Norflash型号为sst39vf32
#ifndef __NORFLASH_H_
#define __NORFLASH_H_
#include "common.h"
#include "delay.h"
#include "debugserial.h"
#define NOR_FLASH_BASE 0x80000000
#define NOR_FLASH_SIZE 0x00100000
#define GET_ADDR(addr) (volatile uint16_t *)(NOR_FLASH_BASE | (addr<<1))
#define SECTOR_SIZE 0x800 /* Must be 2048 words for 39VF160 */
#define BLOCK_SIZE 0x8000 /* Must be 32K words for 39VF160 */
#define SST_ID 0xBF /* SST Manufacturer's ID code */
#define SST_39VF160 0x235D /* SST 39VF160 device code */
#define PROGRAM_TIMEOUT 0x00008000
//norflash 初始化必须在sram初始化之前
void norflash_init(void);
void norflash_erase(void);
u32 norflash_check_id(void);
u32 norflash_write_word(u32 add, u16 data);
u32 norflash_toggle_bit_check(u32 addr,u16 data);
#endif
#include "norflash.h"
static void norflash_io_init(void)
//a0-a22
/* init EMC_A1 */
LPC_IOCON->P4_1 = 0x21;
/* init EMC_A2 */
LPC_IOCON->P4_2 = 0x21;
/* init EMC_A3 */
LPC_IOCON->P4_3 = 0x21;
/* init EMC_A4 */
LPC_IOCON->P4_4 = 0x21;
/* init EMC_A5 */
LPC_IOCON->P4_5 = 0x21;
/* init EMC_A6 */
LPC_IOCON->P4_6 = 0x21;
/* init EMC_A7 */
LPC_IOCON->P4_7 = 0x21;
/* init EMC_A8 */
LPC_IOCON->P4_8 = 0x21;
/* init EMC_A9 */
LPC_IOCON->P4_9 = 0x21;
/* init EMC_A10 */
LPC_IOCON->P4_10 = 0x21;
/* init EMC_A11 */
LPC_IOCON->P4_11 = 0x21;
/* init EMC_A12 */
LPC_IOCON->P4_12 = 0x21;
/* init EMC_A13 */
LPC_IOCON->P4_13 = 0x21;
/* init EMC_A14 */
LPC_IOCON->P4_14 = 0x21;
/* init EMC_A15 */
LPC_IOCON->P4_15 = 0x21;
/* init EMC_A16 */
LPC_IOCON->P4_16 = 0x21;
/* init EMC_A17 */
LPC_IOCON->P4_17 = 0x21;
/* init EMC_A18 */
LPC_IOCON->P4_18 = 0x21;
/* init EMC_A19 */
LPC_IOCON->P4_19 = 0x21;
/* init EMC_A20 */
LPC_IOCON->P4_20 = 0x21;
/* init EMC_A21 */
LPC_IOCON->P4_21 = 0x21;
/* init EMC_A22 */
LPC_IOCON->P4_22 = 0x21;
//d0-d15
/* init EMC_D0 */
LPC_IOCON->P3_0 = 0x21;
/* init EMC_D1 */
LPC_IOCON->P3_1 = 0x21;
/* init EMC_D2 */
LPC_IOCON->P3_2 = 0x21;
/* init EMC_D3 */
LPC_IOCON->P3_3 = 0x21;
/* init EMC_D4 */
LPC_IOCON->P3_4 = 0x21;
/* init EMC_D5 */
LPC_IOCON->P3_5 = 0x21;
/* init EMC_D6 */
LPC_IOCON->P3_6 = 0x21;
/* init EMC_D7 */
LPC_IOCON->P3_7 = 0x21;
/* init EMC_D8 */
LPC_IOCON->P3_8 = 0x21;
/* init EMC_D9 */
LPC_IOCON->P3_9 = 0x21;
/* init EMC_D10 */
LPC_IOCON->P3_10 = 0x21;
/* init EMC_D11 */
LPC_IOCON->P3_11 = 0x21;
/* init EMC_D12 */
LPC_IOCON->P3_12 = 0x21;
/* init EMC_D13 */
LPC_IOCON->P3_13 = 0x21;
/* init EMC_D14 */
LPC_IOCON->P3_14 = 0x21;
/* init EMC_D15 */
LPC_IOCON->P3_15 = 0x21;
/* init EMC_WE */
LPC_IOCON->P4_25 = 0x21;
/* init EMC_oe */
LPC_IOCON->P4_24 = 0x21;
/* init EMC_cs0 */
LPC_IOCON->P4_30 = 0x21;
LPC_SC->SCS |= (1<<0);//emc地址不移位
//打开emc时钟与端口时钟
LPC_SC->PCONP |= (1<<15)|(1<<11);//打开时钟
LPC_SC->EMCDLYCTL = 0x00001010;//延时时间初始化
LPC_EMC->Control = 0x00000001;//emc使能
LPC_EMC->Config = 0x00000000;//emc配置清零,小端模式
norflash_io_init();
DelayMs(100);
LPC_EMC->StaticConfig0 &= ~(3<<0); //
LPC_EMC->StaticConfig0 |= (1<<0); //设置总线宽度16位
LPC_EMC->StaticConfig0 |= (1<<7); //设置读写有效电平,读为低电平
LPC_EMC->StaticWaitWen0 &= ~(7<<0);
LPC_EMC->StaticWaitWen0 |= (2<<0);//设置片选到写使能的延时时间
LPC_EMC->StaticWaitOen0 &= ~(7<<0);
LPC_EMC->StaticWaitOen0 |= (2<<0);//设置片选到输出使能的延时
LPC_EMC->StaticWaitWr0 &= ~(0x1f<<0);
LPC_EMC->StaticWaitWr0 |= (0x1f<<0);//设置片选到写入的延时
LPC_EMC->StaticWaitPage0 &= ~(0x1f<<0);
LPC_EMC->StaticWaitPage0 |= (0x1f<<0);//设置读模式顺序存取延时
LPC_EMC->StaticWaitRd0 &= ~(0x1f<<0);
LPC_EMC->StaticWaitRd0 |= (0x1f<<0);//设置片选到读取的延时
LPC_EMC->StaticWaitTurn0 &= ~(0x1f<<0);
LPC_EMC->StaticWaitTurn0 |= (0x1f<<0);//设置总线周转周期
DelayMs(100);
volatile uint16_t *ip;
ip = GET_ADDR(0x5555);
*ip = 0x00AA;
ip = GET_ADDR(0x2AAA);
*ip = 0x0055;
*ip = 0x0080;
*ip = 0x00AA;
*ip = 0x0055;
*ip = 0x0010;
DelayMs(10); /* Use timer 1 */
return;
//检查nand id
uint16_t SST_id1, SST_id2;
/* Issue the Software Product ID code to 39VF160 */
*ip = 0x00AA;
*ip = 0x0055;
*ip = 0x0090;
DelayMs(10);
/* Read the product ID from 39VF160 */
ip = GET_ADDR(0x0000);
SST_id1 = *ip & 0x00FF;
ip = GET_ADDR(0x0001);
SST_id2 = *ip;
/* Issue the Soffware Product ID Exit code thus returning the 39VF160 */
/* to the read operating mode */
*ip = 0x00AA;
*ip = 0x0055;
*ip = 0x00F0;
DelayMs(10);
/* Check ID */
if ((SST_id1 == SST_ID) && (SST_id2 ==SST_39VF160))
return( 0 );
else
printf("SST_id1 = %x \r\n",SST_id1);
printf("SST_id2 = %x \r\n",SST_id2);
return( 1 );
//写入数据,只能16位写入
*ip = 0x00AA;
ip = GET_ADDR(0x2aaa);
*ip = 0x0055;
*ip = 0x00A0;
ip = GET_ADDR(add); /* Program 16-bit word */
*ip = data;
return ( norflash_toggle_bit_check( add, data ) );
//数据写入检查
volatile u16 *ip;
u16 temp1, temp2;
u32 TimeOut = PROGRAM_TIMEOUT;
while( TimeOut > 0 )
ip = GET_ADDR(addr);
temp1 = *ip;
temp2 = *ip;
if ( (temp1 == temp2) && (temp1 == data) )
return( 0 );
TimeOut--;
printf("temp1 = %x \r\n",temp1);
printf("temp2 = %x \r\n",temp2);
return ( 1 );
