力天电子lpc2148开发板中配的12864小屏是不带字库的,并且没有所谓的左右屏,上下屏之分,是一个整屏.(是北京集粹电子设备有限公司生产的,资料详见
http://download.csdn.net/detail/yueniaoshi/4507741 此资料介绍的芯片的相关东西
http://download.csdn.net/detail/yueniaoshi/4507754 此资料介绍的是驱动函数
http://download.csdn.net/detail/yueniaoshi/4507775 此资料介绍的是小小日历钟,这个里面的函数更全一点)
(再说点题外话,当初买板子的时候老板服务很周到,也很热心,问什么说什么!可是一旦板子买回来了,有些地方不懂的时候,想问问老板,就变得爱理不理了啊,美哦办法啊!谁让咱是菜鸟呢?没人说,咱就自己想办法解决吧!)
#include
//管脚宏定义
#define SCLK 0x01<<24 //595时钟端
#define MISO 0x01<<5 //数据输入端
#define MOSI 0x01<<6 //数据输出端
#define RCK 0x01<<7 //SO12864时钟输入端
//LCD Define
#define LCD_A 1<<30 //命令数据选择端,高电平:数据 低电平:命令
#define LCD_CLK 1<<4 //时钟端
#define LCD_DATA MOSI //数据端
#define B_LED 1<<13 //背光
#define Sclk_L() IO0CLR |=LCD_CLK //时钟高电平
#define Sclk_H() IO0SET |=LCD_CLK //时钟低电平
#define Res_L() HC595_DATA &=~(1<<2);Write595() //复位低电平
#define Res_H() HC595_DATA |=(1<<2); Write595() //复位高电平
#define Data_L() IO0CLR |=LCD_DATA //数据低电平
#define Data_H() IO0SET |=LCD_DATA //数据高电平
#define CS_L() HC595_DATA &=~1; Write595() //片选低电平
#define CS_H() HC595_DATA |=1; Write595() //片选高电平
#define Write_C() IO0CLR |=LCD_A //选择写命令
#define Write_D() IO0SET |=LCD_A //选择写数据
#define Writecommand
//#define pgm_read_byte
//#define LcdCls
//函数声明
void Delayn(unsigned long n);
void Write595();
void HC595_Init(void);
void Lcd_Init(void);
void display_HZ(unsigned char x,unsigned char y,unsigned char *p);
void LcdCls(unsigned char data);
void Setxy(unsigned char x,unsigned char y);
//全局变量
unsigned int HC595_DATA=0xFFFFFFFF;
unsigned char ZHONG[]={
//取的字模
0x90,0x8C,0x84,0x84,0x84,0x84,0x85,0xF6,0x84,0x84,0x84,0x84,0x84,0xD4,0x8C,0x00,
0x00,0x20,0x10,0x08,0x04,0x02,0x01,0xFF,0x01,0x02,0x04,0x04,0x08,0x18,0x08,0x00, //"宋"
//主函数
int main(void)
HC595_Init(); //初始化74HC595
IO0DIR |=LCD_A|B_LED|LCD_CLK; //初始化IO口
Lcd_Init(); //初始化液晶屏
LcdCls(0x00);//清屏
Delayn(10000000); //此处是自己加的,清屏的时候可能会出现正在清上一次的图案时,字就显示出来了
display_HZ(6,2,ZHONG); //在第2页,第6列开始显示一个"宋"
while(1); //stop
//初始化595接口
IO0DIR |= MOSI|RCK;
IO1DIR |= SCLK;
IO1CLR |= SCLK;
IO0DIR |= RCK;
HC595_DATA =0xFFFFFFFF;Write595();
//写字节
void WriteByte(unsigned char data)
unsigned char i;
//IO0CLR;
for(i=0;i<8;i++)
if(data&0x01) IO0SET=MOSI;
else IO0CLR =MOSI;
IO1SET=SCLK;
data>>=1;
IO1CLR=SCLK;
//IO0SET=RCK;
//刷新595的数据
void Write595()
IO0CLR=RCK;
WriteByte(HC595_DATA&0xff);
WriteByte((HC595_DATA&0xff00)>>8);
WriteByte((HC595_DATA&0xff0000)>>16);
WriteByte((HC595_DATA&0xff000000)>>24);
IO0SET=RCK;
//延时周期数
while(n--);
//向SPI总线上写一个字节的数据
void LCDWriteByte(unsigned char data)
unsigned char i,s;
s=data;
for(i=0;i<8;i++)
{ //Delayn(1000000); //自己加的
if(s&0x80) Data_H();
else Data_L();
Sclk_H();
s<<=1;
Sclk_L();
//向液晶屏写数据
void WriteData(unsigned char Data)
Write_D();
CS_L();
LCDWriteByte(Data);
CS_H();
//向液晶屏写命令
void WriteCommand(unsigned char Command)
Write_C();
CS_L();
LCDWriteByte(Command);
CS_H();
//打开液晶背光 0:关闭 1:打开
void Lcd_BackLed(unsigned char on)
if(on==1)
IO0CLR=B_LED; //打开背光
else if(on==0)
IO0SET=B_LED; //关闭背光
//液晶复位
void Lcd_Reset(void)
Res_L();
Delayn(10000000);
Res_H();
//列顺序翻转,左右翻转 0:正常 1:翻转
void Lcd_ColRev(unsigned char i)
WriteCommand(0xa0|(i&0x01));
//清屏
unsigned char i,j;
for(i=0;i<9;i++) //依次刷8页
Setxy(0,i); //每次从0列开始
for(j=0;j<128;j++) //每页写128列
WriteData(data); //128次每次列地址自动递增
//液晶初始化
void Lcd_Init(void)
Lcd_Reset(); //液晶复位
//Lcd_BackLed(0);
Lcd_BackLed(1); //打开液晶背光
WriteCommand(0xaf); //打开显示
WriteCommand(0x40); //指定显示RAM的行地址,起始行为:0然后63,62,....2,1依次减小
WriteCommand(0xa1); //ADC正常???
WriteCommand(0xa6); //没有反白,正常显示
WriteCommand(0xa4); //全屏显示
WriteCommand(0xa2); //设置LCD的偏压比
WriteCommand(0xc0); //正常:意思是下端为0,往上依次为63,62....
WriteCommand(0x2f); //电源设置
WriteCommand(0x24); //粗调对比度
WriteCommand(0x81); //
WriteCommand(0x24); //跟上一行在一起相当于细调对比度
Lcd_ColRev(1); //左右翻转
//选择列x,页y
unsigned char tmp=0;
y=y&0x0F; //把页号变换为0XB0……0XB7的页定位码
y=y|0xb0;
tmp=x;
tmp>>=4; //变换出列号的定位码高低4位
tmp|=0x10;
x&=0x0F;
WriteCommand(y); //写页定位码
WriteCommand(tmp);//写列定位码(高)
WriteCommand(x); //写列定位码(低)
//显示汉字 x是列,y是页,p指向字模数组
void display_HZ(unsigned char x,unsigned char y,unsigned char *p) //p是汉字的首地址
unsigned char i;
WriteCommand(0xa4);
Setxy(x,y); //起始列,页
for(i=0;i<16;i++)
WriteData(*p++);//显示上半个汉字
y+=1;
Setxy(x,y); //到下页起点
for(i=16;i<32;i++)
WriteData(*p++); //显示下半个汉字
图片如下:
