最近刚接触MPLABX集成开发环境,X16和X8编译器,和以前的PIC的开发环境有了很大的区别,这里就说一下新建工程的第一步,配置位的编写。
16F877A Support Information
#pragma config Usage
#pragma config =
For example:
// Brown-out Reset Enable bit: BOR disabled
// Data EEPROM Memory Code Protection bit: Data EEPROM code protection off
// In-Circuit Debugger Mode bit: In-Circuit Debugger disabled, RB6 and RB7 are general purpose I/O pins
// Flash Program Memory Write Enable bits: Write protection off; all program memory may be written to by EECON control
// Oscillator Selection bits: XT oscillator
// Watchdog Timer Enable bit: WDT disabled
// Flash Program Memory Code Protection bit: Code protection off
// Low-Voltage (Single-Supply) In-Circuit Serial Programming Enable bit: RB3 is digital I/O, HV on MCLR must be used for programming
// Power-up Timer Enable bit: PWRT disabled
#pragma config BOREN = OFF, CPD = OFF, DEBUG = OFF, WRT = OFF, FOSC = XT, WDTE = OFF, CP = OFF, LVP = OFF, PWRTE = OFF
#pragma config =
For example:
#pragma config BOREN = 0x0, CPD = 0x1, DEBUG = 0x1, WRT = 0x3, FOSC = 0x1, WDTE = 0x0, CP = 0x1, LVP = 0x0, PWRTE = 0x1
#pragma config =
For example:
#pragma config CONFIG = 0xFF39
For example:
// IDLOC @ 0x2000
#pragma config IDLOC0 = 0x3FFF
#pragma config Settings
Register: CONFIG @ 0x2007
BOREN = |
Brown-out Reset Enable bit |
OFF |
BOR disabled |
ON |
BOR enabled |
CPD = |
Data EEPROM Memory Code Protection bit |
OFF |
Data EEPROM code protection off |
ON |
Data EEPROM code-protected |
DEBUG = |
In-Circuit Debugger Mode bit |
OFF |
In-Circuit Debugger disabled, RB6 and RB7 are general purpose I/O pins |
ON |
In-Circuit Debugger enabled, RB6 and RB7 are dedicated to the debugger |
WRT = |
Flash Program Memory Write Enable bits |
OFF |
Write protection off; all program memory may be written to by EECON control |
HALF |
0000h to 0FFFh write-protected; 1000h to 1FFFh may be written to by EECON control |
1FOURTH |
0000h to 07FFh write-protected; 0800h to 1FFFh may be written to by EECON control |
256 |
0000h to 00FFh write-protected; 0100h to 1FFFh may be written to by EECON control |
FOSC = |
Oscillator Selection bits |
XT |
XT oscillator |
LP |
LP oscillator |
EXTRC |
RC oscillator |
HS |
HS oscillator |
WDTE = |
Watchdog Timer Enable bit |
OFF |
WDT disabled |
ON |
WDT enabled |
CP = |
Flash Program Memory Code Protection bit |
OFF |
Code protection off |
ON |
All program memory code-protected |
LVP = |
Low-Voltage (Single-Supply) In-Circuit Serial Programming Enable bit |
OFF |
RB3 is digital I/O, HV on MCLR must be used for programming |
ON |
RB3/PGM pin has PGM function; low-voltage programming enabled |
PWRTE = |
Power-up Timer Enable bit |
OFF |
PWRT disabled |
ON |
PWRT enabled |
Register: IDLOC0 @ 0x2000
Register: IDLOC1 @ 0x2001
Register: IDLOC2 @ 0x2002
Register: IDLOC3 @ 0x2003
