环境:
主机:WIN8
开发环境:MDK5.13
emwin版本:STemWinLibrary522
mcu: stm32f407VGT6
开发板:安富莱STM32-X3
TFT型号:艾蓝2.8寸TFT,主控芯片:ILI9325
说明:
在STM32F407上移植emwin,驱动屏幕接口为FSMC
移植步骤:
1.MDK新建文件结构:
2.GUIConf.c文件修改
a)增加宏定义:
#define GUI_NUMBYTES (1024 * 80)
#define GUI_BLOCKSIZE 0x80
b)GUI_X_Config(void)函数中增加语句:
GUI_ALLOC_SetAvBlockSize(GUI_BLOCKSIZE);
修改后:
* GUI_X_Config
* Purpose:
* Called during the initialization process in order to set up the
* available memory for the GUI.
void GUI_X_Config(void) {
// 32 bit aligned memory area
static U32 aMemory[GUI_NUMBYTES / 4];
// Assign memory to emWin
GUI_ALLOC_AssignMemory(aMemory, GUI_NUMBYTES);
// Set default font
GUI_SetDefaultFont(GUI_FONT_6X8);
3.LCDConf_FlexColor_Template.c文件修改
a)增加宏定义:
#define LCD_REG_ADDRESS BANK1_LCD_REG
#define LCD_DATA_ADDRESS BANK1_LCD_RAM
这两个BANK宏定义在tft驱动文件中定义:
#define BANK1_BASE ((uint32_t)(0x60000000 | 0x00000000))
#define BANK1_LCD_RAM *(__IO uint16_t *)(BANK1_BASE + (1 <
#define BANK1_LCD_REG *(__IO uint16_t *)(BANK1_BASE)
具体值和接线相关
b)具体函数修改
* Local functions
* LcdWriteReg
* Function description:
* Sets display register
static void LcdWriteReg(U16 Data) {
// ... TBD by user
LCD_REG_ADDRESS = Data;
* LcdWriteData
* Writes a value to a display register
static void LcdWriteData(U16 Data) {
// ... TBD by user
LCD_DATA_ADDRESS=Data;
* LcdWriteDataMultiple
* Writes multiple values to a display register.
static void LcdWriteDataMultiple(U16 * pData, int NumItems) {
while (NumItems--) {
// ... TBD by user
LCD_DATA_ADDRESS=*pData++;
* LcdReadDataMultiple
* Reads multiple values from a display register.
static void LcdReadDataMultiple(U16 * pData, int NumItems) {
// ... TBD by user
*pData++=LCD_DATA_ADDRESS;
* Public functions
* LCD_X_Config
* display driver configuration.
void LCD_X_Config(void) {
GUI_DEVICE * pDevice;
CONFIG_FLEXCOLOR Config = {0};
GUI_PORT_API PortAPI = {0};
// Set display driver and color conversion
pDevice = GUI_DEVICE_CreateAndLink(GUIDRV_FLEXCOLOR, GUICC_565, 0, 0);
// Display driver configuration, required for Lin-driver
LCD_SetSizeEx (0, XSIZE_PHYS , YSIZE_PHYS);
LCD_SetVSizeEx(0, VXSIZE_PHYS, VYSIZE_PHYS);
// Orientation
//Config.Orientation = GUI_SWAP_XY | GUI_MIRROR_Y;
Config.FirstCOM = 0;
Config.FirstSEG = 0;
//Config.Orientation = GUI_MIRROR_X | GUI_MIRROR_Y;
Config.NumDummyReads = 2;
GUIDRV_FlexColor_Config(pDevice, &Config);
// Set controller and operation mode
PortAPI.pfWrite16_A0 = LcdWriteReg;
PortAPI.pfWrite16_A1 = LcdWriteData;
PortAPI.pfWriteM16_A1 = LcdWriteDataMultiple;
PortAPI.pfReadM16_A1 = LcdReadDataMultiple;
GUIDRV_FlexColor_SetFunc(pDevice, &PortAPI, GUIDRV_FLEXCOLOR_F66708, GUIDRV_FLEXCOLOR_M16C0B16);
//GUIDRV_FlexColor_SetFunc(pDevice, &PortAPI, GUIDRV_FLEXCOLOR_F66709, GUIDRV_FLEXCOLOR_M16C0B16);
其中:GUIDRV_FlexColor_SetFunc函数说明:
因为主控芯片为ILI9325,所以参数选择GUIDRV_FLEXCOLOR_F66708
4.GUI_X.c文件修改
此文件控制的是GUI中的延时,可以用定时器配合实现,修改如下:
* Global data
volatile GUI_TIMER_TIME OS_TimeMS;
* Timing:
* GUI_X_GetTime()
* GUI_X_Delay(int)
Some timing dependent routines require a GetTime
and delay function. Default time unit (tick), normally is
1 ms.
extern __IO int32_t g_iRunTime;
GUI_TIMER_TIME GUI_X_GetTime(void) {
//return OS_TimeMS;
return g_iRunTime;
void GUI_X_Delay(int ms) {
// int tEnd = OS_TimeMS + ms;
// while ((tEnd - OS_TimeMS) > 0);
int tEnd = g_iRunTime + ms;
while ((tEnd - g_iRunTime) > 0);
5.主函数实现:
int main(void)
ST固件库中的启动文件已经执行了 SystemInit() 函数,该函数在 system_stm32f4xx.c 文件,主要功能是
配置CPU系统的时钟,内部Flash访问时序,配置FSMC用于外部SRAM
bsp_Init(); /* 硬件初始化 */
PrintfLogo(); /* 打印例程信息到串口1 */
vLCDInit();
// vClearScreen(Green);
// vSetTextColor(Red);
// vPutString(20,0, "NanJing RF Tracking!!!!!");
// ShowImage();
//DemoFatFS(); /* SD卡文件系统演示程序 */
//RCC_AHBPeriphClockCmd(RCC_AHBPeriph_CRC, ENABLE);
RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_CRC, ENABLE);
GUI_Init();
GUI_DispString("I am jdh!");
while (1)
GUI_Delay(1000);
注意:
函数是必须的,否则GUI将不工作,这是ST公司防止其他芯片用此GUI的措施。
参考资料:
1.STemWin5.22移植笔记
2.《野火emwin实战指南V1.0.0》
3.安富莱源程序:x3开发板_裸机STemWin5.20
