Platform: PIC1687A
Project : 实验16:矩阵式按键
Clock F : 外部4M
Software: PICC
Author : 竹林清风
comments:
学习使用矩阵式按键的用法
本例功能是按一下相应键,数码管显示相应的值
0-9;不带连发,不带组合,希望有兴趣的人帮忙完成
并共享
UP键按键计数
proteus仿真通过;
#include
#include
#include"delay.h"
#include"key.h"
unsigned char led_7[]={0x3f,0x06,0x5b,0x4F,0x66,0x6d,0x7d,0x07,0x7f,0x6f};//数码管显示值
unsigned char key_temp;
void main(void)
unsigned char ID=0;
TRISB=0X00;//所有B0端口输出
PORTB=0XFF;
TRISD=0X0F;//初始化键盘接口
PORTD=0XFF;//置输出为高电平
while(1){
delay_nms(5);
key_temp = read_keyboard(); // 调用键盘接口函数读键盘
if (key_temp != No_key)
{ // 有按键按下
switch(key_temp)
case 1:
PORTB=led_7[1];
break;
case 2:
PORTB=led_7[2];
break;
case 3:
PORTB=led_7[3];
break;
case 4:
PORTB=led_7[4];
break;
case 5:
PORTB=led_7[5];
break;
case 6:
PORTB=led_7[6];
break;
case 7:
PORTB=led_7[7];
break;
case 8:
PORTB=led_7[8];
break;
case 9:
PORTB=led_7[9];
break;
case K3_2:
PORTB=led_7[0];
break;
case 13:
if(++ID>=10)
ID=0;
PORTB=led_7[ID];
break;
下面为延时函数:文件delay.c
void delay_1us(void) //1us
asm("nop");
void delay_nus(unsigned int n) //N us延时函数
unsigned int i=0;
for (i=0;i
void delay_1ms(void) //1ms延时函数
unsigned int i;
for (i=0;i<1140;i++);
void delay_nms(unsigned int n) //N ms延时函数
unsigned int i=0;
for (i=0;i
头文件:delay.h
void delay_1us(void);
void delay_nus(unsigned int n); //N us延时函数
void delay_1ms(void); //1ms延时函数
void delay_nms(unsigned int n); //N ms延时函数
键盘key.h
#define No_key 255
#define K1_1 1
#define K1_2 2
#define K1_3 3
#define k1_4 4
#define K2_1 5
#define K2_2 6
#define K2_3 7
#define K2_4 8
#define K3_1 9
#define K3_2 0
#define K3_3 10
#define K3_4 11
#define K4_1 12
#define K4_2 13
#define K4_3 14
#define K4_4 15
#define Key_mask 0b00001111
unsigned char read_keyboard()
static unsigned char key_state = 0, key_value, key_line;
unsigned char key_return = No_key,i,key_time;
switch (key_state)
case 0:
key_line = 0b00010000;
for (i=1; i<=4; i++) // 扫描键盘
PORTD = ~key_line; // 输出行线电平
PORTD = ~key_line; // 必须送2次!!!
key_value = Key_mask & PORTD; // 读列电平
if (key_value == Key_mask)
key_line <<= 1; // 没有按键,继续扫描
else
key_state++; // 有按键,停止扫描
break; // 转消抖确认状态
break;
case 1:
if (key_value == (Key_mask & PORTD)) // 再次读列电平,
switch (key_line | key_value) // 与状态0的相同,确认按键
{ // 键盘编码,返回编码值
case 0b00011110:
key_return = K1_1; //"1"
key_state++;
break;
case 0b00011101:
key_return = K1_2; //"2"
key_state++;
break;
case 0b00011011:
key_return = K1_3; //"3"
key_state++;
break;
case 0b00010111:
key_return = k1_4; //"4"
key_state++;
break;
case 0b00101110:
key_return = K2_1; //"5"
key_state++;
break;
case 0b00101101:
key_return = K2_2; //"6"
key_state++;
break;
case 0b00101011:
key_return = K2_3; //"7"
key_state++;
break;
case 0b00100111:
key_return = K2_4; //"8"
key_state++;
break;
case 0b01001110:
key_return = K3_1; //"9"
key_state++;
break;
case 0b01001101:
key_return = K3_2; //"0"
key_state++;
break;
case 0b01001011:
key_return = K3_3; //"A"
key_state++;
break;
case 0b01000111:
key_return = K3_4; //"B"
key_state++;
break;
case 0b10001110:
key_return = K4_1; //"C"
key_state++;
break;
case 0b10001101:
//key_return = K4_2; //"D"
// key_state++;
key_time=0;
key_state=3;
break;
case 0b10001011:
key_return = K4_3; //"E"
key_state++;
break;
case 0b10000111:
key_return = K4_4; //"F"
key_state++;
break;
// 转入等待按键释放状态
else
key_state--; // 两次列电平不同返回状态0,(消抖处理)
break;
case 2: // 等待按键释放状态
PORTD = 0b00000111; // 行线全部输出低电平
PORTD = 0b00000111; // 重复送一次
if ( (Key_mask & PORTD) == Key_mask)
key_state=0; // 列线全部为高电平返回状态0
break;
case 3:
key_return = K4_2;
//break;
else if( (Key_mask & PORTD)!=Key_mask)
if(++key_time>=100)
key_state=4;
key_time=0;
key_return=20;
break;
case 4:
else if(++key_time>=20)
key_time=0;
key_return=20;
break;
return key_return;
