一、前期准备
单片机:STM32F103ZET6
开发环境:MDK5.14
库函数:标准库V3.5
0.96 OLED模块:淘宝有售
二、实验效果
三、驱动原理
此OLED模块采用SPI通信,也可转成IIC通信,不过要焊接背面的电阻,不建议改IIC,要改请参考具体数据手册。驱动芯片SSD1306,具体命令字详解请见网友SSD1306详解。
需要完整工程或者有问题的请加QQ:1002521871,验证:呵呵。
软件模拟SPI驱动
四、驱动代码
oled.h
#ifndef __OLED_H__
#define __OLED_H__
#include "stm32f10x.h"
#include "stdlib.h"
#include "oledfont.h"
#include "delay.h"
#include "bmp.h"
#include "gpio.h"
#define OLED 0
#define SIZE 16
#define XLevelL 0x00
#define XLevelH 0x10
#define Max_Column 128
#define Max_Row 64
#define Brightness 0xff
#define X_WIDTH 128
#define Y_WIDTH 64
//IO Definitions
#define RST PBout(10) //RES
#define DC PBout(11) //DC
#define SPI2_NSS_PIN GPIO_Pin_12 //CS
#define SPI2_SCLK_PIN GPIO_Pin_13 //D0
#define SPI2_MISO_PIN GPIO_Pin_14
#define SPI2_MOSI_PIN GPIO_Pin_15 //D1
#define SPI2_NSS PBout(12)
typedef enum
OLED_CMD,
OLED_DATA
}OLED_WR_MODE;
typedef enum
Display_ON,
Display_OFF,
Display_Clear,
Display_Test
}DIS_MODE;
//OLED控制用函数
extern void OLED_WR_Byte(uint8_t dat,OLED_WR_MODE cmd);
extern void OLED_Display_Status(DIS_MODE mode);
extern void OLEDConfiguration(void);
extern void OLED_DrawPoint(uint8_t x, uint8_t y, uint8_t t);
extern void OLED_Fill(uint8_t x1, uint8_t y1, uint8_t x2, uint8_t y2, uint8_t dot);
extern void OLED_ShowChar(uint8_t x, uint8_t y, uint8_t chr);
extern void OLED_ShowNum(uint8_t x, uint8_t y, u32 num, uint8_t len, uint8_t size);
extern void OLED_ShowString(uint8_t x,uint8_t y, uint8_t *p);
extern void OLED_Set_Pos(uint8_t x, uint8_t y);
extern void OLED_ShowCHinese(uint8_t x, uint8_t y, uint8_t no);
extern void OLED_DrawBMP(uint8_t x0, uint8_t y0,uint8_t x1, uint8_t y1, uint8_t BMP[]);
#endif
oled.c
#include "oled.h"
//OLED的显存
//存放格式如下.
//[0]0 1 2 3 ... 127
//[1]0 1 2 3 ... 127
//[2]0 1 2 3 ... 127
//[3]0 1 2 3 ... 127
//[4]0 1 2 3 ... 127
//[5]0 1 2 3 ... 127
//[6]0 1 2 3 ... 127
//[7]0 1 2 3 ... 127
uint8_t SPI2_SendByte(uint8_t byte)
while (SPI_I2S_GetFlagStatus(SPI2, SPI_I2S_FLAG_TXE) == RESET); // 等待发送区空
SPI_I2S_SendData(SPI2, byte); // 发送一个字节
while (SPI_I2S_GetFlagStatus(SPI2, SPI_I2S_FLAG_RXNE) == RESET); // 等待接收完一个字节
return SPI_I2S_ReceiveData(SPI2); // 返回收到的数据
//向SSD1106写入一个字节。
//dat:要写入的数据/命令
//cmd:数据/命令标志 0,表示命令;1,表示数据;
//uint8_t i;
switch(cmd)
case OLED_CMD:
DC = 0;
break;
case OLED_DATA:
DC = 1;
break;
SPI2_NSS = 0;
// for(i = 0; i < 8; i ++)
// OLED_SCLK_Clr();
// if(dat & 0x80)
// OLED_SDIN_Set();
// else
// OLED_SDIN_Clr();
// OLED_SCLK_Set();
// dat<<=1;
SPI2_SendByte(dat);
SPI2_NSS = 1;
DC = 1;
//#endif
OLED_WR_Byte(0xB0 + y, OLED_CMD);
OLED_WR_Byte(((x & 0xF0) >> 4) | 0x10, OLED_CMD);
OLED_WR_Byte((x & 0x0F) | 0x01, OLED_CMD);
uint8_t i,n;
switch(mode)
case Display_ON://开启OLED显示
OLED_WR_Byte(0X8D, OLED_CMD); //SET DCDC命令
OLED_WR_Byte(0X14, OLED_CMD); //DCDC ON
OLED_WR_Byte(0XAF, OLED_CMD); //DISPLAY ON
break;
case Display_OFF://关闭OLED显示
OLED_WR_Byte(0X10, OLED_CMD); //DCDC OFF
OLED_WR_Byte(0XAE, OLED_CMD); //DISPLAY OFF
break;
case Display_Clear://清屏函数,清完屏,整个屏幕是黑色的!和没点亮一样!!!
OLED_WR_Byte(0xB0 + i, OLED_CMD); //设置页地址(0~7)
OLED_WR_Byte(0x00, OLED_CMD); //设置显示位置—列低地址
OLED_WR_Byte(0x10, OLED_CMD); //设置显示位置—列高地址
for(n = 0; n < Max_Column; n ++)
OLED_WR_Byte(0, OLED_DATA);
} //更新显示
break;
case Display_Test:
OLED_WR_Byte(0xb0 + i, OLED_CMD); //设置页地址(0~7)
OLED_WR_Byte(1, OLED_DATA);
DelayMs(5);
} //更新显示
break;
//在指定位置显示一个字符,包括部分字符
//x:0~127
//y:0~63
//mode:0,反白显示;1,正常显示
//size:选择字体 16/12
uint8_t c = 0, i = 0;
c = chr - ' ';//得到偏移后的值
if(x > Max_Column - 1)
x = 0;
y += 2;
if(SIZE == 16)
OLED_Set_Pos(x, y);
OLED_WR_Byte(F8X16[c * 16 + i], OLED_DATA);
OLED_Set_Pos(x, y + 1);
OLED_WR_Byte(F8X16[c * 16 + i + 8], OLED_DATA);
else
for(i = 0; i < 6; i ++)
OLED_WR_Byte(F6x8[c][i],OLED_DATA);
void OLED_ShowChar1(uint8_t x, uint8_t y, uint8_t chr)
x = 0;
y += 2;
if(SIZE == 16)
OLED_Set_Pos(x, y);
OLED_WR_Byte(F6x8[c][i], OLED_DATA);
OLED_WR_Byte(F6x8[c][i + 6], OLED_DATA);
else
//m^n函数
u32 oled_pow(uint8_t m,uint8_t n)
u32 result = 1;
while(n --)
result *= m;
return result;
//显示2个数字
//x,y :起点坐标
//len :数字的位数
//size:字体大小
//mode:模式 0,填充模式;1,叠加模式
//num:数值(0~4294967295);
uint8_t t,temp;
uint8_t enshow = 0;
for(t = 0; t < len; t ++)
temp = (num / oled_pow(10, len - t - 1)) % 10;
if(enshow == 0 && t < (len - 1))
if(temp == 0)
OLED_ShowChar(x + (size / 2) * t, y, ' ');
continue;
}else enshow = 1;
OLED_ShowChar(x + (size / 2) * t, y, temp + '0');
//显示一个字符号串
void OLED_ShowString(uint8_t x, uint8_t y, uint8_t *chr)
uint8_t j = 0;
while (chr[j] != '')
OLED_ShowChar(x, y, chr[j]);
x += 8;
if(x > 120)
x = 0;
y += 2;
j++;
//显示汉字
uint8_t t, adder = 0;
OLED_Set_Pos(x, y);
for(t = 0; t < 16; t ++)
OLED_WR_Byte(Hzk[2 * no][t], OLED_DATA);
adder += 1;
OLED_WR_Byte(Hzk[2 * no + 1][t], OLED_DATA);
adder += 1;
/***********功能描述:显示显示BMP图片128×64起始点坐标(x,y),x的范围0~127,y为页的范围0~7*****************/
uint8_t j = 0;
uint8_t x, y;
if(y1 % 8 == 0)
y = y1 / 8;
else
y = y1 / 8 + 1;
for(y = y0; y < y1; y ++)
OLED_Set_Pos(x0, y);
for(x = x0; x < x1; x ++)
OLED_WR_Byte(BMP[j ++], OLED_DATA);
//初始化SSD1306
SPI_InitTypeDef MySPI;
GPIO_InitTypeDef MyGPIO;
RCC_APB1PeriphClockCmd(RCC_APB1Periph_SPI2, ENABLE);
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB |RCC_APB2Periph_AFIO , ENABLE);
// GPIO配置,设置为PB输出
MyGPIO.GPIO_Pin = SPI2_NSS_PIN;
MyGPIO.GPIO_Speed = GPIO_Speed_50MHz;
MyGPIO.GPIO_Mode = GPIO_Mode_Out_PP;
GPIO_Init(GPIOB, &MyGPIO);
SPI2_NSS = 1;
MyGPIO.GPIO_Pin = SPI2_SCLK_PIN | SPI2_MISO_PIN | SPI2_MOSI_PIN;
MyGPIO.GPIO_Mode = GPIO_Mode_AF_PP;
// SPI配置
MySPI.SPI_Direction = SPI_Direction_2Lines_FullDuplex;
MySPI.SPI_Mode = SPI_Mode_Master;
MySPI.SPI_DataSize = SPI_DataSize_8b;
MySPI.SPI_CPOL = SPI_CPOL_Low;
MySPI.SPI_CPHA = SPI_CPHA_1Edge;
MySPI.SPI_NSS = SPI_NSS_Soft;
MySPI.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_4;
MySPI.SPI_FirstBit = SPI_FirstBit_MSB;
MySPI.SPI_CRCPolynomial = 7;
SPI_Init(SPI2, &MySPI);
SPI_Cmd(SPI2, ENABLE);
MyGPIO.GPIO_Pin = GPIO_Pin_10 | GPIO_Pin_11;
GPIO_Init(GPIOB, &MyGPIO); /
DC = 1;
RST = 1;
DelayMs(100);
RST = 0;
DelayMs(100);
RST = 1;
OLED_WR_Byte(0xAE, OLED_CMD);//--turn off oled panel
OLED_WR_Byte(0x00, OLED_CMD);//---set low column address
OLED_WR_Byte(0x10, OLED_CMD);//---set high column address
OLED_WR_Byte(0x40, OLED_CMD);//--set start line address Set Mapping RAM Display Start Line (0x00~0x3F)
OLED_WR_Byte(0x81, OLE
