寄存器分析
代碼分析
///////////////////////////////////////////////////////////////////////UART 初始化/////////////////////////////////////////////////////////////////////////////////////
void Uart_Init(int pclk,int baud)
int i;
if(pclk == 0)
pclk = PCLK; //APB IS USED FOR APB
rUFCON0 = 0x0; //关闭UART0的FIFO
rUFCON1 = 0x0; //关闭UART1的FIFO
rUFCON2 = 0x0; //关闭UART2的FIFO
rUMCON0 = 0x0;//关闭UART0自动流控制AFC (一般不进行握手协议控制)
rUMCON1 = 0x0;//关闭UART1自动流控制AFC (UART2没有自动流控制功能)
//UART0
rULCON0 = 0x3; //Normal,No parity,1 stop bit,8 bits da
rUCON0 = 0x245;
Transmit MODE:发送模式有请求中断发送和请求DMA发送
TX interrupt Type :当发送保持寄存器为空时(Non-FIFO MODE)或达到TX FIFO触发水平时触发中断的电平类型
(TX FIFO触发水平:00 = Empty 01 = 4-byte 10 = 8-byte 11 = 12-byte in UFCONn)
Receive MODE 接收模式有请求中断读取和请求DMA读取
RX interrupt Type :当接收保持寄存器为空时(Non-FIFO MODE)或达到RX FIFO触发水平时触发中断的电平类型(RX FIFO触发水平:00 = 4-byte 01 = 8-byte 10 = 12-byte 11 = 16-byte in UFCONn)
rUBRDIV0=( (int)(pclk/16/baud) -1 );
//UART1
rULCON1 = 0x3;
rUCON1 = 0x245;
rUBRDIV1=( (int)(pclk/16/baud) -1 );
//UART2
rULCON2 = 0x3;
rUCON2 = 0x245;
rUBRDIV2=( (int)(pclk/16/baud) -1 );
for(i=0;i<100;i++);
总结UART的控制寄存器:有ULCON、UCON、UFCON、UMCON、UBRDIV
///////////////////////////////////////////////////////////////////////UART 发送////////////////////////////////////////////////////////////////////////////////////
void Uart_SendByte(int da
if(whichUart==0)
if(da
while(!(rUTRSTAT0 & 0x2));
non FIFO=1 Byte BUFFER REGISTER(HOLDING REGISTER)+SHIFTER REGISTER
FIFO mode = 16 Byte BUFFER REGISTER(FIFO REGISTER)+SHIFTER REGISTER
Delay(10); //because the slow response of hyper_terminal
WrUTXH0(' ');
while(!(rUTRSTAT0 & 0x2)); //Wait until THR is empty.
Delay(10);
WrUTXH0(da
else if(whichUart==1)
if(da
while(!(rUTRSTAT1 & 0x2));
rUTXH1 = ' ';
while(!(rUTRSTAT1 & 0x2)); //Wait until THR is empty.
Delay(10);
rUTXH1 = da
else if(whichUart==2)
if(da
while(!(rUTRSTAT2 & 0x2));
rUTXH2 = ' ';
while(!(rUTRSTAT2 & 0x2)); //Wait until THR is empty.
Delay(10);
rUTXH2 = da
///////////////////////////////////////////////////////////////////////UART 接收////////////////////////////////////////////////////////////////////////////////////
char Uart_Getch(void)
if(whichUart==0)
while(!(rUTRSTAT0 & 0x1)); //Receive da
return RdURXH0();
while(!(rUTRSTAT1 & 0x1)); //Receive da
return RdURXH1();
while(!(rUTRSTAT2 & 0x1)); //Receive da
return RdURXH2();
总结UART有状态寄存器UTRSTAT、UERSTAT、UFSTAT、UMSTAT
有数据寄存器UTXH和URXH
关键字:MCU S3C2410 UART分析『本文转载自网络,版权归原作者所有,如有侵权请联系删除』
