;LIST P=SM311, CLOCK=4MHZ, WDT=DISBALE,INT=ENABLE
; LOUDOUT RA0 1 14 RA1 WHITE_BULB
; SIGNAL_IN RB7 2 13 RA2 BLUE_BULB
; READ RB6 3 12 RA3 BROWN_BULB
; VDD 4 11 VSS
; K1 RB5 5 10 RB0 YELLOW_BULB
; K2 RB4 6 9 RB1 BUZ
; RESET RB3 7 8 RB2 POWER_CUT
INDF EQU 00H
TMR0 EQU 01H
PCL EQU 02H
STATUS EQU 03H
FSR EQU 04H
RA EQU 05H
LOUDOUT EQU 0
WHITE_BULB EQU 1
BLUE_BULB EQU 2
BROWN_BULB EQU 3
RB EQU 06H
YELLOW_BULB EQU 0
BUZ EQU 1
POWER_CUT EQU 2
K2 EQU 4
K1 EQU 5
READ EQU 6
SIGNAL_IN EQU 7
IRQM EQU 09H
TM0M EQU 0
PBM EQU 1
INTM EQU 7
IRQF EQU 0AH
TM0F EQU 0
PBF EQU 1
PA_PDM EQU 0BH
PB_PUP EQU 0CH
PB_PDM EQU 0DH
PB_POD EQU 0EH
WAKEUP EQU 0FH
A EQU 0
M EQU 1
;---STATUS REG----------------------------------------------
C EQU 0
DC EQU 1
Z EQU 2
PD EQU 3
TO EQU 4
GP0 EQU 5
GP1 EQU 6
GP2 EQU 7
;---OPTION REG----------------------------------------------
PS0 EQU 0
PS1 EQU 1
PS2 EQU 2
PSA EQU 3
T0SE EQU 4
T0CS EQU 5
INTEDG EQU 6
;---PA_PDM REG----------------------------------------------
DB0 EQU 0
DB1 EQU 1
DB2 EQU 2
EXTEN EQU 6
RTCEN EQU 7
;---PB_POD REG----------------------------------------------
OB0 EQU 0
OB1 EQU 1
OB2 EQU 2
OB4 EQU 4
OB5 EQU 5
OB6 EQU 6
OB7 EQU 7
;---WAKEUP REG----------------------------------------------
EN0 EQU 0
EN1 EQU 1
EN2 EQU 2
EN4 EQU 4
EN5 EQU 5
EN6 EQU 6
EN7 EQU 7
;CONSUMER REGISTER
MAXDATA EQU .250 ; 高低电平宽度最大值
CODE_TOTAL EQU 20H
LCODE EQU 21H ; 记录一帧码的低8位数据
MCODE EQU 22H ; 记录一帧码的中8位数据
HCODE EQU 23H ; 记录一帧码的高8位数据
LBIT EQU 25H ; 记录'0'和'1'码的低电平宽度
HBIT EQU 26H ; 记录'0'和'1'码的高电平宽度
LCODE_EE EQU 27H ; 记录EEPROM低8位数据
MCODE_EE EQU 28H ; 记录EEPROM中8位数据
HCODE_EE EQU 29H ; 记录EEPROM高4位数据
MODEREG EQU 2AH ; 按键定时器
SHIFT EQU 2BH
KEYREG EQU 2CH
CNT_LW EQU 2DH ; 定时寄存器
CNT_HI EQU 2EH
FRAME EQU 2FH ;
CNT EQU 30H
CNT2 EQU 31H
DEL1 EQU 32H
CNT_32MS EQU 33H
CNT_4S EQU 34H
CNT_1M EQU 35H
W_REG EQU 36H
S_REG EQU 37H
R_BUZ
