单片机源程序如下:
#include
#include
#define DATA P1 //1602驱动端口
//ROM操作命令
#define READ_ROM 0x33 //读ROM
#define SKIP_ROM 0xCC //跳过ROM
#define MATCH_ROM 0x55 //匹配ROM
#define SEARCH_ROM 0xF0 //搜索ROM
#define ALARM_SEARCH 0xEC //告警搜索
//存储器操作命令
#define ANEW_MOVE 0xB8 //重新调出E^2数据
#define READ_POWER 0xB4 //读电源
#define TEMP_SWITCH 0x44 //启动温度变换
#define READ_MEMORY 0xBE //读暂存存储器
#define COPY_MEMORY 0x48 //复制暂存存储器
#define WRITE_MEMORY 0x4E //写暂存存储器
//数据存储结构
typedef struct tagTempData
unsigned char btThird; //百位数据
unsigned char btSecond; //十位数据
unsigned char btFirst; //个位数据
unsigned char btDecimal; //小数点后一位数据
unsigned char btNegative; //是否为负数
}TEMPDATA;
TEMPDATA m_TempData;
//引脚定义
sbit DQ = P2^7; //数据线端口
sbit RS= P2^0;
sbit RW= P2^1;
sbit E= P2^2;
//DS18B20序列号,通过调用GetROMSequence()函数在P1口读出(读8次)
const unsigned char code ROMData1[8] = {0x28, 0x33, 0xC5, 0xB8, 0x00, 0x00, 0x00, 0xD7}; //U1
const unsigned char code ROMData2[8] = {0x28, 0x30, 0xC5, 0xB8, 0x00, 0x00, 0x00, 0x8E}; //U2
const unsigned char code ROMData3[8] = {0x28, 0x31, 0xC5, 0xB8, 0x00, 0x00, 0x00, 0xB9}; //U3
const unsigned char code ROMData4[8] = {0x28, 0x32, 0xC5, 0xB8, 0x00, 0x00, 0x00, 0xE0}; //U4
const unsigned char code ROMData5[8] = {0x28, 0x34, 0xC5, 0xB8, 0x00, 0x00, 0x00, 0x52}; //U5
const unsigned char code ROMData6[8] = {0x28, 0x35, 0xC5, 0xB8, 0x00, 0x00, 0x00, 0x65}; //U6
const unsigned char code ROMData7[8] = {0x28, 0x36, 0xC5, 0xB8, 0x00, 0x00, 0x00, 0x3C}; //U7
const unsigned char code ROMData8[8] = {0x28, 0x37, 0xC5, 0xB8, 0x00, 0x00, 0x00, 0x0B}; //U8
//判断忙指令
void Busy()
DATA = 0xff;
RS = 0;
RW = 1;
while(DATA & 0x80)
E = 0;
E = 1;
E = 0;
//写指令程序
void WriteCommand(unsigned char btCommand)
Busy();
RS = 0;
RW = 0;
E = 1;
DATA = btCommand;
E = 0;
//写数据程序
void WriteData(unsigned char btData)
Busy();
RS = 1;
RW = 0;
E = 1;
DATA = btData;
E = 0;
//清屏显示
void Clear()
WriteCommand(1);
//初始化
void Init()
WriteCommand(0x0c); //开显示,无光标显示
WriteCommand(0x06); //文字不动,光标自动右移
WriteCommand(0x38); //设置显示模式:8位2行5x7点阵
//显示单个字符
void DisplayOne(bit bRow, unsigned char btColumn, unsigned char btData, bit bIsNumber)
if (bRow) WriteCommand(0xc0 + btColumn);
else WriteCommand(0x80 + btColumn);
if (bIsNumber) WriteData(btData + 0x30);
else WriteData(btData);
//显示字符串函数
void DisplayString(bit bRow, unsigned char btColumn, unsigned char *pData)
while (*pData != '')
if (bRow) WriteCommand(0xc0 + btColumn); //显示在第1行
else WriteCommand(0x80 + btColumn); //显示在第0行
WriteData(*(pData++)); //要显示的数据
btColumn++;
