CMSIS Driver 都有着相似的 API 函数和相似的调用方法,它是在 ST HAL 库的基础上又进一步的封装,使用和配置起来都要比 ST HAL 库要方便和简单许多,并且还是跨平台的,非常有学习和使用的价值。今天学习 SPI API 的使用,详细介绍见 CMSIS Driver SPI API
SPI 发送与接收
* @file main.c
* @author XinLi
* @version v1.0
* @date 20-March-2018
* @brief Main program body.
* @attention
* This program is free software: you can redistribute it and/or modify
* it under the terms of the GNU General Public License as published by
* the Free Software Foundation, either version 3 of the License, or
* (at your option) any later version.
* This program is distributed in the hope that it will be useful,
* but WITHOUT ANY WARRANTY; without even the implied warranty of
* MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
* GNU General Public License for more details.
* You should have received a copy of the GNU General Public License
* along with this program. If not, see
/* Header includes -----------------------------------------------------------*/
#include "stm32f4xx.h"
#include "Driver_SPI.h"
#include
/* Macro definitions ---------------------------------------------------------*/
/* Type definitions ----------------------------------------------------------*/
/* Variable declarations -----------------------------------------------------*/
extern ARM_DRIVER_SPI Driver_SPI1;
/* Variable definitions ------------------------------------------------------*/
static uint8_t txBuffer[5] = {0xAB};
static uint8_t rxBuffer[5] = {0};
static uint8_t dataBuffer[5] = {0};
/* Function declarations -----------------------------------------------------*/
static void SPI1_Callback(uint32_t event);
static void SPI1_CS_Init(void);
static void SPI1_CS_Low(void);
static void SPI1_CS_High(void);
static void SystemClock_Config(void);
/* Function definitions ------------------------------------------------------*/
* @brief Main program.
* @param None.
* @return None.
int main(void)
/* STM32F4xx HAL library initialization:
- Configure the Flash prefetch, instruction and Data caches
- Configure the Systick to generate an interrupt each 1 msec
- Set NVIC Group Priority to 4
- Global MSP (MCU Support Package) initialization
HAL_Init();
/* Configure the system clock to 168 MHz */
SystemClock_Config();
SPI1_CS_Init();
Driver_SPI1.Initialize(SPI1_Callback);
Driver_SPI1.PowerControl(ARM_POWER_FULL);
Driver_SPI1.Control(ARM_SPI_MODE_MASTER |
ARM_SPI_CPOL0_CPHA0 |
ARM_SPI_MSB_LSB |
ARM_SPI_SS_MASTER_UNUSED |
ARM_SPI_DATA_BITS(8), 10000000);
SPI1_CS_Low();
Driver_SPI1.Transfer(txBuffer, rxBuffer, sizeof(txBuffer));
for(;;)
* @brief SPI1 callback function.
* @param event: SPI events notification mask.
* @return None.
if(event & ARM_SPI_EVENT_TRANSFER_COMPLETE)
SPI1_CS_High();
memcpy(dataBuffer, rxBuffer, sizeof(rxBuffer));
* @brief SPI1 CS pin initialize.
* @param None.
* @return None.
GPIO_InitTypeDef GPIO_InitStruct = {0};
/* GPIO Ports Clock Enable */
__HAL_RCC_GPIOB_CLK_ENABLE();
/* Configure GPIO pin : PtPin */
GPIO_InitStruct.Pin = GPIO_PIN_14;
GPIO_InitStruct.Mode = GPIO_MODE_OUTPUT_PP;
GPIO_InitStruct.Pull = GPIO_PULLUP;
GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_VERY_HIGH;
HAL_GPIO_Init(GPIOB, &GPIO_InitStruct);
/* Configure GPIO pin Output Level */
HAL_GPIO_WritePin(GPIOB, GPIO_PIN_14, GPIO_PIN_SET);
* @brief SPI1 CS pin level pull low.
* @param None.
* @return None.
HAL_GPIO_WritePin(GPIOB, GPIO_PIN_14, GPIO_PIN_RESET);
* @brief SPI1 CS pin level pull high.
* @param None.
* @return None.
* @brief System Clock Configuration
* The system Clock is configured as follow :
* System Clock source = PLL (HSE)
* SYSCLK(Hz) = 168000000
* HCLK(Hz) = 168000000
* AHB Prescaler = 1
* APB1 Prescaler = 4
* APB2 Prescaler = 2
* HSE Frequency(Hz) = 8000000
* PLL_M = 8
* PLL_N = 336
* PLL_P = 2
* PLL_Q = 7
* VDD(V) = 3.3
* Main regulator output voltage = Scale1 mode
* Flash Latency(WS) = 5
* @param None
* @retval None
RCC_ClkInitTypeDef RCC_ClkInitStruct;
RCC_OscInitTypeDef RCC_OscInitStruct;
/* Enable Power Control clock */
__HAL_RCC_PWR_CLK_ENABLE();
/* The voltage scaling allows optimizing the power consumption when the device is
clocked below the maximum system frequency, to update the voltage scaling value
regarding system frequency refer to product datasheet. */
__HAL_PWR_VOLTAGESCALING_CONFIG(PWR_REGULATOR_VOLTAGE_SCALE1);
/* Enable HSE Oscillator and activate PLL with HSE as source */
RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSE;
RCC_OscInitStruct.HSEState = RCC_HSE_ON;
RCC_OscInitStruct.PLL.PLLState = RCC_PLL_ON;
RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_HSE;
RCC_OscInitStruct.PLL.PLLM = 8;
RCC_OscInitStruct.PLL.PLLN = 336;
RCC_OscInitStruct.PLL.PLLP = RCC_PLLP_DIV2;
RCC_OscInitStruct.PLL.PLLQ = 7;
HAL_RCC_OscConfig(&RCC_OscInitStruct);
/* Select PLL as system clock source and configure the HCLK, PCLK1 and PCLK2
clocks dividers */
RCC_ClkInitStruct.ClockType = (RCC_CLOCKTYPE_SYSCLK | RCC_CLOCKTYPE_HCLK | RCC_CLOCKTYPE_PCLK1 | RCC_CLOCKTYPE_PCLK2);
RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_PLLCLK;
RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV1;
RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV4;
RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV2;
HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_5);
/* STM32F405x/407x/415x/417x Revision Z devices: prefetch is supported */
if (HAL_GetREVID() == 0x1001)
/* Enable the Flash prefetch */
__HAL_FLASH_PREFETCH_BUFFER_ENABLE();
