#include
typedef unsigned char uchar;
typedef unsigned int uint;
typedef unsigned long ulong;
sbit ADDR0 = P1^0;
sbit ADDR1 = P1^1;
sbit ADDR2 = P1^2;
sbit ADDR3 = P1^3;
sbit ENLED = P1^4;
uchar image[8] = {
0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF
uchar T0RH, T0RL;
uint rate;
void LEDScan();
void resetImage();
void configTmr0(uint ms1, uchar ms2);
void main() {
EA = 1;
ADDR3 = 0;
ENLED = 0;
configTmr0(50, 2);
while (1) ;
void configTmr0(uint ms1, uchar ms2) {
ulong tmp;
rate = ms1 / ms2;
tmp = 11059200 / 12; //定时器计数频率
tmp = (tmp * ms2) / 1000; //计算所需的计数值
tmp = 65536 - tmp; //计算定时器重载值
tmp = tmp + 12; //补偿中断响应延时造成的误差
T0RH = tmp >> 8; //定时器重载值拆分为高低字节
T0RL = tmp;
TMOD &= 0xF0;
TMOD |= 0x01;
TH0 = T0RH;
TL0 = T0RL;
ET0 = 1;
TR0 = 1;
#define LEDScan(); { \
static uchar i = 0; \
P0 = 0xFF; \
P1 = (P1 & 0xF8) | i; \
P0 = image[i]; \
i = ++i & 0x07; \
void resetImage() {
static uchar x = 0, y = 0;
image[y] ^= (0x80 >> x);
if (x == 3 && y == 4) {
x = 0;
y = 0;
else if (y <= x + 1 && x + y
x++;
else if (x + y >= 7 && y
y++;
else if (y >= x && x + y > 7) {
x--;
else
y--;
void interruptTmr0() interrupt 1 {
static uint i = 0;
TH0 = T0RH;
TL0 = T0RL;
LEDScan();
if (i == rate) {
resetImage();
i = 0;
else
i++;
双向流水:
#include
sbit ADDR0 = P1^0;
sbit ADDR1 = P1^1;
sbit ADDR2 = P1^2;
sbit ADDR3 = P1^3;
sbit ENLED = P1^4;
uchar image[8] = {
uchar T0RH, T0RL;
uint rate;
void LEDScan();
void resetImage();
void main() {
EA = 1;
ADDR3 = 0;
ENLED = 0;
configTmr0(50, 2);
while (1) ;
ulong tmp;
rate = ms1 / ms2;
T0RL = tmp;
TMOD &= 0xF0;
TMOD |= 0x01;
TH0 = T0RH;
TL0 = T0RL;
ET0 = 1;
TR0 = 1;
P0 = 0xFF; \
P0 = image[i]; \
i = ++i & 0x07; \
void resetImage() {
image[7-y] ^= (0x01 <
x = 0;
y = 0;
else if (y <= x+1 && x + y
x++;
y++;
else if (y >= x-1 && x + y > 7)
x--;
else
y--;
static uint i = 0;
TH0 = T0RH;
TL0 = T0RL;
LEDScan();
if (i == rate) {
resetImage();
i = 0;
else
i++;
