采用svc模式可以将SDK(API)和Application分离, 也可以省略很多重复的代码,比如在bootload中用到了usb, 然后在application中想复用的话,可以用svc
原理: 类似软件中断,中添加了一个软件中断源,通过中断源表明调用的函数接口
源程序如下:
#ifndef NRF_SVC__
#define NRF_SVC__
#ifdef SVCALL_AS_NORMAL_FUNCTION
#define SVCALL(number, return_type, signature) return_type signature
#else
#ifndef SVCALL
#if defined (__CC_ARM)
#define SVCALL(number, return_type, signature) return_type __svc(number) signature
#elif defined (__GNUC__)
_Pragma("GCC diagnostic ignored "-Wunused-function"")
_Pragma("GCC diagnostic push")
_Pragma("GCC diagnostic ignored "-Wreturn-type"")
__attribute__((naked)) static return_type signature
__asm(
"svc %0n"
"bx r14" : : "I" (number) : "r0"
_Pragma("GCC diagnostic pop")
#elif defined (__ICCARM__)
#define PRAGMA(x) _Pragma(#x)
PRAGMA(swi_number = number)
__swi return_type signature;
#else
#endif
#endif // SVCALL
#endif // SVCALL_AS_NORMAL_FUNCTION
#endif // NRF_SVC__
void C_SVC_Handler(uint8_t svc_num, uint32_t * p_svc_args)
switch (svc_num)
case NRF_SEC_SVC_HASH:
p_svc_args[0] = nrf_sec_hash((nrf_sec_data_t *) p_svc_args[0],
(uint8_t *) p_svc_args[1],
(nrf_sec_hash_func_t) p_svc_args[2]);
break;
case NRF_SEC_SVC_VERIFY:
p_svc_args[0] = nrf_sec_verify((nrf_sec_data_t *) p_svc_args[0],
(nrf_sec_ecc_point_t *) p_svc_args[1],
(nrf_sec_ecc_signature_t *) p_svc_args[2],
(nrf_sec_algo_t) p_svc_args[3]);
break;
default:
p_svc_args[0] = NRF_ERROR_SVC_HANDLER_MISSING;
break;
#if defined ( __CC_ARM )
__asm void SVC_Handler(void)
EXC_RETURN_CMD_PSP EQU 0xFFFFFFFD ; EXC_RETURN using PSP for ARM Cortex. If Link register contains this value it indicates the PSP was used before the SVC, otherwise the MSP was used.
IMPORT C_SVC_Handler
LDR R0, =EXC_RETURN_CMD_PSP ; Load the EXC_RETURN into R0 to be able to compare against LR to determine stack pointer used.
CMP R0, LR ; Compare the link register with R0. If equal then PSP was used, otherwise MSP was used before SVC.
BNE UseMSP ; Branch to code fetching SVC arguments using MSP.
MRS R1, PSP ; Move PSP into R1.
B Call_C_SVC_Handler ; Branch to Call_C_SVC_Handler below.
UseMSP
MRS R1, MSP ; MSP was used, therefore Move MSP into R1.
Call_C_SVC_Handler
LDR R0, [R1, #24] ; The arguments for the SVC was stacked. R1 contains Stack Pointer, the values stacked before SVC are R0, R1, R2, R3, R12, LR, PC (Return address), xPSR.
; R1 contains current SP so the PC of the stacked frame is at SP + 6 words (24 bytes). We load the PC into R0.
SUBS R0, #2 ; The PC before the SVC is in R0. We subtract 2 to get the address prior to the instruction executed where the SVC number is located.
LDRB R0, [R0] ; SVC instruction low octet: Load the byte at the address before the PC to fetch the SVC number.
LDR R2, =C_SVC_Handler ; Load address of C implementation of SVC handler.
BX R2 ; Branch to C implementation of SVC handler. R0 is now the SVC number, R1 is the StackPointer where the arguments (R0-R3) of the original SVC are located.
ALIGN
#elif defined ( __GNUC__ )
void __attribute__ (( naked )) SVC_Handler(void)
const uint32_t exc_return = 0xFFFFFFFD; // EXC_RETURN using PSP for ARM Cortex. If Link register contains this value it indicates the PSP was used before the SVC, otherwise the MSP was used.
__asm volatile(
"cmp lr, %0tn" // Compare the link register with argument 0 (%0), which is exc_return. If equal then PSP was used, otherwise MSP was used before SVC.
"bne UseMSPtn" // Branch to code fetching SVC arguments using MSP.
"mrs r1, psptn" // Move PSP into R1.
"b Call_C_SVC_Handlertn" // Branch to Call_C_SVC_Handler below.
"UseMSP: tn" //
"mrs r1, msptn" // MSP was used, therefore Move MSP into R1.
"Call_C_SVC_Handler: tn" //
"ldr r0, [r1, #24]tn" // The arguments for the SVC was stacked. R1 contains Stack Pointer, the values stacked before SVC are R0, R1, R2, R3, R12, LR, PC (Return address), xPSR.
// R1 contains current SP so the PC of the stacked frame is at SP + 6 words (24 bytes). We load the PC into R0.
"sub r0, r0, #2tn" // The PC before the SVC is in R0. We subtract 2 to get the address prior to the instruction executed where the SVC number is located.
"ldrb r0, [r0]tn" // SVC instruction low octet: Load the byte at the address before the PC to fetch the SVC number.
"bx %1tn" // Branch to C implementation of SVC handler, argument 1 (%1). R0 is now the SVC number, R1 is the StackPointer where the arguments (R0-R3) of the original SVC are located.
".aligntn"
:: "r" (exc_return), "r" (C_SVC_Handler) // Argument list for the gcc assembly. exc_return is %0, C_SVC_Handler is %1.
: "r0", "r1" // List of register maintained manually.
#else
#error Compiler not supported.
#endif
__asm void SVCHandler(void)
IMPORT SVCHandler_main
TST lr, #4
ITE EQ
MRSEQ R0, MSP
MRSNE R0, PSP
B SVCHandler_main
void SVCHandler_main(unsigned int * svc_args)
unsigned int svc_number;
* Stack contains:
* R0, R1, R2, R3, R12, R14, the return address and xPSR
* First argument (R0) is svc_args[0]
svc_number = ((char *)svc_args[6])[-2];
switch(svc_number)
case SVC_00:
