// led4 gpk7
// led3 gpk6
// led2 gpk5
// led1 gpk4 0 ,light
//u32 rGPIOKCON0; //0x7f008800
// u32 rGPIOKCON1; //0x7f008804
// u32 rGPIOKDAT; //0x7f008808
//u32 rGPIOKPUD; //0x7f00880c
#include "def.h"
#include "gpio.h"
#define led1on ~(1<<4)
#define led2on ~(1<<5)
#define led3on ~(1<<6)
#define led4on ~(1<<7)
void LedInit()
u32 TEMP;
GPIO->rGPIOKCON0 = 0X11112222;
TEMP = GPIO->rGPIOKPUD ;
TEMP &= (0XFF<<8);
TEMP = TEMP|(0XAA<<8);
GPIO->rGPIOKPUD = TEMP;
TEMP = GPIO->rGPIOKDAT ;
TEMP = TEMP&(0X0F);
GPIO->rGPIOKDAT = TEMP;
void delay(int times)
int i;
for(;times>0;times--)
for(i=0;i<3000;i++);
void Led(char num,char flag)
u32 temp;
temp = GPIO->rGPIOKDAT;
switch(num){
case 1: { if(flag) temp = temp&(led1on);
else temp |=temp | (~led1on);
GPIO->rGPIOKDAT = temp;break;}
case 2:{ if(flag) temp = temp&(led2on);
else temp |=temp | (~led2on);
case 3:{ if(flag) temp = temp&(led3on);
else temp |=temp | (~led3on);
case 4:{ if(flag) temp = temp&(led4on);
else temp |=temp | (~led4on);
default : break;
int main()
LedInit();
delay(1000);
while(1)
Led(1,1);
delay(1000);
Led(1,0);
delay(1000);
上面是c代码,main();
* Project Name : S3C6410 Validation
* Copyright 2006 by Samsung Electronics, Inc.
* All rights reserved.
* Project Description :
* This software is only for validating functions of the S3C6410.
* Anybody can use this software without our permission.
* File Name : gpio.h
* File Description : This file declares prototypes of GPIO API funcions.
* Author : Heemyung.Noh
* Dept. : AP Development Team
* Created Date : 2006/12/26
* Version : 0.1
* History
* - Created(Heemyung.Noh 2006/12/26)
* - Added EINT (Wonjoon.jang 2007/01/03)
#ifndef __GPIO_H__
#define __GPIO_H__
#ifdef __cplusplus
extern "C" {
#endif
#include "def.h"
#include "sfr6410.h"
#define Low_Level 0x0
#define High_Level 0x1
#define Falling_Edge 0x2
#define Rising_Edge 0x4
#define Both_Edge 0x6
#define GPIO ( ( volatile oGPIO_REGS * ) (GPIO_BASE))
typedef struct tag_GPIO_REGS
u32 rGPIOACON; //0x7F008000
u32 rGPIOADAT;
u32 rGPIOAPUD;
u32 rGPIOACONSLP;
u32 rGPIOAPUDSLP;
u32 reserved1[3];
u32 rGPIOBCON; //0x7F008020
u32 rGPIOBDAT;
u32 rGPIOBPUD;
u32 rGPIOBCONSLP;
u32 rGPIOBPUDSLP;
u32 reserved2[3];
u32 rGPIOCCON; //0x7F008040
u32 rGPIOCDAT;
u32 rGPIOCPUD;
u32 rGPIOCCONSLP;
u32 rGPIOCPUDSLP;
u32 reserved3[3];
u32 rGPIODCON; //0x7F008060
u32 rGPIODDAT;
u32 rGPIODPUD;
u32 rGPIODCONSLP;
u32 rGPIODPUDSLP;
u32 reserved4[3];
u32 rGPIOECON; //0x7F008080
u32 rGPIOEDAT;
u32 rGPIOEPUD;
u32 rGPIOECONSLP;
u32 rGPIOEPUDSLP;
u32 reserved5[3];
u32 rGPIOFCON; //0x7F0080A0
u32 rGPIOFDAT;
u32 rGPIOFPUD;
u32 rGPIOFCONSLP;
u32 rGPIOFPUDSLP;
u32 reserved6[3];
u32 rGPIOGCON; //0x7F0080C0
u32 rGPIOGDAT;
u32 rGPIOGPUD;
u32 rGPIOGCONSLP;
u32 rGPIOGPUDSLP;
u32 reserved7[3];
u32 rGPIOHCON0; //0x7F0080E0
u32 rGPIOHCON1;
u32 rGPIOHDAT;
u32 rGPIOHPUD;
u32 rGPIOHCONSLP;
u32 rGPIOHPUDSLP;
u32 reserved8[2];
u32 rGPIOICON; //0x7F008100
u32 rGPIOIDAT;
u32 rGPIOIPUD;
u32 rGPIOICONSLP;
u32 rGPIOIPUDSLP;
u32 reserved9[3];
u32 rGPIOJCON; //0x7F008120
u32 rGPIOJDAT;
u32 rGPIOJPUD;
u32 rGPIOJCONSLP;
u32 rGPIOJPUDSLP;
u32 reserved10[3];
u32 rGPIOOCON; //0x7F008140
u32 rGPIOODAT;
u32 rGPIOOPUD;
u32 rGPIOOCONSLP;
u32 rGPIOOPUDSLP;
u32 reserved11[3];
u32 rGPIOPCON; //0x7F008160
u32 rGPIOPDAT;
u32 rGPIOPPUD;
u32 rGPIOPCONSLP;
u32 rGPIOPPUDSLP;
u32 reserved12[3];
u32 rGPIOQCON; //0x7F008180
u32 rGPIOQDAT;
u32 rGPIOQPUD;
u32 rGPIOQCONSLP;
u32 rGPIOQPUDSLP;
u32 reserved13[3];
u32 rSPCON; //0x7F0081A0
u32 reserved14[3];
u32 rMEM0CONSTOP; //0x7F0081B0
u32 rMEM1CONSTOP; //0x7F0081B4
u32 reserved15[2];
u32 rMEM0CONSLP0; //0x7F0081C0
u32 rMEM0CONSLP1; //0x7F0081C4
u32 rMEM1CONSLP; //0x7F0081C8
u32 reserved;
u32 rMEM0DRVCON; //0x7F0081D0
u32 rMEM1DRVCON; //0x7F0081D4
u32 reserved16[10];
u32 rEINT12CON; //0x7f008200
u32 rEINT34CON; //0x7f008204
u32 rEINT56CON; //0x7f008208
u32 rEINT78CON; //0x7f00820C
u32 rEINT9CON; //0x7f008210
u32 reserved17[3];
u32 rEINT12FLTCON; //0x7f008220
u32 rEINT34FLTCON; //0x7f008224
u32 rEINT56FLTCON; //0x7f008228
u32 rEINT78FLTCON; //0x7f00822C
u32 rEINT9FLTCON; //0x7f008230
u32 reserved18[3];
u32 rEINT12MASK; //0x7f008240
u32 rEINT34MASK; //0x7f008244
u32 rEINT56MASK; //0x7f008248
u32 rEINT78MASK; //0x7f00824C
u32 rEINT9MASK; //0x7f008250
u32 reserved19[3];
u32 rEINT12PEND; //0x7f008260
u32 rEINT34PEND; //0x7f008264
u32 rEINT56PEND; //0x7f008268
u32 rEINT78PEND; //0x7f00826C
u32 rEINT9PEND; //0x7f008270
u32 reserved20[3];
u32 rPRIORITY; //0x7f008280
u32 rSERVICE; //0x7f008284
u32 rSERVICEPEND; //0x7f008288
u32 reserved21;
u32 reserved22[348];
u32 rGPIOLCON0; //0x7f008810
u32 rGPIOLCON1; //0x7f008814
u32 rGPIOLDAT; //0x7f008818
u32 rGPIOLPUD; //0x7f00881c
u32 rGPIOMCON; //0x7f008820
u32 rGPIOMDAT; //0x7f008824
u32 rGPIOMPUD; //0x7f008828
u32 reserved23;
u32 rGPIONCON; //0x7f008830
u32 rGPIONDAT; //0x7f008834
u32 rGPIONPUD; //0x7f008838
u32 reserved24;
u32 reserved25[16];
u32 rSPCONSLP; //0x7f008880
u32 reserved26[31];
u32 rEINT0CON0; //0x7f008900
u32 rEINT0CON1; //0x7f008904
u32 reserved27[2];
u32 rEINT0FLTCON0; //0x7f008910
u32 rEINT0FLTCON1; //0x7f008914
u32 rEINT0FLTCON2; //0x7f008918
u32 rEINT0FLTCON3; //0x7f00891c
u32 rEINT0MASK; //0x7f008920
u32 rEINT0PEND; //0x7f008924
u32 reserved28[2];
u32 rSLPEN; //0x7f008930
oGPIO_REGS;
typedef enum GPIO_Id
// Value & 0xF000 : The muxing bit number of the configuration register
// Value & 0x0F00 : Control register number per each GPIO Port
// Value & 0x00FF : Offset from GPIO base address(Value * 0x10)
eGPIO_A = 0x4100, // muxing bit : 4, control register : 1, offset : 0,
eGPIO_B = 0x4102, // muxing bit : 4, control register : 1, offset : 0x02*0x10
eGPIO_C = 0x4104, // muxing bit : 4, control register : 1, offset : 0x04*0x10
eGPIO_D = 0x4106, // muxing bit : 4, control register : 1, offset : 0x06*0x10
eGPIO_E = 0x4108, // muxing bit : 4, control register : 1, offset : 0x08*0x10
eGPIO_F = 0x210A, // muxing bit : 2, control register : 1, offset : 0x0A*0x10
eGPIO_G = 0x410C, // muxing bit : 4, control register : 1, offset : 0x0C*0x10
eGPIO_H = 0x420E, // muxing bit : 4, control register : 2, offset : 0x0E*0x10
eGPIO_I = 0x2110, // muxing bit : 2, control register : 1, offset : 0x10*0x10
eGPIO_J = 0x2112, // muxing bit : 2, control register : 1, offset : 0x12*0x10
eGPIO_K = 0x4280, // muxing bit : 4, control register : 2, offset : 0x80*0x10
eGPIO_L = 0x4281, // muxing bit : 4, control register : 2, offset : 0x81*0x10
eGPIO_M = 0x4182, // muxing bit : 4, control register : 1, offset : 0x82*0x10
eGPIO_N = 0x2183, // muxing bit : 2, control register : 1, offset : 0x83*0x10
eGPIO_O = 0x2114, // muxing bit : 2, control register : 1, offset : 0x14*0x10
eGPIO_P = 0x2116, // muxing bit : 2, control register : 1, offset : 0x16*0x10
eGPIO_Q = 0x2118 // muxing bit : 2, control register : 1, offset : 0x18*0x10
GPIO_eId;
typedef enum GPIO_BitPos
eGPIO_0 = (u32)(0),
eGPIO_1 = (u32)(1),
eGPIO_2 = (u32)(2),
eGPIO_3 = (u32)(3),
eGPIO_4 = (u32)(4),
eGPIO_5 = (u32)(5),
eGPIO_6 = (u32)(6),
eGPIO_7 = (u32)(7),
eGPIO_8 = (u32)(8),
eGPIO_9 = (u32)(9),
eGPIO_10 = (u32)(10),
eGPIO_11 = (u32)(11),
eGPIO_12 = (u32)(12),
eGPIO_13 = (u32)(13),
eGPIO_14 = (u32)(14),
eGPIO_15 = (u32)(15)
}GPIO_eBitPos;
typedef enum INT_TYPE
Low = (u32) 0x0,
High = (u32) 0x1,
Falling = (u32) 0x2,
Rising = (u32) 0x4,
Both = (u32) 0x6
}INT_eTYPE;
typedef enum FLT_TYPE
eDisFLT = (u32) 0x0,
eEnFLT = (u32) 0x1, // EINT Group 1~9
eDLYFLT = (u32) 0x2, // 2'b10 => Filter Enable, Delay Filter
eDIGFLT = (u32) 0x3
}FLT_eTYPE;
typedef enum LCD_TYPE
eHOSTIF = 0,
eRGBIF = 1,
eYCbCr = 2,
eHidden = 3
}LCD_eTYPE;
void GPIO_Init(void);
void GPIO_SetFunctionEach(GPIO_eId Id, GPIO_eBitPos eBitPos, u32 uFunction);
void GPIO_SetFunctionAll(GPIO_eId Id, u32 uValue0, u32 uValue1);
void GPIO_SetDataEach(GPIO_eId Id, GPIO_eBitPos eBitPos, u32 uValue);
void GPIO_SetDataAll(GPIO_eId Id, u32 uValue);
u32 GPIO_GetDataAll(GPIO_eId Id);
void GPIO_SetPullUpDownEach(GPIO_eId Id, GPIO_eBitPos eBitPos, u32 uValue);
void GPIO_SetPullUpDownAll(GPIO_eId Id, u32 uValue);
void GPIO_SetConRegSleepAll(GPIO_eId Id, u32 uValue);
void GPIO_SetPullUDSleepAll(GPIO_eId Id, u32 uValue);
void GPIO_SetLCDType(LCD_eTYPE eLCDType);
// EINT Group0 => Wakeup Source
void GPIO_SetEint0(u32 uEINT_No , u32 eIntType, FLT_eTYPE eFltType, u32 uFltWidth);
void GPIO_EINT0ClrPend(u32 uEINT_No );
void GPIO_EINT0DisMask(u32 uEINT_No );
void GPIO_EIN
