今天介绍下我新完成的为Microchip的32位单片机PIC32MZ2048ECH144开发的UART bootloader程序。整个工程分两部分,第一部分是单片机端用XC32编译的bootloader程序PhsBoot_v5.0,另一部分是PC端用C#编译的bootloader通讯程序PhsLoader_v5.0。两者之间采用固定的协定通信合作,如下。
STX - Start of packet indicator
ETX - End of packet indicator
LEN - The length of true data
DATA - General data 16 bytes, only first LEN of datas are true
CMD - Base command
ADDR - Address up to 32 bits ( ADDRL , ADDRH , ADDRH, ADDRM)
具体有以下Base command:
RD-VER: 0x00 -- Read Version Information (最终版本未实现)
RD_MEM: 0x01 -- Read Program Memory (最终版本未实现)
ER_MEM: 0x03 -- Erase Program Memory
WR_MEM: 0x02 -- Write Program Memory
WR_CFG: 0x04 -- Write Configuration Registers (最终版本未实现)
PhsLoader_v5.0
PhsLoader_v5.0是PC端的程序,负责打开串口,加载应用程序hex文件,并按照上面介绍的协定进行组包然后发送出去。PhsLoader_v5.0是用C#开发的包含UI的程序,UI如下图。
PhsLoader_v5.0 的主要实现代码如下
private void btnLoad_Click(object sender, EventArgs e) { btnDownload.Enabled = false; textBoxStatus.AppendText("\r\nLoading hex file ...\r\n"); OpenFileDialog openDialog = new OpenFileDialog(); openDialog.Filter = "Hex files (*.hex)|*.hex"; if (openDialog.ShowDialog() == DialogResult.OK) { textBoxFile.Text = openDialog.FileName; string[] pathArray = textBoxFile.Text.Split('\\'); int pathDeep = pathArray.Count(); textBoxStatus.AppendText("Hex file: " + pathArray[pathDeep - 1] + "\r\n"); textBoxStatus.AppendText("Loading completed\r\n"); HexParse loaderParse = new HexParse(); textBoxStatus.AppendText("Parsing hex file ...\r\n"); if (loaderParse.IsHexFile(textBoxFile.Text)) { btnDownload.Enabled = true; loaderLines = loaderParse.HexLines; textBoxStatus.AppendText("Parsing completed\r\n"); } else { textBoxStatus.ForeColor = Color.Red; textBoxStatus.AppendText("Parsing failed\r\n"); textBoxStatus.ForeColor = Color.Black; } } else { textBoxStatus.ForeColor = Color.Red; textBoxStatus.AppendText("Loading failed\r\n\r\n"); textBoxStatus.ForeColor = Color.Black; } } private void btnDownload_Click(object sender, EventArgs e) { btnDownload.Enabled = false; if (!this.connect()) { btnDownload.Enabled = true; return; } try { loaderReader = new StreamReader(textBoxFile.Text); } catch (Exception ex) { Debug.WriteLine("Error: " + ex.Message); textBoxStatus.ForeColor = Color.Red; textBoxStatus.AppendText("Read hex file unsuccessfully\r\n"); textBoxStatus.ForeColor = Color.Black; loaderReader.Close(); loaderSerial.Close(); btnDownload.Enabled = true; return; } loaderFrame = new SerialFrame(); if (!erase()) { textBoxStatus.ForeColor = Color.Red; textBoxStatus.AppendText("Erase unsuccessfully\r\n"); textBoxStatus.ForeColor = Color.Black; loaderReader.Close(); loaderSerial.Close(); btnDownload.Enabled = true; return; } pBarLoading.Refresh(); pBarLoading.Visible = true; pBarLoading.Value = 0; pBarLoading.Maximum = loaderLines; pBarLoading.Step = 1; string recordLine; loaderUpperAddr = 0; bool isNextLineUserID = false; bool isNextLineConfigBits = false; textBoxStatus.AppendText("\r\nDownloading hex file ...\r\n"); try { while (loaderReader.Peek() >= 0) { pBarLoading.PerformStep(); recordLine = loaderReader.ReadLine(); //if (recordLine.Contains(USER_ID_TOKEN) == true) //{ // isNextLineUserID = true; // continue; //} //else if (recordLine.Contains(CONFIG_BITS_TOKEN) == true) //{ // isNextLineConfigBits = true; // continue; //} if (recordLine.Contains(EXTEND_TOKEN) == true) { if (recordLine.Contains(USER_ID_TOKEN) == true) { isNextLineUserID = true; continue; } else if (recordLine.Contains(CONFIG_BITS_TOKEN) == true) { const int ADDR_U_START_INDEX = 9; const int ADDR_U_LENGTH = 4; string addrU = recordLine.Substring(ADDR_U_START_INDEX, ADDR_U_LENGTH); loaderUpperAddr = Convert.ToInt32(addrU, 16) <
PhsBoot_v5.0
PhsBoot_v5.0是PIC32单片机端程序,放置在程序存储器中,放置的位置和我上一款PIC32 bootloader(HyperBootloader_PIC32)一样。所以他们的linker script也使用一样的。PhsBoot_v5.0主要功能是接收PhsLoader_v5.0发送过来的数据包,按照通信协定进行解包,分离出其中的地址和数据,并将数据按照PIC32的烧写时序烧录到对应的地址中。PhsBoot_v5.0 是用XC32开发的,主要的实现代码如下。
if (lineReceived) { if ((frameBuffer[0] == STX) && (frameBuffer[BUFFER_MAX-1] == ETX)) { switch (frameBuffer[CMD_INDEX]) { case WR_MEM: SourceAddr.byte.LB = frameBuffer[ADDRL_INDEX]; SourceAddr.byte.HB = frameBuffer[ADDRH_INDEX]; SourceAddr.byte.UB = frameBuffer[ADDRU_INDEX]; SourceAddr.byte.MB = frameBuffer[ADDRM_INDEX]; if ((SourceAddr.word.HW == 0x1fc0)) { SendResponse(); break; } int ix; for (ix=0;ix
如何使用PhsLoader_v5.0和PhsBoot_v5.0
1. 使用XC32编译PhsBoot_v5.0(编译前,需先修改linker script)。
2. 使用pickit3烧录PhsBoot_v5.0的Hex文件到目标板中。
3. 拔除pickit3烧录器
4. 连接目标板与PC的串口,打开PhsLoader_v5.0,选择COM端口,BAUD RATE。
5. 点击PhsLoader_v5.0用户界面上的“.."按钮加载需要烧录的应用程序Hex文件(编译前,需先修改linker script)
6. 重启目标板,等到LED1 灯亮了,立刻在PhsLoader_v4.0界面上点击Download按钮。如果超时未点击Download按钮,会自动跳转到上次烧录的应用程序中去。
7. 烧录完毕,再次重启目标板, 6秒后目标板开始正常运行应用程序。
之后每次更新应用程序,只需重复步骤 4 ~ 7 就可以了。注意,整个烧录过程未能实现Configuration Bits的烧写,所以需要保持应用程序的Configuration Bits和Bootloader的Configuration Bits一致。
