接复位
- while(1)
- error=0; //初始化error=0,即没有错误
- error+=s_measure((unsigned char*)&temp_val.i,&checksum,TEMP); //温度测量
- error+=s_measure((unsigned char*)&humi_val.i,&checksum,HUMI); //湿度测量
- if(error!=0) s_connectionreset(); ////如果发生错误,系统复位
- else
- humi_val.f=(float)humi_val.i; //转换为浮点数
- temp_val.f=(float)temp_val.i; //转换为浮点数
- calc_sth10(&humi_val.f,&temp_val.f); //修正相对湿度及温度
- temp=temp_val.f*10;
- humi=humi_val.f*10;
- wendu[0]=temp/1000+'0'; //温度百位
- wendu[1]=temp%1000/100+'0'; //温度十位
- wendu[2]=temp%100/10+'0'; //温度个位
- wendu[3]=0x2E; //小数点
- wendu[4]=temp%10+'0'; //温度小数点后第一位
- displaywendu();
- shidu[0]=humi/1000+'0'; //湿度百位
- shidu[1]=humi%1000/100+'0'; //湿度十位
- shidu[2]=humi%100/10+'0'; //湿度个位
- shidu[3]=0x2E; //小数点
- shidu[4]=humi%10+'0'; //湿度小数点后第一位
- displayshidu();
- delay(800); //等待足够长的时间,以现行下一次转换
