单片机 > 单片机程序设计 > 详情
AT24C128 EEPROM的读写
发布时间:2024-12-12 发布时间:
记录AT24C128 eeprom的多字节读写
  1. #define _EEPROM_DEBUG_LEVEL 0
  2.
  3. #if _EEPROM_DEBUG_LEVEL == 1
  4.          #defineEEPROM_DEBUG(fmt,args...) do{ \
  5.                    printf(fmt,##args);\
  6.          }while(0)
  7. #elif _EEPROM_DEBUG_LEVEL == 2
  8.          #defineEEPROM_DEBUG(fmt,args...) do{ \
  9.                    printf("%s:line:%d->",__FUNCTION__,__LINE__); \
  10.                    printf(fmt,##args);\
  11.          }while(0)
  12. #elif _EEPROM_DEBUG_LEVEL == 0
  13.          #defineEEPROM_DEBUG(fmt,args...)
  14. #else
  15.          #defineEEPROM_DEBUG(fmt,args...)
  16. #endif
[cpp] view plain copy
  1. #define AT24C128_PAGE_SIZE 64
  2. #define AT24C128_PAGE_COUNT 256
  3. #define AT24C128_BYTE_SIZE 16*1024
  4. #define AT24C128_WADDR 0xA0
  5. #define AT24C128_RADDR 0xA1
写时序:
  1. ///
  2. //// wrtie eeprom by page
  3. ////
  4. int writeE2promByPage(u32 startaddr,void* data,u32 len){
  5.
  6.     int retry=0,pageCnt =0,i=0,j=0,k =0;
  7.     u32 temp1=0,temp2=0,temp3=0,start=0,startPage;
  8.     u8 * pBuf;
  9.     pBuf = (u8*)data;
  10.     temp1 = startaddr % AT24C128_PAGE_SIZE;
  11.     temp2 = len % AT24C128_PAGE_SIZE;
  12.     temp3 = len / AT24C128_PAGE_SIZE;
  13.     startPage = startaddr / AT24C128_PAGE_SIZE;
  14.     if(temp1 ==0){
  15.         if(temp2 !=0) pageCnt = temp3 + 2;
  16.         else pageCnt = temp3 + 1;
  17.     }
  18.     else
  19.     {
  20.         if(temp2 !=0) pageCnt = temp3 + 3;
  21.         else pageCnt = temp3 + 2;
  22.     }
  23.
  24.     if(pageCnt > AT24C128_PAGE_COUNT) return -1;
  25.     EEPROM_DEBUG("pageCnt %d \r\n",pageCnt);
  26.     for(i=0;i
  27.         //start signal !!!
  28.         while(SCCB_Start() ==0){
  29.             if(retry > 100) {
  30.                 EEPROM_DEBUG("start fail \r\n");
  31.                 return -1;
  32.             }
  33.             retry++;
  34.         }
  35.         if(i == 0){
  36.             start = startaddr;
  37.             temp1 = AT24C128_PAGE_SIZE - startaddr;
  38.         }
  39.         else{
  40.             start = (startPage + i) * AT24C128_PAGE_SIZE;
  41.             temp1 = AT24C128_PAGE_SIZE;
  42.         }
  43.         EEPROM_DEBUG("start:%d \r\n",start);
  44.         EEPROM_DEBUG("temp1:%d \r\n",temp1);
  45.         //write slave addr
  46.         SCCB_writeByte(AT24C128_WADDR);
  47.         if(SCCB_Wait_Ack() == 0){
  48.               EEPROM_DEBUG("write addr fail \r\n");
  49.                 SCCB_Stop();
  50.                 goto _end;
  51.         }
  52.         //write page high addr
  53.         SCCB_writeByte(start / 256 );
  54.         if(SCCB_Wait_Ack() == 0){
  55.               EEPROM_DEBUG("write high page addr fail \r\n");
  56.                 SCCB_Stop();
  57.                 goto _end;
  58.         }
  59.         //write page low addr
  60.         SCCB_writeByte(start % 256 );
  61.         if(SCCB_Wait_Ack() == 0){
  62.                 EEPROM_DEBUG("write low page addr fail \r\n");
  63.                 SCCB_Stop();
  64.                 goto _end;
  65.         }
  66.         //write date
  67.         for(j = 0; j
  68.             SCCB_writeByte(pBuf[k]);
  69.             //write operation need slave response ack
  70.             if(SCCB_Wait_Ack() == 0){
  71.                 EEPROM_DEBUG("write data fail \r\n");
  72.                 SCCB_Stop();
  73.                 goto _end;
  74.             }
  75.             else{
  76.                 k++;
  77.             }
  78.             if( k == len){
  79.                 SCCB_Stop();
  80.                 goto _end;
  81.             }
  82.         }
  83.         EEPROM_DEBUG("page %d write success \r\n",i);
  84.         //stop
  85.         SCCB_Stop();
  86.         SCCB_Delay(SCL_TIME_US);
  87.     }
  88. _end:
  89.     return k;
  90. }
读取时序参考:
注意:Sequential read的时序图并不是完整的,根据文档描述Sequential read时序需要加上random的头!
即start -> slave waddr ->high addr -> low addr ->startagain ->slave raddr -> read n byte -> stop
注意写时候是wait ack ,需要eeprom回复!而读取的时候master只需要发送ack即可,读取的最后一个字节要发送的是noack。
  1. /*
  2. *SEQUENTIAL READ,can read multi byte!!!
  3. */
  4. int readE2promBySeq(u32 startaddr,void* data,u32 len){
  5.         int retry=0,j=0;
  6.         u8 * pBuf;
  7.         pBuf = (u8*)data;
  8.      //startc signal
  9.       SCCB_Delay(SCL_TIME_US);
  10.         while(SCCB_Start() ==0){
  11.                 if(retry > 100){
  12.                     EEPROM_DEBUG("start fail \r\n");
  13.                     return -1;
  14.                 }
  15.                 retry++;
  16.         }
  17.             //write slave w addr
  18.         SCCB_writeByte(AT24C128_WADDR);
  19.         if(SCCB_Wait_Ack() == 0){
  20.                 EEPROM_DEBUG("write slave w addr fail \r\n");
  21.                 SCCB_Stop();
  22.                 goto _end;
  23.         }
  24.         //write high addr
  25.         SCCB_writeByte(startaddr / 256 );
  26.         if(SCCB_Wait_Ack() == 0){
  27.             EEPROM_DEBUG("write h addr fail \r\n");
  28.             SCCB_Stop();
  29.             goto _end;
  30.         }
  31.         //write low addr
  32.         SCCB_writeByte(startaddr % 256 );
  33.         if(SCCB_Wait_Ack() == 0){
  34.             EEPROM_DEBUG("write l addr fail \r\n");
  35.             SCCB_Stop();
  36.             goto _end;
  37.         }
  38.         //start again
  39.         retry = 0;
  40.         while(SCCB_Start() ==0){
  41.                 if(retry > 100){
  42.                     EEPROM_DEBUG("start fail \r\n");
  43.                     return -1;
  44.                 }
  45.                 retry++;
  46.         }
  47.         //write slave read addr
  48.         SCCB_writeByte(AT24C128_RADDR);
  49.         if(SCCB_Wait_Ack() == 0){
  50.                     EEPROM_DEBUG("write r addr fail \r\n");
  51.                     SCCB_Stop();
  52.                     goto _end;
  53.         }
  54.
  55.         //read data
  56.         for(j = 0; j
  57.             pBuf[j] = SCCB_readByte();
  58.             if(j
  59.                 //read operation ,master just send ack ,no response
  60.                 SCCB_Ack();
  61.             }
  62.         }
  63.         SCCB_noAck();
  64.         SCCB_Stop();
  65. _end:
  66.     return j;
  67. }
stm32f4 - 时钟树分析配置
