使用的51单片机作为主控芯片,两个51单片机通过24L01通信,一个检测吊瓶滴液的速度,如果太快太慢或者不滴液都会报警,并发送到主机,输液者也可以主动通过按键呼叫主机,丛机用1602显示,主机用12864显示。
Altium Designer画的原理图和PCB图如下:
单片机源程序如下:
#include
#include
#include "keys.h"
#include "24L01.h"
#include "LCD1602.h"
#define uint unsigned int
#define uchar unsigned char
sbit YeDi=P2^0;//红外信号采集口
sbit Speaker=P2^4;//蜂鸣器
uchar TX_buf[32]=0;
uchar View_Con=0;
uchar View_Change=1;
uchar View_Con_Change=1;
uint Cap_Data=100;
uint Cap_View=0;
uchar View_Data[8];
uint YeDi_Num=0;
void InitTimer0(void)
TMOD |= 0x01;
TH0 = 0x0D8; //10000us
TL0 = 0x0F0;
EA = 1;
ET0 = 1;
TR0 = 1;
void InitTimer1(void)
TMOD |= 0x10;
TH1 = 0x0FC; //1000us
TL1 = 0x18;
EA = 1;
ET1 = 1;
void main()
TX_buf[1]=0;
TX_buf[2]=2;
TX_buf[3]=5;
TX_buf[4]=4;
InitLcd();
Lcd_1602_word(0x80,16," NRF24L01 "); //1602第一行显示 NRF24L01
//Lcd_1602_word(0xc0,16," Connecting "); //1602第二行显示 Connecting
while(NRF24L01_Check()); //检查24L01是否存在
NRF24L01_Init(); //开机的时候需要初始化24l01
InitTimer0(); //定时计数器0初始化
InitTimer1(); //定时计数器1初始化
while(1)
if(Key_Change) //如果Key_Change为真
Key_Change=0;
View_Change=1;
switch(Key_Value) //选择键值
case 1:
View_Con_Change=1;
if(View_Con==0)
View_Con=1;
TR1 = 1;
Cap_View=Cap_Data*100;
if(View_Con==2)
View_Con=1;
TR1 = 1;
break;
case 2:
if(View_Con==0) //液滴加
if(Cap_Data<=500)
Cap_Data+=10;
break;
case 3:
if(View_Con==0)
if(Cap_Data>10) //液滴减
Cap_Data-=10;
break;
case 4:
if(View_Con==1)
TR1 = 0;
YeDi_Num=0;
View_Con=2;
View_Con_Change=1;
TX_buf[0]=0xf5;//蜂鸣器响
TX_buf[5]=4;//用户呼叫
NRF24L01_TxPacket(TX_buf);
break;
if(View_Change)
View_Change=0;
if(View_Con_Change)
View_Con_Change=0;
switch(View_Con)
case 0:Lcd_1602_word(0x80,16,"Infusion Set: ");Lcd_1602_word(0xc0,16," ");break;
case 1:Lcd_1602_word(0x80,16,"In The Infusion ");Lcd_1602_word(0xc0,16," ");Speaker=1;break;
case 2:
Lcd_1602_word(0x80,16,"****Warning*****");Lcd_1602_word(0xc0,16,"****Warning*****");Speaker=0;
if(TX_buf[5]<4)
while(1);
break;
switch(View_Con)
case 0:
View_Data[0]=Cap_Data/100+0x30;
View_Data[1]=Cap_Data%100/10+0x30;
View_Data[2]=Cap_Data%10+0x30;
View_Data[3]='m';
View_Data[4]='l';
if(View_Data[0]==0x30)
View_Data[0]=' ';
Lcd_1602_word(0xcb,5,View_Data);
break;
case 1:
View_Data[0]=Cap_View/10000+0x30;
View_Data[1]=Cap_View%10000/1000+0x30;
View_Data[2]=Cap_View%1000/100+0x30;
View_Data[3]='.';
View_Data[4]=Cap_View%100/10+0x30;
View_Data[5]=Cap_View%10+0x30;
View_Data[6]='m';
View_Data[7]='l';
View_Data[0]=' ';
if(View_Data[1]==0x30)
View_Data[1]=' ';
Lcd_1602_word(0xc8,8,View_Data);
break;
void Timer0Interrupt(void) interrupt 1
static uchar YeDi_Con;
static uchar Key_Time0_Con;
TH0 = 0xfc;
TL0 = 0x18;
Key_Time0_Con++;
switch(YeDi_Con)
case 0:
if(YeD
