#include
#include
#include
void main(void)
PORTB=0;
PORTC=0;
DDRB=255;
DDRC=255;
delay_ms(100);
RESET=1; //复位
delay_ms(100);
ks0108cls(); //清屏
ks0108putchar(’A’);
ks0108gotoxy(70,2);
ks0108putchar(’#’);
while(1)
//文件
//www.avrDIY.com
#define RESET PORTB.2
#define RS PORTB.3
#define RW PORTB.4
#define E PORTB.5
#define CS1 PORTB.6
#define CS2 PORTB.7
#define DATA PORTC
#include
//由于ks0108没有读坐标指令,所以就用2个全局变量来记录坐标
unsigned char ks0108x,ks0108y;
flash unsigned char data[]={
0x00, 0x00, 0x00, 0x00, 0x00, // sp
0x00, 0x00, 0x2f, 0x00, 0x00, // !
0x00, 0x07, 0x00, 0x07, 0x00, // "
0x14, 0x7f, 0x14, 0x7f, 0x14, // #
0x24, 0x2a, 0x7f, 0x2a, 0x12, // $
0x62, 0x64, 0x08, 0x13, 0x23, // %
0x36, 0x49, 0x55, 0x22, 0x50, // &
0x00, 0x05, 0x03, 0x00, 0x00, // ’
0x00, 0x1c, 0x22, 0x41, 0x00, // (
0x00, 0x41, 0x22, 0x1c, 0x00, // )
0x14, 0x08, 0x3E, 0x08, 0x14, // *
0x08, 0x08, 0x3E, 0x08, 0x08, // +
0x00, 0x00, 0xA0, 0x60, 0x00, // ,
0x08, 0x08, 0x08, 0x08, 0x08, // -
0x00, 0x60, 0x60, 0x00, 0x00, // .
0x20, 0x10, 0x08, 0x04, 0x02, // /
0x3E, 0x51, 0x49, 0x45, 0x3E, // 0
0x00, 0x42, 0x7F, 0x40, 0x00, // 1
0x42, 0x61, 0x51, 0x49, 0x46, // 2
0x21, 0x41, 0x45, 0x4B, 0x31, // 3
0x18, 0x14, 0x12, 0x7F, 0x10, // 4
0x27, 0x45, 0x45, 0x45, 0x39, // 5
0x3C, 0x4A, 0x49, 0x49, 0x30, // 6
0x01, 0x71, 0x09, 0x05, 0x03, // 7
0x36, 0x49, 0x49, 0x49, 0x36, // 8
0x06, 0x49, 0x49, 0x29, 0x1E, // 9
0x00, 0x36, 0x36, 0x00, 0x00, // :
0x00, 0x56, 0x36, 0x00, 0x00, // ;
0x08, 0x14, 0x22, 0x41, 0x00, // 0x14, 0x14, 0x14, 0x14, 0x14, // =
0x00, 0x41, 0x22, 0x14, 0x08, // >
0x02, 0x01, 0x51, 0x09, 0x06, // ?
0x32, 0x49, 0x59, 0x51, 0x3E, // @
0x7C, 0x12, 0x11, 0x12, 0x7C, // A
0x7F, 0x49, 0x49, 0x49, 0x36, // B
0x3E, 0x41, 0x41, 0x41, 0x22, // C
0x7F, 0x41, 0x41, 0x22, 0x1C, // D
0x7F, 0x49, 0x49, 0x49, 0x41, // E
0x7F, 0x09, 0x09, 0x09, 0x01, // F
0x3E, 0x41, 0x49, 0x49, 0x7A, // G
0x7F, 0x08, 0x08, 0x08, 0x7F, // H
0x00, 0x41, 0x7F, 0x41, 0x00, // I
0x20, 0x40, 0x41, 0x3F, 0x01, // J
0x7F, 0x08, 0x14, 0x22, 0x41, // K
0x7F, 0x40, 0x40, 0x40, 0x40, // L
0x7F, 0x02, 0x0C, 0x02, 0x7F, // M
0x7F, 0x04, 0x08, 0x10, 0x7F, // N
0x3E, 0x41, 0x41, 0x41, 0x3E, // O
0x7F, 0x09, 0x09, 0x09, 0x06, // P
0x3E, 0x41, 0x51, 0x21, 0x5E, // Q
0x7F, 0x09, 0x19, 0x29, 0x46, // R
0x46, 0x49, 0x49, 0x49, 0x31, // S
0x01, 0x01, 0x7F, 0x01, 0x01, // T
0x3F, 0x40, 0x40, 0x40, 0x3F, // U
0x1F, 0x20, 0x40, 0x20, 0x1F, // V
0x3F, 0x40, 0x38, 0x40, 0x3F, // W
0x63, 0x14, 0x08, 0x14, 0x63, // X
0x07, 0x08, 0x70, 0x08, 0x07, // Y
0x61, 0x51, 0x49, 0x45, 0x43, // Z
0x00, 0x7F, 0x41, 0x41, 0x00, // [
0x55, 0x2A, 0x55, 0x2A, 0x55, // 55
0x00, 0x41, 0x41, 0x7F, 0x00, // ]
0x04, 0x02, 0x01, 0x02, 0x04, // ^
0x40, 0x40, 0x40, 0x40, 0x40, // _
0x00, 0x01, 0x02, 0x04, 0x00, // ’
0x20, 0x54, 0x54, 0x54, 0x78, // a
0x7F, 0x48, 0x44, 0x44, 0x38, // b
0x38, 0x44, 0x44, 0x44, 0x20, // c
0x38, 0x44, 0x44, 0x48, 0x7F, // d
0x38, 0x54, 0x54, 0x54, 0x18, // e
0x08, 0x7E, 0x09, 0x01, 0x02, // f
0x18, 0xA4, 0xA4, 0xA4, 0x7C, // g
0x7F, 0x08, 0x04, 0x04, 0x78, // h
0x00, 0x44, 0x7D, 0x40, 0x00, // i
0x40, 0x80, 0x84, 0x7D, 0x00, // j
0x7F, 0x10, 0x28, 0x44, 0x00, // k
0x00, 0x41, 0x7F, 0x40, 0x00, // l
0x7C, 0x04, 0x18, 0x04, 0x78, // m
0x7C, 0x08, 0x04, 0x04, 0x78, // n
0x38, 0x44, 0x44, 0x44, 0x38, // o
0xFC, 0x24, 0x24, 0x24, 0x18, // p
0x18, 0x24, 0x24, 0x18, 0xFC, // q
0x7C, 0x08, 0x04, 0x04, 0x08, // r
0x48, 0x54, 0x54, 0x54, 0x20, // s
0x04, 0x3F, 0x44, 0x40, 0x20, // t
0x3C, 0x40, 0x40, 0x20, 0x7C, // u
0x1C, 0x20, 0x40, 0x20, 0x1C, // v
0x3C, 0x40, 0x30, 0x40, 0x3C, // w
0x44, 0x28, 0x10, 0x28, 0x44, // x
0x1C, 0xA0, 0xA0, 0xA0, 0x7C, // y
0x44, 0x64, 0x54, 0x4C, 0x44, // z
0x00, 0x08, 0x36, 0x41, 0x00, // {
0x00, 0x00, 0x7F, 0x00, 0x00, // |
0x00, 0x41, 0x36, 0x08, 0x00, // }
0x08, 0x10, 0x08, 0x04, 0x08 // ~
void ks0108rs0 (unsigned char rs) //写一个指令
E=1; RS=0; RW=0;
DATA=rs;
E=0;
delay_ms(1); //KS0108真是慢,写指令/数据都要适当延时
void ks0108putbyte (unsigned char datas) //写一个字节
if(ks0108x>127) //显示到最后列时就退出本函数,并停止写显示数据
return;
if(ks0108x<64) //判断列地址,确定在左屏还是在右屏写数据
{ CS1=1; CS2=0; }
else
{ CS1=0; CS2=1; }
E=1; RS=1; RW=0; //写一个显示数据
DATA=datas;
E=0;
ks0108x++; //每写一个数据,列地址就要加1
delay_ms(1);
void ks0108putchar (unsigned char ASCII) //写一个字符(就是写6个数据)
unsigned char i;
unsigned int No;
No=ASCII-32; //字模数据是由空格’ ’开始,空格的ASCII的值就是32
No=No*5; //每个字符的字模是5个字节
ks0108putbyte(0); //每个字符之间空一列
for(i=0;i<5;i++) //一个字符的字模是5个字节,就是5*8点阵
ks0108putbyte(data[No]);
No++;
void ks0108gotoxy (unsigned char x,unsigned char y) //写列/行地址
if(x>127) x=0; //如果列地址超出范围就回到0列
if(y> 7) y=0; //如果行地址超出范围就回到0行
CS1=1; //左右屏都使能,写下相同的行地址
CS2=1;
ks0108rs0(y+184); //写页(行)地址,共有8页,第0页地址是184
if(x<64) //写列地址,共有64列,第0列地址是64
{ CS1=1; CS2=0; ks0108rs0(x+64); }
else
{ CS1=0; CS2=1; ks0108rs0(x); };
ks0108x=x; //记住列/行地址
ks0108y=y;
void ks0108cls (void) //清屏,光标回到左半屏左上角
unsigned char i0,i1;
CS1=1; //左/右屏都使能
CS2=1;
ks0108rs0(63); //打开显示
ks0108rs0(64); //列地址回到0
for(i0=0;i0<8;i0++) //页地址由7变到0
ks0108rs0(191-i0);
for(i1=0;i1<64;i1++)//对某一行全写入0
E=1; RS=1; RW=0;
DATA=0;
E=0;
delay_ms(1);
CS2=0;
ks0108x=0;
ks0108y=0;
