前提:系统已经实现DNS(即使用ping 通)。
1. 在内核中添加以下选项:
Networking --->
- Networking support
Networking options --->
Packet socket //添加.配置CONFIG_PACKET
[ * ] IP: DHCP support //添加
[ * ] Network packet filtering (replaces ipchains) ---> //添加,后面子选项可不选,配置CONFIG_NETFILTER
说明:若没选 Packet socket, [ * ] Network packet filtering (replaces ipchains) --->选项,在执行udhcpc命令时出现如下错误:
~ # udhcpc
udhcpc (v0.9.9-pre) started
udhcpc[208]: udhcpc (v0.9.9-pre) started
FATAL: couldn't listen on socket, Address family not supported by protocol
udhcpc[208]: FATAL: couldn't listen on socket, Address family not supported by protocol
2. Busybox中添加以下选项:
Networking Utilities --->
udhcp Server/Client --->
[] udhcp Server (udhcpd) //在此不作服务端,故不选。生成udhcpd命令
- udhcp Client (udhcpc) //生成udhcpc命令
[ ] Lease display utility (dumpleases)
[ ] Log udhcp messages to syslog (instead of stdout)
[ ] Compile udhcp with noisy debugging messages
若busybox没编译相应选项,也可从网上下载相应文件,用arm-linux交叉编译得到udhcpd,udhcpc命令copy到usr/sbin下就可以了。
我从 网上 下的udhcp_0.9.8cvs20050303.orig.tar.gz文件
解压后修改Makefile文件
在19行添加CROSS_COMPILE=arm-linux-
注释12行的COMBINED_BINARY=1,否则不生成udhcpc命令。
3. 建相关配置文件
从busybox的examples/udhcp/下copy simple.script文件到开发板/usr/share/udhcpc/下,并重命名为default.script,udhcp_0.9.8cvs20050303.orig.tar.gz中也有这样的文件。
[root@localhost root]# vi usr/share/udhcpc/default.script
#!/bin/sh
# udhcpc script edited by Tim Riker
[ -z "$1" ] && echo "Error: should be called from udhcpc" && exit 1
RESOLV_CONF="/etc/resolv.conf"
[ -n "$broadcast" ] && BROADCAST="broadcast $broadcast"
[ -n "$subnet" ] && NETMASK="netmask $subnet"
case "$1" in
deconfig)
/sbin/ifconfig $interface 0.0.0.0
renew|bound)
/sbin/ifconfig $interface $ip $BROADCAST $NETMASK
if [ -n "$router" ] ; then
echo "deleting routers"
while route del default gw 0.0.0.0 dev $interface ; do
done
for i in $router ; do
route add default gw $i dev $interface
done
fi
echo -n > $RESOLV_CONF
[ -n "$domain" ] && echo search $domain >> $RESOLV_CONF
for i in $dns ; do
echo adding dns $i
echo nameserver $i >> $RESOLV_CONF
done
esac
exit 0
4. 重启开发板,执行udhcpc就可自动获取IP地址了,以下是执行udhcpc的输出信息:
~ # udhcpc
udhcpc[228]: udhcpc (v0.9.9-pre) started
Sending discover...
udhcpc[228]: Sending discover...
Sending select for 192.168.1.109...
udhcpc[228]: Sending select for 192.168.1.109...
Lease of 192.168.1.109 obtained, lease time 86400
udhcpc[228]: Lease of 192.168.1.109 obtained, lease time 86400
deleting routers
route: SIOC[ADD|DEL]RT: No such process
adding dns 192.168.0.1
~ # ping www.baidu.com
PING www.a.shifen.com (220.181.38.4): 56 data bytes
64 bytes from 220.181.38.4: icmp_seq=0 ttl=52 time=1219.0 ms
[1] + Stopped ping www.baidu.com
5. 如果是双网卡必须用参数指明
例:udhcpc -i eth1
今天在我的2410上搞定摄像头。交叉编译gspca驱动,配置linux2.6.20.3使其支持V4L,不用选择linux2.6自带的ZC0301驱动。发现可以搞定,但是2410性能交叉,640*480的VGA输出,摄像头分辨率大小不能设太大,否则很慢。我设定为176*144.
今天顺便上busybox.net看了看,发现稳定版已经到1.5.1,于是重新把我现在用的1.4.2换成1.5.1。
发现原来ls -l /dev出现segment fault的BUG消除了!
顺便加上了dhcp client的支持。看了写资料,方法:
在KERNEL中需要将 Packet socket和IP: DHCP support编译进内核或编译成模块。在编译Busybox时把 Networking Utilities下udhcp Server/Client中的 udhcp Client (udhcpc)选上。
关键点要把examples/udhcp/simple.script 脚本文件做为default.script拷贝到/usr/share/udhcpc/default.script
运行udhcpc
~ # udhcpc
udhcpc (v1.5.1) started
Sending discover...
Sending select for 59.64.134.99...
Lease of 59.64.134.99 obtained, lease time 10800
deleting routers
adding dns 211.68.71.4
adding dns 211.68.71.5
adding dns 202.106.196.115
adding dns 202.106.0.20
然后可以使用tftp命令下载和上传文件,主机的ip为192.168.1.105,下载自己tftp服务器下的led.ko文件,先在主机上建立tftp服务器,在开发板上输入下面的命令,可以将led.ko文件下载到当前目录下。
#tftp -g -r led.ko 192.168.1.105
tftp使用说明如下:
Usage: tftp [OPTION]... HOST [PORT]
Transfers a file from/to a tftp server using "octet" mode.
Options:
-l FILE Local FILE
-r FILE Remote FILE
-g Get file
-p Put file
-b SIZE Transfer blocks of SIZE octets
关键字:2410开发板 DHCP 自动获取 IP地址
