sbit LCD_RS=P3^4; // 定义IO口,具体1602的读控制线 sbit LCD_RW=P3^3; // 定义IO口,具体1602的写控制线 sbit LCD_EN=P2^0; // 定义IO口,具体1602的使能控制线 sbit Light=P3^7; // 定义IO口,具体1602的背光控制线(0:开通,1关闭) sbit D0 = P1^0; // 定义IO口,P1.0数据口1602LCD的D0口 sbit D1 = P1^1; // 定义IO口,P1.1数据口1602LCD的D1口 sbit D2 = P1^2; // 定义IO口,P1.2数据口1602LCD的D2口 sbit D3 = P1^3; // 定义IO口,P1.3数据口1602LCD的D3口 sbit D4 = P1^4; // 定义IO口,P1.4数据口1602LCD的D4口 sbit D5 = P1^5; // 定义IO口,P1.5数据口1602LCD的D5口 sbit D6 = P1^6; // 定义IO口,P1.6数据口1602LCD的D6口 sbit D7 = P2^1; // 定义IO口,P2.1数据口1602LCD的D7口 sbit B_0=B^0; // 定义变量B的位,方便位操作 sbit B_1=B^1; sbit B_2=B^2; sbit B_3=B^3; sbit B_4=B^4; sbit B_5=B^5; sbit B_6=B^6; sbit B_7=B^7;
void main(void) { P1M0 = 0x00; P1M1 = 0x00; // 配置P1口为准双向口 P2M0 = 0x00; P2M1 = 0x00; // 配置P2口为准双向口 P3M0 = 0x00; P3M1 = 0x80; // 配置P3.7口为强推挽输出(控制背光),其它IO口默认为准双向口(详细配置见STC12C56XXAD数据手册) Light = 0; // 开1602LCD的背光 lcd_init(); // LCD 初始化 lcd_write_char(0,0,'A'); //在坐标(0,0)处写入A lcd_write_char(1,0,'B'); //在坐标(1,0)处写入B lcd_write_char(2,0,'C'); //在坐标(2,0)处写入C lcd_write_char(3,0,'D'); //在坐标(3,0)处写入D lcd_write_char(4,0,'E'); //在坐标(4,0)处写入E lcd_write_char(5,0,'F'); //在坐标(5,0)处写入F lcd_write_char(6,0,'G'); //在坐标(6,0)处写入G lcd_write_char(7,0,'H'); //在坐标(7,0)处写入H lcd_write_char(8,0,'I'); //在坐标(8,0)处写入I lcd_write_char(9,0,'J'); //在坐标(9,0)处写入J lcd_write_char(10,0,'K'); //在坐标(10,0)处写入K lcd_write_char(11,0,'L'); //在坐标(11,0)处写入L lcd_write_char(12,0,'M'); //在坐标(12,0)处写入M lcd_write_char(13,0,'N'); //在坐标(13,0)处写入N lcd_write_char(14,0,'O'); //在坐标(14,0)处写入O lcd_write_char(15,0,'P'); //在坐标(15,0)处写入P lcd_write_char(0,1,'Q'); //在坐标(0,1)处写入Q lcd_write_char(1,1,'R'); //在坐标(1,1)处写入R lcd_write_char(2,1,'S'); //在坐标(2,1)处写入S lcd_write_char(3,1,'T'); //在坐标(3,1)处写入T lcd_write_char(4,1,'U'); //在坐标(4,1)处写入U lcd_write_char(5,1,'V'); //在坐标(5,1)处写入V lcd_write_char(6,1,'W'); //在坐标(6,1)处写入W lcd_write_char(7,1,'X'); //在坐标(7,1)处写入X lcd_write_char(8,1,'Y'); //在坐标(8,1)处写入Y lcd_write_char(9,1,'Z'); //在坐标(9,1)处写入Z while(1) // 进入程序主循环 { } } void delay1(int ms) // 延时子函数,用于模拟时序中高低电平的保持时间,非精确的定时 { unsigned char y; while(ms--) { for(y = 0; y<100; y++) { _nop_(); _nop_(); _nop_(); _nop_(); } } } //================================*/ // 1602检测判忙函数 */ //================================*/ bit lcd_busy() // 读写判断数据的D7读写位,用于判断1602是否忙 { bit result; D7 = 1; // 数据口D7置1,为读状态做准备 LCD_RS = 0; // 选择指令寄存 LCD_RW = 1; // 选择读控制线 LCD_EN = 1; // 开使能控制线 delayNOP(); // 时序延时 result = D7; // 读D7的电平 LCD_EN = 0; // 关使能 return(result); // 返回值1:忙,0可以执行操作 } //===============================*/ // 1602写命令函数 */ //===============================*/ void lcd_wcmd(uchar cmd) { while(lcd_busy()); // 判断等待 LCD_RS = 0; // 选择指令寄存 LCD_RW = 0; //选择写 LCD_EN = 0; // 开使能控制线 _nop_(); // 时序延时 _nop_(); // 时序延时 B = cmd; // 把命令字送入B D0 = B_0; // 把cmd的0位写入D0 D1 = B_1; // 把cmd的1位写入D1 D2 = B_2; // 把cmd的2位写入D2 D3 = B_3; // 把cmd的3位写入D3 D4 = B_4; // 把cmd的4位写入D4 D5 = B_5; // 把cmd的5位写入D5 D6 = B_6; // 把cmd的6位写入D6 D7 = B_7; // 把cmd的7位写入D7 delayNOP(); // 时序延时 LCD_EN = 1; // 使能控制线 delayNOP(); // 时序延时 LCD_EN = 0; // 关闭使能控制线 } //===========================*/ // 1602写数据函数 */ //===========================*/ void lcd_wdat(uchar dat) { while(lcd_busy()); // 判断等待 LCD_RS = 1; // 选择数据寄存器 LCD_RW = 0; // 选择写 LCD_EN = 0; // 使能控制线 B = dat; // 把databuf送入B D0 = B_0; // 把dat的0位写入D0 D1 = B_1; // 把dat的1位写入D1 D2 = B_2; // 把dat的2位写入D2 D3 = B_3; // 把dat的3位写入D3 D4 = B_4; // 把dat的4位写入D4 D5 = B_5; // 把dat的5位写入D5 D6 = B_6; // 把dat的6位写入D6 D7 = B_7; // 把dat的7位写入D7 delayNOP(); // 时序延时 LCD_EN = 1; // 开使能控制线 delayNOP(); // 时序延时 LCD_EN = 0; // 关使能控制线 } //=========================*/ // 1602 LCD初始化 */ //=========================*/ void lcd_init() { delay1(15); // 时序延时 lcd_wcmd(0x38); //16*2显示,5*7点阵,8位数据 delay1(5); // 时序延时 lcd_wcmd(0x38); delay1(5); // 时序延时 lcd_wcmd(0x38); delay1(5); // 时序延时 lcd_wcmd(0x0c); //显示开,关光标 delay1(5); lcd_wcmd(0x06); //移动光标 delay1(5); lcd_wcmd(0x01); //清除LCD的显示内容 delay1(5); } //====================*/ // 设置显示地址 */ //===================*/ void lcd_write_address(unsigned char x,unsigned char y) { x&=0x0f; //列地址限制在0-15 y&=0x01; //行地址限制在0-1 if(y==0x00) lcd_wcmd(x| 0x80); else //需要自行查看1602写地址的指令格式 lcd_wcmd((x +0x40) | 0x80); //第二行的列地址写入 } //========================*/ // 指定地址写入函数 */ //=====================*/ void lcd_write_char(unsigned char x,unsigned char y,unsigned char buf) { lcd_write_address(x,y); //写入地址 lcd_wdat(buf); //写入显示数据 }
