* DETERMINE IF WE HAVE A LEAP YEAR
* Description : This function determines whether the 'year' passed as an argument is a leap year.
* Arguments : year is the year to check for leap year.
* Returns : TRUE if 'year' is a leap year.
* FALSE if 'year' is NOT a leap year.
#if CLK_DATE_EN
static BOOL ClkIsLeapYear(UINT year)
if (!(year % 4) && (year % 100) || !(year % 400))
return TRUE;
else
return (FALSE);
#endif
* SET DATE ONLY
* Description : Set the date of the time-of-day clock
* Arguments : month is the desired month (1..12)
* day is the desired day (1..31)
* year is the desired year (CLK_TS_BASE_YEAR .. CLK_TS_BASE_YEAR+63)
* Returns : None.
* Notes : It is assumed that you are specifying a correct date (i.e. there is no range checking
* done by this function).
#if CLK_DATE_EN
void Clk_set_date (UCHAR month, UCHAR day, UINT year)
ENTER_CRITICAL();
ClkMonth = month;
ClkDay = day;
ClkYear = year;
ClkUpdateDOW();
EXIT_CRITICAL();
#endif
* SET DATE AND TIME
* Description : Set the date and time of the time-of-day clock
* year is the desired year (2xxx)
* hr is the desired hour (0..23)
* min is the desired minutes (0..59)
* sec is the desired seconds (0..59)
* Returns : None.
* Notes : It is assumed that you are specifying a correct date and time (i.e. there is no range
* checking done by this function).
#if CLK_DATE_EN
void Clk_set_date_time (UCHAR month, UCHAR day, UINT year, UCHAR hr, UCHAR min, UCHAR sec)
ENTER_CRITICAL(); /* Gain exclusive access to time-of-day clock */
ClkMonth = month;
ClkDay = day;
ClkYear = year;
ClkHr = hr;
ClkMin = min;
ClkSec = sec;
ClkUpdateDOW(); /* Compute the day of the week (i.e. Sunday ...) */
EXIT_CRITICAL(); /* Release access to time-of-day clock */
#endif
* UPDATE THE DATE
* Description : This function is called to update the date (i.e. month, day and year)
* Arguments : None.
* Returns : None.
* Notes : This function updates ClkDay, ClkMonth, ClkYear and ClkDOW.
#if CLK_DATE_EN
static void ClkUpdateDate (void)
BOOL newmonth;
newmonth = TRUE;
if (ClkDay >= ClkMonthTbl[ClkMonth].MonthDays) { /* Last day of the month? */
if (ClkMonth == 2) { /* Is this February? */
if (ClkIsLeapYear(ClkYear) == TRUE) { /* Yes, Is this a leap year? */
if (ClkDay >= 29) { /* Yes, Last day in february? */
ClkDay = 1; /* Yes, Set to 1st day in March */
} else {
ClkDay++;
newmonth = FALSE;
} else {
ClkDay = 1;
} else {
ClkDay = 1;
} else {
ClkDay++;
newmonth = FALSE;
if (newmonth == TRUE) { /* See if we have completed a month */
if (ClkMonth >= 12) { /* Yes, Is this december ? */
ClkMonth = 1; /* Yes, set month to january... */
ClkYear++; /* ...we have a new year! */
} else {
ClkMonth++; /* No, increment the month */
#endif
* COMPUTE DAY-OF-WEEK
* Description : This function computes the day of the week (0 == Sunday) based on the current month,
* day and year.
* Arguments : None.
* Returns : None.
* Notes : - This function updates ClkDOW.
* - This function is called by ClkUpdateDate().
#if CLK_DATE_EN
static void ClkUpdateDOW (void)
UINT dow;
dow = ClkDay + ClkMonthTbl[ClkMonth].MonthVal;
if (ClkMonth < 3)
if (ClkIsLeapYear(ClkYear))
dow--;
dow += ClkYear + (ClkYear / 4);
dow += (ClkYear / 400) - (ClkYear / 100);
dow %= 7;
ClkDOW = dow;
#endif
// 功能: 给定的时间与当前时间比较
// 函数: int Cmp_now_time(UCHAR hr, UCHAR min, UCHAR sec)
// 语言: C
// 输入:
// 输出: 0 相等
// >0 给定时间大于当前时间
// <0 给定时间小于当前时间
if(ClkHr!=hr)
return(hr-ClkHr);
else if(ClkMin!= min)
return(min-ClkMin);
else
return(sec-ClkSec);
// 功能: 给定的时间与当前时间比较
// 函数: int Cmp_now_date_time(UCHAR month, UCHAR day, UINT year, UCHAR hr, UCHAR min, UCHAR sec)
// 语言: C
// 输入:
// 输出: 0 相等
// >0 给定时间大于当前时间
// <0 给定时间小于当前时间
#if CLK_DATE_EN
if(ClkYear!=year)
return(year-ClkYear);
else if(ClkMonth!=month)
return(month-ClkMonth);
else if(ClkDay!=day)
return(day-ClkDay);
else if(ClkHr!=hr)
return(hr-ClkHr);
return(min-ClkMin);
else
return(sec-ClkSec);
#endif
#endif
